commit 3a2fa775bd1d0579113666c1a2e37654a34018a0 upstream.
Let's fix pinmux address of gpio 170 used by tfp410 powerdown-gpio.
According to the OMAP35x Technical Reference Manual
CONTROL_PADCONF_I2C3_SDA[15:0] 0x480021C4 mode0: i2c3_sda
CONTROL_PADCONF_I2C3_SDA[31:16] 0x480021C4 mode4: gpio_170
the pinmux address of gpio 170 must be 0x480021C6.
The former wrong address broke i2c3 (used by hdmi ddc), resulting in
kernel message:
omap_i2c 48060000.i2c: controller timed out
Fixes: 8cecf52befd7 ("ARM: omap3-beagle.dts: add display information")
Signed-off-by: Carl Frederik Werner <frederik@cfbw.eu>
Pull ARM DT updates from Olof Johansson:
"As always, this tends to be one of our bigger branches. There are
lots of updates this release, but not that many jumps out as something
that needs more detailed coverage. Some of the highlights are:
- DTs for the new Annapurna Labs Alpine platform
- more graphics DT pieces falling into place on Exynos, bridges,
clocks.
- plenty of DT updates for Qualcomm platforms for various IP blocks
- some churn on Tegra due to switch-over to tool-generated pinctrl
data
- misc fixes and updates for Atmel at91 platforms
- various DT updates to add IP block support on Broadcom's Cygnus
platforms
- more updates for Renesas platforms as DT support is added for
various IP blocks (IPMMU, display, audio, etc)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits)
ARM: dts: alpine: add internal pci
Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135."
ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB
ARM: dts: qcom: Add idle state device nodes for 8064
ARM: dts: qcom: Add idle states device nodes for 8084
ARM: dts: qcom: Add idle states device nodes for 8974/8074
ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs
devicetree: bindings: Document qcom,idle-states
devicetree: bindings: Update qcom,saw2 node bindings
dt-bindings: Add #defines for MSM8916 clocks and resets
arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree
arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes
arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes
arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974
arm: dts: qcom: Add LCC nodes
arm: dts: qcom: Add TCSR support for MSM8960
arm: dts: qcom: Add TCSR support for MSM8660
arm: dts: qcom: Add TCSR support for IPQ8064
The coresight-default-sink configuration option has been
removed from the framework. As such remove it from DT and bindings.
Signed-off-by: Kaixu Xia <xiakaixu@huawei.com>
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
ti,codec property is not used (parsed) in omap-twl4030 driver. The ti,twl4030-audio
which ti,codec points by phandle is mfd driver and device for ASoC codec is created
w/o DT compatible string. Removing all references in DT files.
Signed-off-by: Marek Belisko <marek@goldelico.com>
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
The beagle board contains a 16-bit NAND device connected to
chip select 0 of the GPMC controller.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Currently supporting ETM and ETB. Support for TPIU
and SDTI are yet to be added.
For device tree based booting, we need to use wake-up
interrupts like we already do for some omaps. This fixes
a PM regression on beagleboard compared to legacy booting.
Tested-by: Tero Kristo <t-kristo@ti.com>
Add DT data for OMAP3 Beagle board. The board has the following displays:
dvi: uses TFP410 encoder to convert DPI to DVI
tv: analog svideo
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
In omap3.dtsi disable all mcbsp nodes and board dts files can explicitly
enable the mcbsp they are using.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
The omap3_pmx_core pinmux device in the device tree handles the system
controller module (SCM) PADCONFS fonction. Its control registers are
split in two distinct areas, with other SCM registers in-between. Those
other registers can't thus be requested by other drivers as the memory
region gets reserved by the pinmux driver.
Split the omap3_pmx_core device tree node in two for the two memory
regions. The second region address and size depends on the SoC model.
The change in omap3.dtsi fixes an "external abort on non-linefetch" when
doing
cat /sys/kernel/debug/pinctrl/.../pins
on a Nokia N900.
Note that the core2 padconf region is different for 3430 vs 3630,
and does not exist on 3517 as noted by Nishanth Menon <nm@ti.com>.
Reported-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-By: Sebastian Reichel <sre@debian.org>
Signed-off-by: Nishanth Menon <nm@ti.com>
[tony@atomide.com: updated for 3430 vs 3630 core2 based on Nishant's patch]
This adds typical McBSP2-TWL4030 audio description to the legacy
Beagle Board.
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
Beagle (rev. C4) and Beagle-XM (all revs) need VAUX2 1.8V supply
for the USB PHY.
As the generic PHY driver can't handle more than one supply
at the moment, we configure this supply to be always on.
This will cause a very small power impact if the USB host subsystem
is not in use, about 76.86 micro-W + LDO power.
Older Beagle boards (prior to C4) don't have VAUX2 connected anywhere,
so there won't be any functional impact on those boards other than
some additional LDO power consumption.
Reported-by: Nishanth Menon <nm@ti.com>
Tested-by: Nishanth Menon <nm@ti.com>
The generic PHY framewrok expects different properties than the
old USB PHY framework. Supply those properties.
Fixes USB OTG port on beagle after the Generic PHY framework was
merged in greg/usb-next. [1]
[1] - https://lkml.org/lkml/2013/9/27/581
Acked-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Benoit Cousson <bcousson@baylibre.com>
Add information about the USB OTG PHY. Without this
the OTG port on beagle will not work.
We no longer need to model the RESET line as a regulator since
the USB phy-nop driver accepts "reset-gpios" property.
Use a common naming scheme "mode0name.modename flags" for the
USB host pins to be consistent.
On most OMAP3 platforms, the twl4030 IRQ line is connected to the
SYS_NIRQ line on OMAP. Add another DTS include file
(twl4030_omap3.dtsi) for boards that hook up the twl4030 this way
to include.
This allows RTC wake from off-mode to work again on OMAP3-based
platforms with twl4030. Tested on 3530/Beagle, 3730/Beagle-xM,
3530/Overo, 3730/Overo-STORM.
Special thanks to Florian Vaussard for suggesting use of preprocessor
feature.
Cc: Florian Vaussard <florian.vaussard@epfl.ch>
Cc: Benoit Cousson <b-cousson@ti.com>
Cc: Nishanth Menon <nm@ti.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
Using the gpio-keys bindings, configure the user button on Beagle
boards. Since the user button is enabled as a wakeup source, also
ensure the GPIO pin is mux'd correctly and has IO ring wakeups enabled,
so it can also wakeup from off mode.
Special thanks to Florian Vaussard for suggesting the preprocessor
feature.
Ensure the console uart (UART3) on these boards is mux'd correctly, and
IO ring wakeup is enabled.
This is needed for serial console wakeups when using DT boot.
Thanks to Florian Vaussard for suggestion to use preprocessor
features.
Using constants for pinctrl allows a better readability, and removes
redundancy with comments.
Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Use standard GPIO constants to enhance the readability of DT GPIOs.
Replace /include/ by #include for OMAP2+ DT, in order to use the
C pre-processor, making use of #define features possible.
Define VDD1 regulator in twl4030 DT and mark it as the supply for the
various OMAP34xx/35xx/36xx/37xx platforms (all use TWL4030 variants with
VDD1 supplying the CPU).
NOTE: This currently will use I2C1 bus communication path to set the
voltage in device tree boot. In the legacy non device tree boot, we
continue to use twl-common.c which bypasses I2C1 bus communication path
and uses I2C4 bus path using OMAP voltage libraries. We should
eventually be able to use I2C4 path once we have voltage regulator for
OMAP which is capable of using the voltage controller/voltage processor
IP blocks.
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Jon Hunter <jon-hunter@ti.com>
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: Keerthy <j-keerthy@ti.com>
Add DT OPP table for OMAP34xx/35xx family of devices. This data is
decoded by OF with of_init_opp_table() helper function.
OPP data here is based on existing opp3xxx_data.c
Since the omap36xx OPP tables would be different from OMAP34xx/35xx,
introduce an new omap34xx.dtsi for 34xx/35xx specific entries and use
existing omap3.dtsi as the common dtsi file for all OMAP3 platforms.
This is in preparation to use generic cpufreq-cpu0 driver for device
tree enabled boot. Legacy non device tree enabled boot continues to
use omap-cpufreq.c and opp3xxx_data.c.
Provide RESET and Power regulators for the USB PHY,
the USB Host port mode and the PHY device.
Also provide pin multiplexer information for USB host
pins.
CC: Benoît Cousson <b-cousson@ti.com>
Add a minimal dts for original OMAP3430/3530 version of the Beagle board. This
version of the Beagle board has 256MB of DDR and features the same TWL4030
power management IC (PMIC) as the Beagle board XM.
Given that the Beagle and Beagle-XM boards use the same PMIC, move the
definition of the VSIM regulator into the TWL4030.dtsi file so that we do not
need to duplicate in the Beagle board dts file.
This has been boot tested on an OMAP3530 Beagle board and verifing that the
SD/MMC interface is working with a SD card.
V2 changes
- Rebased upon of devel-dt
- Corrected copyright date in omap3-beagle.dts file
- Added LED support after verifing that Beagle and Beagle XM have the same LED
configuration
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
The extra serial port is not available on 34xx. And the current
omap3-beagle.dts file is for omap3-beagle-xm.dts as it lists 512MB
of memory.
Please somebody submit a new omap3-beagle.dts for the original 34xx
BeagleBoard after testing it properly.
Cc: devicetree-discuss@lists.ozlabs.org
Add the needed sections to enable audio support on BeagleBoard when booted
with DT blob.
Add the support for D6 and D7 LEDs on Beagle board.
- D6 will be used for heartbeat
- D7 will be used for mmc0
Add device tree properties for twl4030/gpio, according to the
platform data of corresponding boards. This enables the led
connected to LEDB output for both boards, as well as
pullups/pulldowns on GPIO for the BeagleBoard.
Acked-by: Vaibhav Hiremath <hvaibhav@ti.com>
regulators do not have a 'reg' property, hence the regulator@0,
regulator@1 do not make sense. get rid of it.
Reported-by: David Brown <davidb@codeaurora.org>
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
This patches fixes some status = "disable" strings to "disabled", the correct
way of disabling nodes in the devicetree.
Just the OMAP part here, the rest goes via other patches and trees.
Signed-off-by: Roland Stigge <stigge@antcom.de>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Acked-by: Benoit Cousson <b-cousson@ti.com>
This patch unifies the current DT MMC bindings documentation and code,
adds generic MMC DT bindings documentation, and updates .dts files for
consistency.
[cjb: typo fixes, addition of max-frequency property]
Signed-off-by: Chris Ball <cjb@laptop.org>
Add OMAP mmc related device tree data for OMAP3.
Currenly limited to only omap3-beagle board.
Pass all the voltage regulator information for
twl6030/twl4030 PMIC from device tree.
Add required clock frequencies for the i2c client devices existing
on beagle board.
Add the twl4030 basic description with only the twl_rtc module.
Add the EEPROM node.
Based on original patch from Manju:
http://www.spinics.net/lists/linux-omap/msg55831.html
Since 3.2, the CONFIG_ARM_ATAG_DTB_COMPAT config allows
an old bootloader to still use ATAG to provide cmdline.
Remove chosen/bootargs from the DTS board files.
Cc: Grant Likely <grant.likely@secretlab.ca>
Add OMAP3 beagleboard DTS file to use the omap3.dtsi SoC file.
Add a default bootargs line to allow a boot from RAMDISK.
Add memory node information.
Cc: G, Manjunath Kondaiah <manjugk@ti.com>
