path: root/arch/arm/boot/dts/omap4-var-stk-om44.dts
2014-05-19ARM: dts: Add VAR-SOM-OM44 WLAN nodesJoachim Eastwood
Both the VAR-STK-OM44 and VAR-DVK-OM44 boards comes with the WLAN/BT version of the system on module VAR-SOM-OM44. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-05-19ARM: dts: Add support for OMAP4 Variscite OM44 familyJoachim Eastwood
Add support for VAR-SOM-OM44[1] SODIMM system on module from Variscite. SoM features a OMAP4460, 1GB RAM, Gigabit Ethernet (LAN7500) and optional WLAN/BT. Also add support for VAR-STK-OM44 development board from Variscite. This kit features a VAR-SOM-OM44 and the carrier board VAR-OM44CustomBoard[2]. The VAR-STK-OM44 is the same as VAR-DVK-OM44 but without the LCD display. omap4-var-stk-om44.dts replace the old and very limited omap4-var-som.dts. [1] http://www.variscite.com/products/system-on-module-som/cortex-a9/var-som-om44-cpu-ti-omap-4-omap4460 [2] http://www.variscite.com/products/single-board-computers/var-om44customboard Signed-off-by: Joachim Eastwood <manabian@gmail.com> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
