path: root/arch/arm/boot/dts/imx6ul-isiot-emmc.dts
2017-07-16ARM: dts: imx6ul-isiot: Move common nodes in imx6ul-isiot.dtsiJagan Teki
Maintaining separate dtsi file with common nodes make unclear and confusing since -isiot.dtsi is available for adding common nodes. If the nodes are common between the dts files then mark status as "okay" otherwise mark it "disabled" so-that respective dts can mark status "okay" Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-04-10ARM: dts: imx6ul-isiot: Add imx6ul-isiot-common.dtsiJagan Teki
lcdif nodes are differ wrt specific LCD connected on Is.IoT MX6UL module, so create separate file 'imx6ul-isiot-common.dtsi' for common lcdif node structure and include the same on respective dts. More common nodes will add in future patches. Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-01-24ARM: dts: imx6ul: Add Engicam Is.IoT MX6UL eMMC initial supportJagan Teki
Engicam Is.IoT MX6UL has separate module for eMMC, so add emmc dts file for imx6ul-isiot.dtsi, usdhc2 node represent eMMC. dmesg: ----- mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA mmc1: new DDR MMC card at address 0001 mmcblk1: mmc1:0001 M62704 3.53 GiB Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
