This patch just move content of file omap34xx-hs.dtsi into omap3-tao3530.dts.
There is no code change, patch is just preparation for removing -hs file.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
ti,codec property is not used (parsed) in omap-twl4030 driver. The ti,twl4030-audio
which ti,codec points by phandle is mfd driver and device for ASoC codec is created
w/o DT compatible string. Removing all references in DT files.
Signed-off-by: Marek Belisko <marek@goldelico.com>
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
The GPMC binding is obviously very confusing as the values
are all over the place. People seem to confuse the GPMC partition
size for the chip select, and the device IO size within the GPMC
partition easily.
The ranges entry contains the GPMC partition size. And the
reg entry contains the size of the IO registers of the
device connected to the GPMC.
Let's fix the issue according to the following table:
Device GPMC partition size Device IO size
connected in the ranges entry in the reg entry
NAND 0x01000000 (16MB) 4
16550 0x01000000 (16MB) 8
smc91x 0x01000000 (16MB) 0xf
smc911x 0x01000000 (16MB) 0xff
OneNAND 0x01000000 (16MB) 0x20000 (128KB)
16MB NOR 0x01000000 (16MB) 0x01000000 (16MB)
32MB NOR 0x02000000 (32MB) 0x02000000 (32MB)
64MB NOR 0x04000000 (64MB) 0x04000000 (64MB)
128MB NOR 0x08000000 (128MB) 0x08000000 (128MB)
256MB NOR 0x10000000 (256MB) 0x10000000 (256MB)
Let's also add comments to the fixed entries while at it.
Acked-by: Roger Quadros <rogerq@ti.com>
The Technexion TAO3530 is a OMAP3530 based SOM. This patch adds the
basic support for it as an dtsi file which can be included by
baseboard equipped with this SOM. E.g. the Technexion Thunder
baseboard.
Cc: Thorsten Eisbein <thorsten.eisbein@head-acoustics.de>
Cc: Tapani Utriainen <tapani@technexion.com>
Cc: Tony Lindgren <tony@atomide.com>
