path: root/arch/arm/boot/dts/imx6qdl-microsom-ar8035.dtsi
2015-06-03ARM: dts: cubox-i/hummingboard: Fix the license textFabio Estevam
Arrange the license text a bit to make it clear. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-03-30ARM: dts: Re-license SolidRun iMX6 platform DT GPL v2/X11Russell King
Update SolidRun iMX6 platforms DT descriptions to be dual-licensed. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Rabeeh Khoury <rabeeh@solid-run.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-08-27ARM: dts: microsom-ar8035: MDIO pad must be set open drainimx-fixes-3.17-2Rabeeh Khoury
This patch is important for the MicroSOM implementation due to the following details - 1. VIH of the Atheros phy is 1.7V. 2. NVCC_ENET which is the power domain of the MDIO pad is driven by the PHY's LDO (i.e. either 1.8v or 2.5v). 3. The MicroSOM implements an onbouard 1.6kohm pull up to 3.3v (R3000). In the case the PHY's LDO was 1.8v then there would be only a 100mV margin for the signal to be acknowledged as high (1.8v-1.7v). Due to that setting the pad as an open drain will let the 1.6kohm pull that signal high to 3.3 that assures enough margins to the PHY to be acked as '1' logic. Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-04-14ARM: dt: microsom: don't set bit 7 for ethernet mux settingsRussell King
Bit 6,7 are marked as reserved for the ethernet RGMII pins, so avoid setting these bits. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-01-27ARM: imx: initial SolidRun HummingBoard supportRussell King
Add support for the SolidRun HummingBoard. This commit adds support for the following interfaces on this board: - Consumer Ir receiver - S/PDIF output - Both USB interfaces - Gigabit Ethernet using AR8035 - UART port Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
