The new parameter description is:
gpr = <gpr-node, register-offset, mask, value>;
Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com>
(cherry picked from commit 7a97a245bb794d3dfac11240941e5bda653cab74)
support display in audio dts imx6ull-14x14-ddr3-arm2-cs42888.dts
On i.MX6ULL, the pin MUX and CTRL register of BOOT_MODEx and TAMPERx
pins have been move to the IOMUXC_SNVS. Add additional pinfunc define
and correct the pinctrl binding.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
of hog
Move usdhc1 wp/cd/reset/vselect pin setting and usdhc2 reset pin
setting out of hog. Due to many pin conflict with usdhc1 and usdhc2,
this patch can let other modules do not touch the iomuxc.
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
Add wm8958 sound card in cs42888 dts, SAI2 conflict with SD1.
So disable usdhc1.
Add the dize size info in the ARM2 board dts file name to align with
i.MX6UL, so mfgtool and yocto script can handle the naming rule easily.
