Keystone K2L-EVM has two 1G Marvell 88E1514 Ethernet PHYs
installed, which are compatible with 88E1510.
Hence, add corresponding child nodes for 1G MDIO bus.
For more information see:
https://www.einfochips.com/index.php/partnerships/texas-instruments/k2l-evm.html
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
k2hk, k2e, k2l EVM board have the same Micron N25Q128A11
SPI NOR Flash installed on SPI0 bus.
The NOR Flash is splitted on two partistions:
partition@0
label = "u-boot-spl";
reg = <0x0 0x80000>;
partition@1
label = "misc";
reg = <0x80000 0xf80000>;
Hence, add SPI NOR Flash nodes to all k2hk, k2e, k2l EVM boards.
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Add AEMIF/NAND device entry.
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
I2C devices are not the part of Keystone SoC and have to be
defined in board DTS files.
Hence, move i2c0 EEPROM device node from Keystone SoC to
k2hk, k2e, k2l EVM files as they all have similar EEPROM SoCs
installed.
As suggested by Olof Johansson at
http://www.spinics.net/lists/arm-kernel/msg314009.html.
It be better just keeping a "ti,keystone" top-level compatible and
just using that to probe. If so we don't have to touch the file
for new boards in the future.
So use common "ti,keystone" compatible in keystone.c for all boards.
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Olof Johansson <olof@lixom.net>
Keystone2 Lamarr (K2L) is a dual Cortex A15 core based SoC with
4 DSPs. It has standard peripherals such as i2c, spi, uart, timer,
pcie etc., similar to k2hk, but different set of wireless hardware.
This patch add support for k2 Lamarr SoC and EVM. This re-uses the
common keystone.dtsi to include common bindings across the various
k2 devices.
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: Mark Rutland <mark.rutland@arm.com>
