To prepare pin-controller consolidation, first rename all pinctrl nodes
to a more appropriate name regarding ePAPR recommended names.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lkml.kernel.org/r/1398862602-29595-6-git-send-email-sebastian.hesselbarth@gmail.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Use GPIO_ACTIVE_HIGH and GPIO_ACTIVE_LOW instead of 0 and 1.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Replace the numeric key value with a symbolic name from
<bt-bindings/input/input.h>
kirkwood_setup_wins is the last manual caller of mbus in kirkwood, don't
call it for DT boards and rely on the DT having a mbus node with
a proper ranges property to setup these windows.
Move all the mbus ranges properties for all boards into kirkwood.dtsi,
since they are currently all the same.
This makes the DT self consistent, since the physical address of the
NAND and CRYPTO are both referenced internally. The arbitary Linux
constants KIRKWOOD_NAND_MEM_PHYS_BASE and KIRKWOOD_SRAM_PHYS_BASE
no longer have to match the DT values.
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Pull ARM SoC board updates from Olof Johansson:
"Board updates for 3.12. Again, a bit of domain overlap with SoC and
DT branches, but most of this is around legacy code and board support.
We've found that platform maintainers have a hard time separating all
of these out and might move towards fewer branches for next release.
- Removal of a number of Marvell Kirkwood board files, since contents
is now common and mostly configured via DT.
- Device-tree updates for Marvell Dove, including irqchip and
clocksource setup.
- Defconfig updates. Gotta go somewhere. One new one for Renesas
Lager.
- New backlight drivers for backlights used on Renesas shmobile
platforms.
- Removal of Renesas leds driver.
- Shuffling of some of the new Broadcom platforms to give room for
others in the same mach directory. More in 3.13"
* tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits)
mmc: sdhci-bcm-kona: Staticize sdhci_bcm_kona_card_event
mmc: sdhci-bcm-kona: Remove unneeded version.h inclusion
ARM: bcm: Make secure API call optional
ARM: DT: binding fixup to align with vendor-prefixes.txt (drivers)
ARM: mmc: fix NONREMOVABLE test in sdhci-bcm-kona
ARM: bcm: Rename board_bcm
mmc: sdhci-bcm-kona: make linker-section warning go away
ARM: tegra: defconfig updates
ARM: dove: add initial DT file for Globalscale D2Plug
ARM: dove: add GPIO IR receiver node to SolidRun CuBox
ARM: dove: add common pinmux functions to DT
ARM: dove: add cpu device tree node
ARM: dove: update dove_defconfig with SI5351, PCI, and xHCI
arch/arm/mach-kirkwood: Avoid using ARRAY_AND_SIZE(e) as a function argument
ARM: kirkwood: fix DT building and update defconfig
ARM: kirkwood: Remove all remaining trace of DNS-320/325 platform code
ARM: configs: disable DEBUG_LL in bcm_defconfig
ARM: bcm281xx: Board specific reboot code
ARM bcm281xx: Turn on socket & network support.
ARM: bcm281xx: Turn on L2 cache.
Now that mbus has been added to the device tree, it's possible to
move the PCIe nodes out of the ocp node, placing it directly
below the mbus. This is a more accurate representation of the hardware.
Moving the PCIe nodes, we now need to introduce an extra cell to
encode the window target ID and attribute. Since this depends on
the PCIe port, we split the ranges translation entries, to
correspond to each MBus window.
In addition, we encode the PCIe memory and I/O apertures in the MBus
node, according to the MBus DT binding specification. The choice made
is 0xe0000000-0xf0000000 for memory space, and 0xf200000-0xf2100000 for
I/O space. These apertures can be changed in each per-board DT file.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Tested-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
This patch adds mv643xx_eth and mvmdio device tree nodes for DT enabled
Kirkwood boards. Phy nodes are also added with reg property set on a
per-board basis.
Pull ARM SoC device tree changes from Arnd Bergmann:
"These changes from 30 individual branches for the most part update
device tree files, but there are also a few source code changes that
have crept in this time, usually in order to atomically move over a
driver from using hardcoded data to DT probing.
A number of platforms change their DT files to use the C preprocessor,
which is causing a bit of churn, but that is hopefully only this once"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (372 commits)
ARM: at91: dt: rm9200ek: add spi support
ARM: at91: dt: rm9200: add spi support
ARM: at91/DT: at91sam9n12: add SPI DMA client infos
ARM: at91/DT: sama5d3: add SPI DMA client infos
ARM: at91/DT: fix SPI compatibility string
ARM: Kirkwood: Fix the internal register ranges translation
ARM: dts: bcm281xx: change comment to C89 style
ARM: mmc: bcm281xx SDHCI driver (dt mods)
ARM: nomadik: add the new clocks to the device tree
clk: nomadik: implement the Nomadik clocks properly
ARM: dts: omap5-uevm: Provide USB Host PHY clock frequency
ARM: dts: omap4-panda: Fix DVI EDID reads
ARM: dts: omap4-panda: Add USB Host support
arm: mvebu: enable mini-PCIe connectors on Armada 370 RD
ARM: shmobile: irqpin: add a DT property to enable masking on parent
ARM: dts: AM43x EPOS EVM support
ARM: dts: OMAP5: Add bandgap DT entry
ARM: dts: AM33XX: Add pinmux configuration for CPSW to am335x EVM
ARM: dts: AM33XX: Add pinmux configuration for CPSW to EVMsk
ARM: dts: AM33XX: Add pinmux configuration for CPSW to beaglebone
Enable the second PCIe port on QNAP TS-11x/TS-21x devices as newer
revisions (rev 1.3) have a USB 3.0 chip from Etron on PCIe port 1.
Now that the PCIe mvebu driver is usable on Kirkwood, use it instead
of the legacy PCIe code, since it allows to describe the PCIe
interfaces in the Device Tree.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
When the pinmux mechanism was added in Kirkwood, the device driver
core was not yet providing the possibility of attaching pinmux
configurations to all devices, drivers had to do it explicitly, and
not all drivers were doing this.
Now that the driver core does that in a generic way, it makes sense to
attach the pinmux configuration to their corresponding devices.
This allows the pinctrl subsystem to show in debugfs to which device
is related which pins, for example:
pin 41 (PIN41): gpio-leds.1 mvebu-gpio:41 function gpio group mpp41
pin 42 (PIN42): gpio-leds.1 mvebu-gpio:42 function gpio group mpp42
pin 43 (PIN43): gpio-leds.1 mvebu-gpio:43 function gpio group mpp43
Tested-By: Andrew Lunn <andrew@lunn.ch>
Make use of the pinctrl driver for configuring all the pins, instead
of using the Orion mpp code.
The two different variants of QNAP TS devices, varying by SoC, put the
GPIO keys on different GPIO lines. Hence we need two different DT
board descriptions, which share the same board-ts219.c file.
Acked-by: Jason Cooper <jason@lakedaemon.net>
