Add Cypress wifi bcm4339 support with fmac driver for below platforms:
- imx6q/dl/qp-sabresd
- imx6sl/sll-evk
- imx6sx-sdb
Reviewed-by: Frank Li <frank.li@nxp.com>
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
Add BT modem device reset node.
Enable the Bluetooth interface for i.MX 6SoloLite EVK.
Signed-off-by: xlin <xlin@murata.com>
Signed-off-by: Tiberiu Breana <andrei-tiberiu.breana@nxp.com>
MMC core pm_notify will re-detect card after system suspend/resume,
regardless of post-cd claim.
Since in current MMC implement, non-removeable card only detects once,
this will break post card detect which happens next.
e.g. when we suspend/resume system first, then load Broadcom wifi module,
we will get below dump:
root@imx6qdlsolo:/mnt/nfs/vte_IMX6QP-Sabre-SD# modprobe bcmdhd firmware_path=/lib/firmware/bcm/ZP_BCM4339/fw_bcmdhd.bin nvram_path=/lib/firmware/bcm/ZP_BCM4339/bcmdhd.ZP.SDIO.cal
dhd_module_init in
Power-up adapter 'DHD generic adapter'
wifi_platform_bus_enumerate device present 1
failed to power up DHD generic adapter, 3 retry left
wifi_platform_bus_enumerate device present 0
-----------[ cut here ]-----------
Kernel BUG at 80513170 [verbose debug info unavailable]
Internal error: Oops - BUG: 0 1 PREEMPT SMP ARM
Modules linked in: bcmdhd ov5642_camera ov5640_camera_mipi_int ov5640_camera_int mxc_v4l2_capture mxc_dcic ipu_bg_overlay_sdc ipu_still v4l2_int_device ipu_prp_enc ipu_csi_enc ipu_fg_overlay_sdc
CPU: 1 PID: 1487 Comm: modprobe Not tainted 4.1.15-1.0.0+g54cf6a2 #1
Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
task: a881e3c0 ti: a9152000 task.ti: a9152000
PC is at mmc_sdio_remove+0x7c/0x80
LR is at mmc_sdio_force_remove+0xc/0x34
pc : [<80513170>] lr : [<80513180>] psr: 60030013
sp : a9153d28 ip : 00000000 fp : 00000000
r10: 00000000 r9 : 00000000 r8 : 7f0f76e0
r7 : a9153d58 r6 : 00000000 r5 : 00000000 r4 : a83f1800
r3 : 00000000 r2 : 00000000 r1 : 809c02f4 r0 : a83f1800
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c53c7d Table: 38d7804a DAC: 00000015
Process modprobe (pid: 1487, stack limit = 0xa9152210)
Stack: (0xa9153d28 to 0xa9154000)
3d20: 00000000 7f0c569c a9ffe440 00000003 00000000 7f0c58f4
3d40: a81942c0 8032e33c a8195960 7f0fbf68 00020002 00000000 a9153d58 a9153d58
3d60: fffffdfb 80bc0db4 a81af810 7f0f9518 fffffdfb 00000008 00000000 5624ce5c
3d80: 00000124 80381140 80bc0db4 a81af810 7f0f9518 00000000 00000008 8037f9dc
3da0: a81af810 7f0f9518 a81af844 80b288b0 00000000 8037fbec 00000000 7f0f9518
3dc0: 8037fb60 8037e068 a8025c5c a818fa34 7f0f9518 a20ff280 00000000 8037f16c
3de0: 7f0f0330 a9ffe440 00000000 7f0f9518 a9ffe440 00000000 80bb18f4 803801ec
3e00: 7f0fbf68 a9ffe440 00000000 7f0c5fdc 80b01720 80b01720 a9ffe440 7f11f000
3e20: 00000000 00000001 5624ce5c 80009730 abc7b120 800e316c 000000c8 a9209a00
3e40: 8040003f 00000001 00010000 800b0dfc 000000c8 8040003f abc7dc60 80afc2b0
3e60: abc75880 80afc260 a8001f00 80afe6c0 00000124 800e4944 7f0f9718 00000001
3e80: 7f0f9718 00000001 a9ffeb00 7f0f9718 a9db31c0 8078e47c 7f0f9718 a9db31c0
3ea0: a9153f58 00000001 a9db31c8 80094094 7f0f9724 00007fff 800910d4 00000000
3ec0: 00000000 7f0f9760 00000000 7f0f9860 c0fce8f4 7f0f9724 00000000 8079aa0c
3ee0: c0f07000 000c7944 00b6817a 00000000 0000000e 00000000 00000000 00000000
3f00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
3f20: 00000000 00000000 00000000 00000000 00000640 00000000 00000003 01608348
3f40: 0000017b 8000f604 a9152000 00000000 01608270 800944f8 c0f07000 000c7944
3f60: c0fce28c c0f83439 c0f99248 0007aff8 0008f968 00000000 00000000 00000000
3f80: 00000029 0000002a 00000020 00000024 00000015 00000000 01608348 00000073
3fa0: 00000000 8000f480 01608348 00000073 00000003 01608348 00000000 00000000
3fc0: 01608348 00000073 00000000 0000017b 01608218 00000000 00000073 01608270
3fe0: 7e9ab8c0 7e9ab8b0 0001f2c0 76eac340 600d0010 00000003 00000000 00000000
[<80513170>] (mmc_sdio_remove) from [<7f0c58f4>] (dhd_wifi_platform_load+0x180/0x39c [bcmdhd])
[<7f0c58f4>] (dhd_wifi_platform_load [bcmdhd]) from [<80381140>] (platform_drv_probe+0x44/0xac)
[<80381140>] (platform_drv_probe) from [<8037f9dc>] (driver_probe_device+0x174/0x2b4)
[<8037f9dc>] (driver_probe_device) from [<8037fbec>] (__driver_attach+0x8c/0x90)
[<8037fbec>] (__driver_attach) from [<8037e068>] (bus_for_each_dev+0x68/0x9c)
[<8037e068>] (bus_for_each_dev) from [<8037f16c>] (bus_add_driver+0x148/0x1f0)
[<8037f16c>] (bus_add_driver) from [<803801ec>] (driver_register+0x78/0xf8)
[<803801ec>] (driver_register) from [<7f0c5fdc>] (dhd_wifi_platform_register_drv+0x1bc/0x208 [bcmdhd])
[<7f0c5fdc>] (dhd_wifi_platform_register_drv [bcmdhd]) from [<80009730>] (do_one_initcall+0x8c/0x1d4)
[<80009730>] (do_one_initcall) from [<8078e47c>] (do_init_module+0x5c/0x1a8)
[<8078e47c>] (do_init_module) from [<80094094>] (load_module+0x1ba8/0x1e50)
[<80094094>] (load_module) from [<800944f8>] (SyS_finit_module+0x80/0x90)
[<800944f8>] (SyS_finit_module) from [<8000f480>] (ret_fast_syscall+0x0/0x3c)
Signed-off-by: Dong Aisheng <aisheng.dong@nxp.com>
(cherry picked from commit 2ce993c504798e7fad0910432bd2c6cbd332120d)
BCM WiFi driver needs to take care of card detect by itself.
Using cd-post property to tell MMC core not detect card automatically
during host driver probe and post it untill client driver tells it to
do it.
Add Murata Type ZP (BCM4339) module support on below platforms:
- i.MX6Q/DL/QP SabreSD(SD2 slot) + Murata adapter V2.0
- i.MX6SX SDB (SD3+SD2 slot) + Murata adapter V1.0 & SD EXT card
- i.MX6SL EVK (SD1+SD3 slot) + Murata adapter V1.0 & SD EXT card
- i.MX6UL SDB RevC (SD1 slot) + Murata adapter V2.0
Note: MX6Q/DL/QP SabreSD board requires HW rework.
Please refer to rework guide specified in schematic.
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
