path: root/arch/arm/boot/dts/omap3-igep0030-rev-g.dts
2015-10-20ARM: dts: Update Javier Martinez Canillas's emailJavier Martinez Canillas
I see that people are still sending emails to my old address (that no longer exists) since is the one mentioned in the IGEP DTS. Replace it with my current email address to avoid this. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-03-24ARM: dts: add wl12xx/wl18xx bindingsEliad Peller
Replace all the pdata-quirks for setting wl12xx/wl18xx platform data with proper DT definitions. Signed-off-by: Eliad Peller <eliad@wizery.com> Acked-by: Javier Martinez Canillas <javier@dowhile0.org> Acked-by: Enric Balletbo i Serra <eballetbo@gmail.com> Tested-by: Nikita Kiryanov <nikita@compulab.co.il> Tested-by: Tony Lindgren <tony@atomide.com> Acked-by: Kalle Valo <kvalo@codeaurora.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-11-12ARM: dts: omap3-igep0030-rev-g: Support IGEP COM MODULE Rev. GEnric Balletbo i Serra
Add support for the new hardware revision of the IGEP COM MODULE. Basically, the new revision G replaces the old Wifi module for a Wilink8 based module. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Javier Martinez Canillas <javier@dowhile0.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
