Otherwise M/F will be off while system sleep even wakeup source
is enabled or requested on.
Reviewed-by: Anson Huang <Anson.Huang@nxp.com>
Signed-off-by: Li Jun <jun.li@nxp.com>
Add node for the RNGB block.
Signed-off-by: Horia Geantă <horia.geanta@nxp.com>
Acked-by: Leonard Crestez <leonard.crestez@nxp.com>
removing all the leading "0x" and zeros to fix the
following dtc warnings:
Warning (unit_address_format): Node /XXX unit name should not have leading "0x"
and
Warning (unit_address_format): Node /XXX unit name should not have leading 0s
Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com>
change compatible string for sdma
Signed-off-by: Shengjiu Wang <shengjiu.wang@nxp.com>
(cherry picked from commit 12c7a2a0fa87a09977eb5582a28f39db29b11f00)
Change the usdhc compatible to make it support hs400 mode.
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
add epdc node on imx6sll
Signed-off-by: Robby Cai <robby.cai@nxp.com>
add pxp property on imx6sll
Update the clocks of cpu to match with the
cpufreq driver.
Signed-off-by: Jacky Bai <ping.bai@nxp.com>
Add busfreq node for i.MX6SLL.
Add the OCRAM node on i.MX6SLL for low power feature support.
Correct ecspi/sdma compatible since ecspi errata ERR009165
not fixed on i.mx6sll chip.
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
[ Aisheng: fix small conflicts during upgrade ]
Signed-off-by: Dong Aisheng <aisheng.dong@nxp.com>
Use a space before and after assignment operator to have consistent
style.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
GIC is inside of SoC from architecture perspective, it should
be located inside of soc node in DT.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Correct sdma compatible since ecspi errata ERR009165 has been fixed
on i.mx6sll as i.mx6ul.
The SNVS poweroff depends on board design, by default it should
be disabled in SoC DT and ONLY be enabled on board DT if it is
wired up to external PMIC.
The SNVS power key depends on board design, by default it should
wired up.
Add #cooling-cells for i.MX6SLL cpu-freq cooling device usage.
Since 25aaa75df1e6 SDMA driver uses clock rates of "ipg" and "ahb"
clock to determine if it needs to configure the IP block as operating
at 1:1 or 1:2 clock ratio (ACR bit in SDMAARM_CONFIG). Specifying both
clocks as IMX6SLL_CLK_SDMA result in driver incorrectly thinking that
ratio is 1:1 which results in broken SDMA funtionality. Fix the code
to specify IMX6SLL_CLK_IPG as "ipg" clock for SDMA, to avoid detecting
incorrect clock ratio.
Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com>
Cc: Angus Ainslie (Purism) <angus@akkea.ca>
Cc: Chris Healy <cphealy@gmail.com>
Cc: Lucas Stach <l.stach@pengutronix.de>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Shawn Guo <shawnguo@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/dt
i.MX device tree update for 4.21:
- New boards support: emtrion emCON-MX6, imx6ul-pico-pi, imx7d-sdb-reva
and vf610 based Liebherr's BK4 device, ZII SCU4 AIB board.
- Add flexcan support for i.MX6UL SoC, turn on stop mode wakeup feature
for flexcan, and enable devices on a few i.MX6 NXP boards.
- Enable AUO G101EVN010 lcd panel and Goodix touch support for
imx6ul-ccimx6ulsbcpro board.
- Enable sensors support for imx6qdl-sabresd board: egalax touch, light,
magnetometer and accelerometer sensor.
- Switch more boards to use SPDX identifier.
- Fix memory node duplication in i.MX device tree sources.
- Correct GIC PPI interrupts mask for i.MX6UL and i.MX7 SoCs.
- Drop 'snps,dw-pcie' compatible from LS1021A PCIe device to avoid
incorrect device matching.
- Add the gpu nodes for the adreno 200 GPU on iMX51 and iMX53, which
are now supported by the freedreno driver.
- Add DCP device support for i.MX6ULL, which requires explicit clock
enabling.
- Add '#thermal-sensor-cells' for thermal device and '#cooling-cells'
for cooling devices.
- Add missing clock information for EPIT on i.MX25 SoC.
- Add PWM and qdma devices for LS1021A SoC.
- Update cooling maps of LS1021A SoC to include all devices affected by
individual trip points.
- Random device addition and cleanup on various boards.
* tag 'imx-dt-4.21' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: (82 commits)
ARM: dts: imx51-zii-rdu1: Do not specify "power-gpio" for hpa1
ARM: dts: imx6ul: Remove extra space between node name and brace
ARM: dts: imx6qdl-sabresd: Use GPIO_ACTIVE_HIGH for regulators
ARM: dts: imx6ul: add flexcan support
ARM: dts: imx5: add gpu nodes
ARM: dts: imx6qdl-sabresd: add accelerometer sensor support
ARM: dts: imx6qdl-sabresd: add magnetometer sensor support
ARM: dts: imx6qdl-sabresd: add light sensor support
ARM: dts: imx6qdl-sabresd: Move regulators outside of "simple-bus"
ARM: dts: imx6qdl: Fix memory node duplication
ARM: dts: imx6dl-mamoj: Add a memory node
ARM: dts: imx53-voipac-dmm-668: Fix memory node duplication
ARM: dts: vf610-zii-scu4-aib: Add HI8435 support
ARM: dts: imx6qdl-sabresd: add egalax touch screen support on i2c2 bus
ARM: dts: imx7s: Add flexcan stop mode wakeup support
ARM: dts: imx6ul: Add flexcan stop mode wakeup support
ARM: dts: imx6qdl: Add flexcan stop mode wakeup support
ARM: dts: imx6sx: Add flexcan stop mode wakeup support
ARM: dts: imx6ul-pico: Add the imx6ul-pico-pi variant
ARM: dts: imx6ul-pico-hobbit: Extend peripherals support
The "fsl,mf-mix-wakeup-irq" is ONLY used as a temporary
solution in NXP's internal tree for Mega/Fast Mix off
feature after suspend, upstream kernel does NOT need it,
remove it.
i.MX6 SoCs has MMDC clock gates in CCM CCGR, add
clock property for MMDC driver's clock operation.
Fix the type of compatible string "fs,imx6sll-i2c" which should be
"fsl,imx6sll-i2c".
Signed-off-by: Oleksij Rempel <o.rempel@pengutronix.de>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
i.MX6SLL has GPIO clock gates in CCM CCGR, add
clock property for GPIO driver to make sure all
GPIO banks work as expected.
Add "gpio-ranges" property to establish connections between GPIOs
and PINs on i.MX6SLL pinctrl driver, for details, please refer to
Documentation/devicetree/bindings/gpio/gpio.txt of "gpio-ranges"
property.
i.MX6SLL uses same SRC module as i.MX51, add "fsl,imx51-src"
compatible string to enable SRC driver to support setting
CPU resume address for cpu-idle and suspend/resume.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Add dtsi file for imx6sll.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
Reviewed-by: Rob Herring <robh@kernel.org>
Acked-by: Dong Aisheng <Aisheng.dong@nxp.com>
