path: root/arch/arm/boot/dts/kirkwood-dreamplug.dts
2015-05-25ARM: kirkwood: add "jedec,spi-nor" flash compatible bindingRafał Miłecki
Starting with commit 8947e396a829 ("Documentation: dt: mtd: replace "nor-jedec" binding with "jedec, spi-nor"") we have "jedec,spi-nor" binding indicating support for JEDEC identification. Use it for all flashes that are supposed to support READ ID op according to the datasheets. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2014-05-19Merge tag 'mvebu-dt-3.16' of git://git.infradead.org/linux-mvebu into next/dtOlof Johansson
Merge "ARM: mvebu: DT changes for v3.16" from Jason Cooper: mvebu DT changes for v3.16 - kirkwood - rework nsa3x0 board to add nsa320 - large cleanup to facilitate use in barebox - guruplug phy updates - audio updates for t5325 - mvebu - use clocks vice clock-frequency for uart nodes - armada 375/380/385 - add watchdog node - add coherency fabric - add smp support - add sdhci - add ahci - add thermal sensor - armada 370/XP - and pmsu * tag 'mvebu-dt-3.16' of git://git.infradead.org/linux-mvebu: (35 commits) ARM: Kirkwood: t5325: Use simple card to instantiate audio ARM: Kirkwood: DT: Add missing #sound-dai-cells property ARM: Kirkwood: Add node for audio codec ARM: dts: kirkwood: set Guruplug phy-connection-type to rgmii-id ARM: dts: kirkwood: set Guruplug ethernet PHY compatible ARM: dts: kirkwood: set default pinctrl for I2C1 on 6282 ARM: dts: kirkwood: set default pinctrl for I2C0 ARM: dts: kirkwood: set default pinctrl for NAND ARM: dts: kirkwood: set default pinctrl for SPI0 ARM: dts: kirkwood: set default pinctrl for UART0/1 ARM: dts: kirkwood: set default pinctrl for GBE1 ARM: dts: kirkwood: consolidate common pinctrl settings ARM: dts: kirkwood: add pinctrl node to common SoC include ARM: dts: kirkwood: rename pin-controller nodes ARM: dts: kirkwood: remove clock-frequency properties from UART nodes ARM: dts: kirkwood: add stdout-path property to all boards ARM: dts: kirkwood: add node labels ARM: mvebu: Enable the thermal sensor in Armada 380/385 SoC ARM: mvebu: Enable the thermal sensor in Armada 375 SoC ARM: mvebu: don't use clocks property in UART node for Netgear RN2120 ... Signed-off-by: Olof Johansson <olof@lixom.net>
2014-05-05ARM: dts: kirkwood: set default pinctrl for SPI0Sebastian Hesselbarth
Most Kirkwood boards use the default SPI0 pinctrl setting anyway. Add a default pinctrl setting to the toplevel SoC SPI0 node and put a note in front of the corresponding pinctrl node to overwrite the setting on board level. Currently, only T5325 is using a different setting and already overwrites the corresponding pinctrl node. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1398862602-29595-11-git-send-email-sebastian.hesselbarth@gmail.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-05-05ARM: dts: kirkwood: rename pin-controller nodesSebastian Hesselbarth
To prepare pin-controller consolidation, first rename all pinctrl nodes to a more appropriate name regarding ePAPR recommended names. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1398862602-29595-6-git-send-email-sebastian.hesselbarth@gmail.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-05-05ARM: dts: kirkwood: add stdout-path property to all boardsSebastian Hesselbarth
ePAPR allows to reference the device used for console output by stdout-path property. With node labels for Kirkwood UART0, now reference it on all Kirkwood boards that already have ttyS0 in their bootargs property. While at it, fix some whitespace issues on mplcec4's chosen node (there are more, but we only fix the chosen node now) Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1398862602-29595-4-git-send-email-sebastian.hesselbarth@gmail.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-07ARM: Kirkwood: DT: Add missing vendor prefixAndrew Lunn
Add vendor prefixes to compatible strings where they are missing. Both the I2C and MTD framework ignore the prefix, so adding them has no effect on backwards compatibility. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1395492360-1865-6-git-send-email-andrew@lunn.ch Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-01-24Merge tag 'devicetree-for-3.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: - Add new documents with guidelines for DT binding stability and review process. This is one of the outcomes of Kernel Summit DT discussions - Remove a bunch of device_type usage which is only for OF and deprecated with FDT - Fix a long standing issue with compatible string match ordering - Various minor binding documentation updates * tag 'devicetree-for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: dt-bindings: add rockchip vendor prefix serial: vt8500: Add missing binding document for arch-vt8500 serial driver. dt/bindings: submitting patches and ABI documents DT: Add vendor prefix for Emerging Display Technologies of: add vendor prefixe for EPFL of: add vendor prefix for Gumstix of: add vendor prefix for Ka-Ro electronics GmbH devicetree: macb: Document clock properties dts: bindings: trivial clock bindings doc fixes of: Fix __of_device_is_available check dt/bindings: Remove device_type "serial" from marvell,mv64360-mpsc dt/bindings: remove device_type "network" references dt/bindings: remove users of device_type "mdio" dt/bindings: Remove references to linux,phandle properties dt/bindings: Remove all references to device_type "ethernet-phy" of: irq: Ignore disabled intc's when searching map of: irq: Ignore disabled interrupt controllers OF: base: match each node compatible against all given matches first dt-bindings: add GIC-400 binding
2014-01-16dt/bindings: Remove all references to device_type "ethernet-phy"Grant Likely
The device_type property is deprecated for the flattened device tree and the value "ethernet-phy" has never been defined as having a useful meaning. Neither the kernel nor u-boot depend on it. It should never have appeared in PHY bindings. This patch removes all references to "ethernet-phy" as a device_type value from the documentation and the .dts files. This patch was generated mechanically with the following command and then verified by looking at the diff. sed -i '/"ethernet-phy"/d' `git grep -l '"ethernet-phy"'` Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Kumar Gala <galak@codeaurora.org> Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-12-08ARM: DT: Kirkwood: Use symbolic names from gpio.hAndrew Lunn
Use GPIO_ACTIVE_HIGH and GPIO_ACTIVE_LOW instead of 0 and 1. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-06Merge tag 'boards-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC board updates from Olof Johansson: "Board updates for 3.12. Again, a bit of domain overlap with SoC and DT branches, but most of this is around legacy code and board support. We've found that platform maintainers have a hard time separating all of these out and might move towards fewer branches for next release. - Removal of a number of Marvell Kirkwood board files, since contents is now common and mostly configured via DT. - Device-tree updates for Marvell Dove, including irqchip and clocksource setup. - Defconfig updates. Gotta go somewhere. One new one for Renesas Lager. - New backlight drivers for backlights used on Renesas shmobile platforms. - Removal of Renesas leds driver. - Shuffling of some of the new Broadcom platforms to give room for others in the same mach directory. More in 3.13" * tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits) mmc: sdhci-bcm-kona: Staticize sdhci_bcm_kona_card_event mmc: sdhci-bcm-kona: Remove unneeded version.h inclusion ARM: bcm: Make secure API call optional ARM: DT: binding fixup to align with vendor-prefixes.txt (drivers) ARM: mmc: fix NONREMOVABLE test in sdhci-bcm-kona ARM: bcm: Rename board_bcm mmc: sdhci-bcm-kona: make linker-section warning go away ARM: tegra: defconfig updates ARM: dove: add initial DT file for Globalscale D2Plug ARM: dove: add GPIO IR receiver node to SolidRun CuBox ARM: dove: add common pinmux functions to DT ARM: dove: add cpu device tree node ARM: dove: update dove_defconfig with SI5351, PCI, and xHCI arch/arm/mach-kirkwood: Avoid using ARRAY_AND_SIZE(e) as a function argument ARM: kirkwood: fix DT building and update defconfig ARM: kirkwood: Remove all remaining trace of DNS-320/325 platform code ARM: configs: disable DEBUG_LL in bcm_defconfig ARM: bcm281xx: Board specific reboot code ARM bcm281xx: Turn on socket & network support. ARM: bcm281xx: Turn on L2 cache. ...
2013-08-06ARM: kirkwood: Use the preprocessor on device tree filesEzequiel Garcia
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-07-25ARM: kirkwood: add gigabit ethernet and mvmdio device tree nodesSebastian Hesselbarth
This patch adds mv643xx_eth and mvmdio device tree nodes for DT enabled Kirkwood boards. Phy nodes are also added with reg property set on a per-board basis. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-27arm: kirkwood: dreamplug: move pinmux configs to the right devicesThomas Petazzoni
When the pinmux mechanism was added in Kirkwood, the device driver core was not yet providing the possibility of attaching pinmux configurations to all devices, drivers had to do it explicitly, and not all drivers were doing this. Now that the driver core does that in a generic way, it makes sense to attach the pinmux configuration to their corresponding devices. This allows the pinctrl subsystem to show in debugfs to which device is related which pins, for example: pin 41 (PIN41): gpio-leds.1 mvebu-gpio:41 function gpio group mpp41 pin 42 (PIN42): gpio-leds.1 mvebu-gpio:42 function gpio group mpp42 pin 43 (PIN43): gpio-leds.1 mvebu-gpio:43 function gpio group mpp43 Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-15ARM: mvebu: Use standard MMC binding for all users of mvsdioSimon Baatz
In order to prepare the switch to the standard MMC device tree parser for mvsdio, adapt all current uses of mvsdio in the dts files to the standard format. Signed-off-by: Simon Baatz <gmbnomis@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-03-08ARM: kirkwood: of_serial: fix clock gating by removing clock-frequencyJason Cooper
When DT support for kirkwood was first introduced, there was no clock infrastructure. As a result, we had to manually pass the clock-frequency to the driver from the device node. Unfortunately, on kirkwood, with minimal config or all module configs, clock-frequency breaks booting because of_serial doesn't consume the gate_clk when clock-frequency is defined. The end result on kirkwood is that runit gets gated, and then the boot fails when the kernel tries to write to the serial port. Fix the issue by removing the clock-frequency parameter from all kirkwood dts files. Booted on dreamplug without earlyprintk and successfully logged in via ttyS0. Reported-by: Simon Baatz <gmbnomis@gmail.com> Tested-by: Simon Baatz <gmbnomis@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28arm: kirkwood: dreamplug: use Device Tree to probe SDIOThomas Petazzoni
Now that the mvsdio driver has a Device Tree binding, and the SDIO controller is declared in kirkwood.dtsi, migrate the dreamplug board to use the Device Tree to probe the SDIO controller and to mux this interface properly. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-24ARM: Kirkwood: Convert dreamplug to pinctrl.Andrew Lunn
2012-07-27ARM: Kirkwood: Describe Dreamplug LEDs in DT.Andrew Lunn
2012-07-27ARM: Kirkwood: Use DT to configure SATA device.Andrew Lunn
Convert boards using DT, but the old way of configuring SATA to now use properties in there DT file. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Simon Baatz <gmbnomis@gmail.com>
2012-07-27ARM: kirkwood: use devicetree for SPI on dreamplugMichael Walle
Use the device tree for the SPI driver and partition layout. Signed-off-by: Michael Walle <michael@walle.cc> Signed-off-by: Andrew Lunn <andrew@lunn.ch>
2012-07-25ARM: Kirkwood: Replace mrvl with marvellAndrew Lunn
It has been decided to use marvell, not mrvl, in the compatibility property. Search & replace. Signed-off-by: Andrew Lunn <andrew@lunn.ch>
2012-03-16ARM: kirkwood: fdt: define uart[01] as disabled, enable uart0Jason Cooper
Define both uarts in kirkwood.dtsi as they are common to all kirkwood SoCs. Each board may enable all or none of them, so they are disabled by default. uart0 is enabled for the dreamplug. tclk can vary for each board, so we leave it undefined in the kirkwood dtsi. Each board can then set it as appropriate when enabling the uart. Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-03-16ARM: kirkwood: fdt: use mrvl ticker symbolJason Cooper
Also, use inclusive register size for uart0. Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-02-27ARM: kirkwood: convert uart0 to devicetree.Jason Cooper
This uart is the primary console for the dreamplug. Removed kirkwood_uart0_init() call from board-dt.c. Signed-off-by: Jason Cooper <jason@lakedaemon.net> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-02-27ARM: kirkwood: add dreamplug (fdt) support.Jason Cooper
Initially, copied guruplug-setup.c and did s/guruplug/dreamplug/g. Then, switched to SPI based NOR flash. After talking to Arnd Bergman, chose an incremental approach to adding devicetree support. First, we use the dtb to tell us we are on the dreamplug, then we gradually port over drivers. Driver porting will start with the uart (see next patch), and progress from there. Possibly, spi/flash/partitions will be next. When done, board-dt.c will no longer be dreamplug specific, and dt's can be made for the other kirkwood boards. Signed-off-by: Jason Cooper <jason@lakedaemon.net> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
