The regulator has a reg property so include it in the unit name.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
PCIe has a range property, so the unit name should contain an address.
Make use of the label to enable individual PCIe busses. Also, fixup
the synology dtsi file which added a label pcie2 rather than using the
existing pcie1 label.
Most boards use the default UART0/1 pinctrl setting without RTS/CTS.
Add the pinctrl setting to the toplevel SoC UART nodes and put a note
in front of the corresponding pinctrl node to overwrite the setting
on board level. Currently, both boards using a different UART pinctrl
setting (Openblocks A6, A7) already overwrite the pinctrl node.
While at it, also fix up some status = "ok" to "okay" and again
whitespace issues on mplcec4 uart nodes.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lkml.kernel.org/r/1398862602-29595-10-git-send-email-sebastian.hesselbarth@gmail.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
To prepare pin-controller consolidation, first rename all pinctrl nodes
to a more appropriate name regarding ePAPR recommended names.
Link: https://lkml.kernel.org/r/1398862602-29595-6-git-send-email-sebastian.hesselbarth@gmail.com
ePAPR allows to reference the device used for console output by
stdout-path property. With node labels for Kirkwood UART0, now
reference it on all Kirkwood boards that already have ttyS0 in
their bootargs property.
While at it, fix some whitespace issues on mplcec4's chosen node
(there are more, but we only fix the chosen node now)
Link: https://lkml.kernel.org/r/1398862602-29595-4-git-send-email-sebastian.hesselbarth@gmail.com
Use GPIO_ACTIVE_HIGH and GPIO_ACTIVE_LOW instead of 0 and 1.
Replace the numeric key value with a symbolic name from
<bt-bindings/input/input.h>
Almost all hardware parts of the NETGEAR ReadyNAS NV+ v2 ([1] for more
details) are supported by mainline kernel. The only missing elements in
provided .dts file are:
- the front LCD module (Winstar WINSTAR WH1602): driver development is
ongoing. This is the same LCD module as on ReadyNAS 104.
- the Macronix MX25L512 512Kbit SPI flash: no time to play with it yet.
The device is the big brother (4 vs 2 bay) of the ReadyNAS Duo v2. The
main differences are some additional LEDs for the disks, a Marvell
88SM4140 SATA Port multiplier (no driver required to access the disk)
and previously described LCD module. Otherwise, it shares the same SoC
(kirkwood 88F6282), RAM (256MB), NAND (128MB), RTC chip (Ricoh rs5c372a),
fan controller (GMT G762), XHCI controller (NEC/Renesas µPD720200).
[1]: http://natisbad.org/NAS5/
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
