path: root/arch/arm/boot/dts/omap2420.dtsi
2015-03-31ARM: dts: omap24xx: add minimal l4 bus layout with control module supportTero Kristo
This patch creates an l4 / l4-wkup interconnects for omap2420 / omap2430 SoCs, and moves some of the generic peripherals under it. System control module nodes are moved under this new interconnect also, and the SCM clock layout is changed to use the new SCM node as the clock provider. Signed-off-by: Tero Kristo <t-kristo@ti.com>
2014-11-10ARM: dts: OMAP2+: Add #mbox-cells property to all mailbox nodesSuman Anna
The '#mbox-cells' property is added to all the OMAP mailbox nodes. This property is mandatory with the new mailbox framework. Cc: "Benoît Cousson" <bcousson@baylibre.com> Cc: Rob Herring <robh+dt@kernel.org> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Kumar Gala <galak@codeaurora.org> Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-11ARM: dts: OMAP2+: Add sub mailboxes device node informationSuman Anna
The sub-mailbox devices are added to the Mailbox DT nodes on OMAP2420, OMAP2430, OMAP3, AM33xx, AM43xx, OMAP4 and OMAP5 family of SoCs. This data represents the same mailboxes that used to be represented in hwmod attribute data previously. The node name is chosen based on the .name field of omap_mbox_dev_info structure used in the hwmod data. Cc: "Benoît Cousson" <bcousson@baylibre.com> Cc: Rob Herring <robh+dt@kernel.org> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Kumar Gala <galak@codeaurora.org> Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-08-08Merge tag 'dt-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device-tree changes from Olof Johansson: "Unlike the board branch, this keeps having large sets of changes for every release, but that's quite expected and is so far working well. Most of this is plumbing for various device bindings and new platforms, but there's also a bit of cleanup and code removal for things that are moved from platform code to DT contents (some OMAP clock code in particular). There's also a pinctrl driver for tegra here (appropriately acked), that's introduced this way to make it more bisectable. I'm happy to say that there were no conflicts at all with this branch this release, which means that changes are flowing through our tree as expected instead of merged through driver maintainers (or at least not done with conflicts). There are several new boards added, and a couple of SoCs. In no particular order: - Rockchip RK3288 SoC support, including DTS for a dev board that they have seeded with some community developers. - Better support for Hardkernel Exynos4-based ODROID boards. - CCF conversions (and dtsi contents) for several Renesas platforms. - Gumstix Pepper (TI AM335x) board support - TI eval board support for AM437x - Allwinner A23 SoC, very similar to existing ones which mostly has resulted in DT changes for support. Also includes support for an Ippo tablet with the chipset. - Allwinner A31 Hummingbird board support, not to be confused with the SolidRun i.MX-based Hummingboard. - Tegra30 Apalis board support" * tag 'dt-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (334 commits) ARM: dts: Enable USB host0 (EHCI) on rk3288-evb ARM: dts: add rk3288 ehci usb devices ARM: dts: Turn on USB host vbus on rk3288-evb ARM: tegra: apalis t30: fix device tree compatible node ARM: tegra: paz00: Fix some indentation inconsistencies ARM: zynq: DT: Clarify Xilinx Zynq platform ARM: dts: rockchip: add watchdog node ARM: dts: rockchip: remove pinctrl setting from radxarock uart2 ARM: dts: Add missing pinctrl for uart0/1 for exynos3250 ARM: dts: Remove duplicate 'interrput-parent' property for exynos3250 ARM: dts: Add TMU dt node to monitor the temperature for exynos3250 ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250 ARM: dts: cypress,cyapa trackpad is exynos5250-Snow only ARM: dts: max77686 is exynos5250-snow only ARM: zynq: DT: Remove DMA from board DTs ARM: zynq: DT: Add CAN node ARM: EXYNOS: Add exynos5260 PMU compatible string to DT match table ARM: dts: Add PMU DT node for exynos5260 SoC ARM: EXYNOS: Add support for Exynos5410 PMU ARM: dts: Add PMU to exynos5410 ...
2014-07-15ARM: dts: OMAP2+: Add mailbox fifo and user informationSuman Anna
The number of mailbox fifos and users (IP interrupts) are added to the Mailbox DT nodes on OMAP2420, OMAP2430, OMAP3, and OMAP5 family of SoCs through the DT properties "ti,mbox-num-fifos" and "ti,mbox-num-users" properties. This data represents the same data that used to be represented in hwmod attribute data through the .num_fifos and .num_users fields previously. Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-07-02ARM: OMAP2: clock: use DT clock boot if availableTero Kristo
Otherwise legacy boot clock data is used. This patch also includes the clock data files to the base dtsi files. Signed-off-by: Tero Kristo <t-kristo@ti.com>
2014-06-02Merge tag 'dt-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next Pull ARM SoC devicetree updates from Olof Johansson: "As with previous release, this continues to be among the largest branches we merge, with lots of new contents. New things for this release are among other things: - DTSI contents for the new SoCs supported in 3.16 (see SoC pull request) - Qualcomm APQ8064 and APQ8084 SoCs and eval boards - Nvidia Jetson TK1 development board (Tegra T124-based) Two new SoCs that didn't need enough new platform code to stand out enough for me to notice when writing the SoC tag, but that adds new DT contents are: - TI DRA72 - Marvell Berlin 2Q" * tag 'dt-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (500 commits) ARM: dts: add secure firmware support for exynos5420-arndale-octa ARM: dts: add pmu sysreg node to exynos3250 ARM: dts: correct the usb phy node in exynos5800-peach-pi ARM: dts: correct the usb phy node in exynos5420-peach-pit ARM: dts: add dts files for exynos5410 and exynos5410-smdk5410 ARM: dts: add dts files for exynos3250 SoC ARM: dts: add mfc node for exynos5800 ARM: dts: add Vbus regulator for USB 3.0 on exynos5800-peach-pi ARM: dts: enable fimd for exynos5800-peach-pi ARM: dts: enable display controller for exynos5800-peach-pi ARM: dts: enable hdmi for exynos5800-peach-pi ARM: dts: add dts file for exynos5800-peach-pi board ARM: dts: add dts file for exynos5800 SoC ARM: dts: add dts file for exynos5260-xyref5260 board ARM: dts: add dts files for exynos5260 SoC ARM: dts: update watchdog node name in exynos5440 ARM: dts: use key code macros on Origen and Arndale boards ARM: dts: enable RTC and WDT nodes on Origen boards ARM: dts: qcom: Add APQ8084-MTP board support ARM: dts: qcom: Add APQ8084 SoC support ...
2014-05-28Merge branch 'for-v3.16/clk-dt' of https://github.com/t-kristo/linux-pm into ↵Tony Lindgren
omap-for-v3.16/dt-v2
2014-05-28ARM: dts: omap2 clock dataTero Kristo
This patch creates a unique node for each clock in the OMAP2 power, reset and clock manager (PRCM). Signed-off-by: Tero Kristo <t-kristo@ti.com>
2014-04-25ARM: dts: OMAP2: Fix interrupts for OMAP2420 mailboxSuman Anna
The mailbox module is capable of generating two interrupts to MPU in OMAP2420, compared to one in OMAP2430. The second interrupt is to handle interrupts from the additional IVA processor present only on OMAP2420. Move the current common mailbox DT node into the SoC specific files to allow the above differentiation. Also, added back the interrupt-names on OMAP2420, that were previously defined in hwmod data. This fixes regression caused by the recent dropping of hwmod data in favor for defining it in the .dts files. Signed-off-by: Suman Anna <s-anna@ti.com> [tony@atomide.com: updated description] Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-02-28ARM: dts: omap2: Set disabled status for McBSP instances as default statePeter Ujfalusi
In omap2420.dtsi and omap2430.dtsi disable all mcbsp nodes and board dts files can explicitly enable the mcbsp they are using. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-11-15ARM: dts: Fix omap2 specific dtsi files by adding the missing entriesTony Lindgren
Looks like we're missing few entries for omap2 and the drivers have only worked because of the omap hwmod building the devices for the missing entries. Let's fix the missing entries so we don't need to rely on hwmod for the basic data and can then later on remove the duplicate data from hwmod. Otherwise device tree only drivers will not work properly. Cc: "Benoît Cousson" <bcousson@baylibre.com> Cc: devicetree@vger.kernel.org Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-06-18ARM: dts: OMAP2+: Use #include for all device treesFlorian Vaussard
Replace /include/ by #include for OMAP2+ DT, in order to use the C pre-processor, making use of #define features possible. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-04-09ARM: dts: OMAP2+: Identify GPIO banks that are always poweredJon Hunter
Add the "ti,gpio-always-on" property to the appropriate GPIO banks to indicate which banks are always powered and will never lose logic state. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-04-09ARM: dts: OMAP2+: Update DMTIMER compatibility propertyJon Hunter
Update the DMTIMER compatibility property to reflect the register level compatibilty between devices and update the various OMAP/AM timer bindings with the appropriate compatibility string. By doing this we can add platform specific data applicable to specific timer versions to the driver. For example, errata flags can be populated for the timer versions that are impacted. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-04-09ARM: dts: OMAP2+: Add SDMA Audio IPs bindingsSebastien Guiriec
Populate DMA client information for McBSP DMIC and McPDM periperhal on OMAP2+ devices. Signed-off-by: Sebastien Guiriec <s-guiriec@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-04-09ARM: dts: Add OMAP2 gpio bindingsJon Hunter
Add gpios bindings for OMAP2420 and OMAP2430 devices. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-04-09ARM: dts: Add GPMC node for OMAP2, OMAP4 and OMAP5Jon Hunter
Add the device-tree node for GPMC on OMAP2, OMAP4 and OMAP5 devices. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2012-10-29ARM: dts: OMAP: Add counter-32k nodesJon Hunter
Adds the counter-32k timers nodes present in OMAP2/3/4 devices and device-tree binding documentation for OMAP counter-32k. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Signed-off-by: Benoit Cousson <b-cousson@ti.com>
2012-10-29ARM: dts: OMAP: Add timer nodesJon Hunter
Add the 12 GP timers nodes present in OMAP2. Add the 12 GP timers nodes present in OMAP3. Add the 11 GP timers nodes present in OMAP4. Add the 7 GP timers nodes present in AM33xx. Add documentation for timer properties specific to OMAP. Thanks to Vaibhav Hiremath for creating the AM33xx timer nodes. I have modified Vaibhav's original nodes adding information on which timers support a PWM output. V5 changes: - Updated timer register sizes for OMAP2/3/4. - Modified AM335x timer register size to be 1KB instead of 4KB to align with HWMOD. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Acked-Reviewed-&-Tested-By: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Benoit Cousson <b-cousson@ti.com>
2012-10-29ARM: dts: OMAP: Move interrupt-parent to the root node to avoid duplicationBenoit Cousson
The interrupt-parent attribute does not have to be added in each node since the fmwk will check for the parent as well to get it. Create an interrupt-parent for OMAP2, OMAP3, AM33xx and remove the attributes from every nodes that were using it. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Sebastien Guiriec <s-guiriec@ti.com>
2012-09-10arm/dts: Add pinctrl driver entries for omap2/3/4Tony Lindgren
Add pinctrl driver entries for omap2+. These all use the generic pinctrl-single driver for the padconf registers. Cc: devicetree-discuss@lists.ozlabs.org Acked-by: Linus Walleij <linus.walleij@linaro.org> [tony@atomide.com: updated to drop omap2420.dtsi rename changes] Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-07ARM: dts: omap2: Add McBSP entries for OMAP2420 and OMAP2430 SoCPeter Ujfalusi
The McBSP IP within OMAP2420 and 2430 is different we need to create separate dtsi files for them. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Benoit Cousson <b-cousson@ti.com>
