path: root/arch/arm/boot/dts/kirkwood-nsa3x0-common.dtsi
2014-06-02Merge tag 'dt-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next Pull ARM SoC devicetree updates from Olof Johansson: "As with previous release, this continues to be among the largest branches we merge, with lots of new contents. New things for this release are among other things: - DTSI contents for the new SoCs supported in 3.16 (see SoC pull request) - Qualcomm APQ8064 and APQ8084 SoCs and eval boards - Nvidia Jetson TK1 development board (Tegra T124-based) Two new SoCs that didn't need enough new platform code to stand out enough for me to notice when writing the SoC tag, but that adds new DT contents are: - TI DRA72 - Marvell Berlin 2Q" * tag 'dt-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (500 commits) ARM: dts: add secure firmware support for exynos5420-arndale-octa ARM: dts: add pmu sysreg node to exynos3250 ARM: dts: correct the usb phy node in exynos5800-peach-pi ARM: dts: correct the usb phy node in exynos5420-peach-pit ARM: dts: add dts files for exynos5410 and exynos5410-smdk5410 ARM: dts: add dts files for exynos3250 SoC ARM: dts: add mfc node for exynos5800 ARM: dts: add Vbus regulator for USB 3.0 on exynos5800-peach-pi ARM: dts: enable fimd for exynos5800-peach-pi ARM: dts: enable display controller for exynos5800-peach-pi ARM: dts: enable hdmi for exynos5800-peach-pi ARM: dts: add dts file for exynos5800-peach-pi board ARM: dts: add dts file for exynos5800 SoC ARM: dts: add dts file for exynos5260-xyref5260 board ARM: dts: add dts files for exynos5260 SoC ARM: dts: update watchdog node name in exynos5440 ARM: dts: use key code macros on Origen and Arndale boards ARM: dts: enable RTC and WDT nodes on Origen boards ARM: dts: qcom: Add APQ8084-MTP board support ARM: dts: qcom: Add APQ8084 SoC support ...
2014-05-05ARM: dts: kirkwood: rename pin-controller nodesSebastian Hesselbarth
To prepare pin-controller consolidation, first rename all pinctrl nodes to a more appropriate name regarding ePAPR recommended names. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Link: https://lkml.kernel.org/r/1398862602-29595-6-git-send-email-sebastian.hesselbarth@gmail.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-24ARM: kirkwood: rename kirwood-nsa310-common to 3x0-commonAdam Baker
Rename the include file kirkwood-nsa310-common.dtsi as it is now also used for NSA320. There is also an NSA325 but that appears not to be as similar so is unlikely to want to share an include file. Signed-off-by: Adam Baker <linux@baker-net.org.uk> Link: https://lkml.kernel.org/r/53447978.2020206@baker-net.org.uk Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
