Follow the recent trend for the license description
Acked-by: Jason Cooper <jason@lakedaemon.net>
Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
Fix dtc warnings for 'simple_bus_reg' due to leading 0s. Converted using
the following command:
perl -p -i -e 's/\@0+([0-9a-f])/\@$1/g' `find arch/arm/boot/dts -type -f -name '*.dts*'
Dropped changes to ARM, Ltd. boards LED nodes and manually fixed up some
occurrences of uppercase hex.
Signed-off-by: Rob Herring <robh@kernel.org>
PCIe has a range property, so the unit name should contain an address.
Make use of the label to enable individual PCIe busses. Also, fixup
the synology dtsi file which added a label pcie2 rather than using the
existing pcie1 label.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Starting with commit 8947e396a829 ("Documentation: dt: mtd: replace
"nor-jedec" binding with "jedec, spi-nor"") we have "jedec,spi-nor"
binding indicating support for JEDEC identification.
Use it for all flashes that are supposed to support READ ID op according
to the datasheets.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
As reported by Andrew, the vendor prefix for Seiko Instruments, Inc.
S-35390A I2C RTC chip in kirkwood-synology.dtsi has a typo (ssi
instead of sii). This patches fixes it.
Note: i2c devices ignore the optional vendor prefix, which explains
why it worked with the typo and also why there is no backward
compatibility issues with the fix.
Reported-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
Link: https://lkml.kernel.org/r/0444140a267d982c3e5f5f2b7b5f2dc41d010e2a.1416613429.git.arno@natisbad.org
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
There is only one valid pinctrl setting for I2C0 on Kirkwood. Now that we
have the setting in the common SoC pinctrl, move it to the I2C0 controller
node directly and remove it from the individual boards.
While at it, also fix up status = "okay" to "ok" on one board's I2C0 node.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Link: https://lkml.kernel.org/r/1398862602-29595-13-git-send-email-sebastian.hesselbarth@gmail.com
Most Kirkwood boards use the default SPI0 pinctrl setting anyway. Add a
default pinctrl setting to the toplevel SoC SPI0 node and put a note
in front of the corresponding pinctrl node to overwrite the setting
on board level.
Currently, only T5325 is using a different setting and already
overwrites the corresponding pinctrl node.
Link: https://lkml.kernel.org/r/1398862602-29595-11-git-send-email-sebastian.hesselbarth@gmail.com
Most boards use the default UART0/1 pinctrl setting without RTS/CTS.
Add the pinctrl setting to the toplevel SoC UART nodes and put a note
on board level. Currently, both boards using a different UART pinctrl
setting (Openblocks A6, A7) already overwrite the pinctrl node.
While at it, also fix up some status = "ok" to "okay" and again
whitespace issues on mplcec4 uart nodes.
Link: https://lkml.kernel.org/r/1398862602-29595-10-git-send-email-sebastian.hesselbarth@gmail.com
To prepare pin-controller consolidation, first rename all pinctrl nodes
to a more appropriate name regarding ePAPR recommended names.
Link: https://lkml.kernel.org/r/1398862602-29595-6-git-send-email-sebastian.hesselbarth@gmail.com
Add device tree fragments and files to support many of the kirkwood
based Synology NAS devices. This is a modification of
Andrew Lunn's <andrew@lunn.ch> translation of the board setup file
maintained by Ben Peddell <klightspeed@killerwolves.net>
The Ricoh RS5C372 RTC was used in all 2009 units and some 2010 units.
All other Synology Kirkwood-based DiskStations and RackStations use
the Seiko S35390A RTC.
Most of the 1-bay and 2-bay units use the GPIOs that are multiplexed
with the built-in SATA interface activity/presence pins on mpp 20-23,
while the 4-bay units use ge01 and a PCIe SATA controller, and put the
software controlled HDD leds on mpp 36-43.
Most of the 6281 units with HDD power controls use mpp 29 and 31, while
most of the 6282 units with HDD power controls use mpp 30, 34, 44 and 45
and provide a model ID on mpp 28, 29, 46 and 47. Pre-2012 units and
most 4-bay units didn't have a separate power control for HDD1. These
power controls are presumably to limit startup current from the 12V
brick power supply.
Instead of using separate dtsi files in a synology directory, this
patch uses a single dtsi file containing all of the modules for
these boards, with all of the modules not common to all boards
disabled. The board dts files then enable the appropriate modules for
their boards.
Signed-off-by: Ben Peddell <klightspeed@killerwolves.net>
Tested-by: Ben Peddell <klightspeed@killerwolves.net> (ds211j)
