path: root/arch/arm/boot/dts/mpa1600.dts
2014-07-09ARM: at91/dt: mpa1600: define crytals frequenciesAlexandre Belloni
Define Phontech MPA 1600 main and slow crystals frequencies. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: switch to standard GPIO flag defines.Jean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: use #include for all device treesJean-Christophe PLAGNIOL-VILLARD
to prepare the switch to the macro. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-03-21ARM: at91: add MPA 1600 DT boardJoachim Eastwood
Signed-off-by: Joachim Eastwood <manabian@gmail.com> [nicolas.ferre@atmel.com: remove unneeded address-cells and size-cells to gpio-keys] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
