2016-02-02 | MLK-12370 ARM: dts: imx7d-12x12-lpddr3-arm2: disable sim1 node in flexcan ↵ | Fugang Duan | |
dts file The sim1 has pin conflicts with flexcan1,flexcan2 and sai1. By default, imx7d 12x12 lpddr3 arm2 default dts enable sim1 node and disable flexcan1, flexcan2, sai1 nodes. The patch do two things: - disable sim1 node in extended flexcan dts file - remove redundant sim1 node in default dts file Signed-off-by: Fugang Duan <B38611@freescale.com> | |||
2016-01-14 | MLK-10392-1 dts: imx7d-arm2: add flexcan support | Dong Aisheng | |
New dts file imx7d-12x12-lpddr3-arm2-flexcan.dts introduced due to pin conflict with enet1 and sai1. Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com> |
