Update IPU and display property, make sure these dts files can
pass build.
Signed-off-by: Sandor Yu <R01008@freescale.com>
commit 89c1a8cf63f8c69dfddb6e377c04df8b25ab1c88 upstream.
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios
should be changed to GPIO_ACTIVE_HIGH.
Otherwise, the SD may not work properly due to wrong polarity inversion
specified in DT after switch to common parsing function mmc_of_parse().
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit 0af822110871400908d5b6f83a8908c45f881d8f upstream.
This fixes a duplicated pin control causing this error:
imx6q-pinctrl 20e0000.iomuxc: pin MX6Q_PAD_GPIO_1 already
requested by regulators:regulator@2; cannot claim for 2184000.usb
imx6q-pinctrl 20e0000.iomuxc: pin-137 (2184000.usb) status -22
imx6q-pinctrl 20e0000.iomuxc: could not request pin 137
(MX6Q_PAD_GPIO_1) from group usbotggrp on device 20e0000.iomuxc
imx_usb 2184000.usb: Error applying setting, reverse things
back
imx6q-pinctrl 20e0000.iomuxc: pin MX6Q_PAD_EIM_D31 already
requested by regulators:regulator@1; cannot claim for 2184200.usb
imx6q-pinctrl 20e0000.iomuxc: pin-52 (2184200.usb) status -22
imx6q-pinctrl 20e0000.iomuxc: could not request pin 52 (MX6Q_PAD_EIM_D31)
from group usbh1grp on device 20e0000.iomuxc
imx_usb 2184200.usb: Error applying setting, reverse things
back
Signed-off-by: Felipe F. Tonello <eu@felipetonello.com>
Fixes: e2047e33f2bd ("ARM: dts: add initial Rex Pro board support")
imx6qdl-rex boards use sgtl5000 codec and the machine file (imx-sgtl5000)
already sets SSI in slave mode and codec in master mode, so there is no need
for having this property.
Cc: Robert Nelson <robertcnelson@gmail.com>
Add initial Rex Pro i.mx6q board support. Ethernet, UART, USB, I2C, SPI, HDMI,
Audio, and SDHC cards are working. Currently no mainline u-boot, so boot with
cat zImage imx6q-rex-pro.dtb > zImage.dtb, then using mkimage create uImage
Signed-off-by: Robert Nelson <robertcnelson@gmail.com>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
