path: root/arch/arm/boot/dts/omap3-lilly-a83x.dtsi
2015-10-12ARM: dts: omap3-lilly-a83x: Don't use IRQ level flag for a GPIOJavier Martinez Canillas
The card detect GPIO is using IRQ_TYPE_LEVEL_LOW in the GPIO flag cells but this defined constant is meant to be used for a IRQ and not a GPIO. So instead use GPIO_ACTIVE_LOW that seems to be the original intention. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-10-12ARM: dts: Use defined GPIO constants in flags cell for OMAP2+ boardsJavier Martinez Canillas
Many OMAP2+ DTS are not using the defined constants to express the GPIO polarity. Replace these so the DTS are easier to read. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-07-21ARM: dts: omap3: correct the format of u16 values for tsc2046 nodeFugang Duan
In tsc2046 touch driver, the values such as ti,x-min is defined as a u16 value. the driver use API of_property_read_u16() read the value. For these u16 value, the dts entry should be like: property = /bits/ 16 <0x5000>; This describes the property as a u16 value. Signed-off-by: Fugang Duan <B38611@freescale.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-03-16ARM: dts: omap3: Remove all references to ti,codec propertyMarek Belisko
ti,codec property is not used (parsed) in omap-twl4030 driver. The ti,twl4030-audio which ti,codec points by phandle is mfd driver and device for ASoC codec is created w/o DT compatible string. Removing all references in DT files. Signed-off-by: Marek Belisko <marek@goldelico.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-10-30ARM: dts: Fix wrong GPMC size mappings for omapsTony Lindgren
The GPMC binding is obviously very confusing as the values are all over the place. People seem to confuse the GPMC partition size for the chip select, and the device IO size within the GPMC partition easily. The ranges entry contains the GPMC partition size. And the reg entry contains the size of the IO registers of the device connected to the GPMC. Let's fix the issue according to the following table: Device GPMC partition size Device IO size connected in the ranges entry in the reg entry NAND 0x01000000 (16MB) 4 16550 0x01000000 (16MB) 8 smc91x 0x01000000 (16MB) 0xf smc911x 0x01000000 (16MB) 0xff OneNAND 0x01000000 (16MB) 0x20000 (128KB) 16MB NOR 0x01000000 (16MB) 0x01000000 (16MB) 32MB NOR 0x02000000 (32MB) 0x02000000 (32MB) 64MB NOR 0x04000000 (64MB) 0x04000000 (64MB) 128MB NOR 0x08000000 (128MB) 0x08000000 (128MB) 256MB NOR 0x10000000 (256MB) 0x10000000 (256MB) Let's also add comments to the fixed entries while at it. Acked-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-05-27ARM: dts: omap3 a83x: fix duplicate usb pin configChristoph Fritz
Node usbhshost is supporting pinctrl, so the deprecated quirk call can be removed. Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-05-27ARM: dts: omap3: set mcbsp2 statusChristoph Fritz
This patch fixes audio support for omap3-lilly-a83x. Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-04-18ARM: dts: OMAP2+: remove uses of obsolete gpmc,device-nandJohan Hovold
Remove all remaining uses of gpmc,device-nand that have been added since the property was removed by commit f40739faba8e ("ARM: dts: OMAP2+: Simplify NAND support"). Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-02-28ARM: dts: omap3: Add support for INCOstartec a83x moduleChristoph Fritz
INCOstartec LILLY-A83X module is a TI DM3730xx100 (OMAP3) SoC computer-on-module. This patch adds device tree support for most of its features. Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
