commit 89a898df87e114952191ab0e061aa18e3c617880 upstream.
commit <7415b0b4c645> ("ARM: dts: omap4: add minimal l4 bus layout
with control module support") moved pbias_regulator dt node
from being a child node of ocp to be the child node of
omap4_padconf_global. After this device for pbias_regulator
is not created.
Fix it by adding "simple-bus" compatible property to
omap4_padconf_global dt node.
Fixes: 7415b0b4c645 ("ARM: dts: omap4: add minimal l4 bus layout
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Pull ARM SoC late changes from Olof Johansson:
"We were expecting to sit on this branch through most of the merge
window since the contents was merged into our tree late, but we ended
up sitting on all of our contents so it can go in with the rest.
The contents here is:
- a large branch of cleanups of the CM/PRM blocks on OMAP.
- a couple of patches plumbing up CM/PRM on OMAP5 and DRA7.
- a branch with DT updates for Freescale i.MX. including some
shuffling from .dts to .dtsi (include) files that causes a little
churn"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (78 commits)
ARM: OMAP2+: Fix booting with configs that don't have MFD_SYSCON
ARM: OMAP4+: control: add support for initializing control module via DT
ARM: dts: dra7: add minimal l4 bus layout with control module support
ARM: dts: omap5: add minimal l4 bus layout with control module support
ARM: OMAP4+: control: remove support for legacy pad read/write
ARM: OMAP4: display: convert display to use syscon for dsi muxing
ARM: dts: omap4: add minimal l4 bus layout with control module support
ARM: dts: am4372: add minimal l4 bus layout with control module support
ARM: dts: am43xx-epos-evm: fix pinmux node layout
ARM: dts: am33xx: add minimal l4 bus layout with control module support
ARM: dts: omap3: add minimal l4 bus layout with control module support
ARM: dts: omap24xx: add minimal l4 bus layout with control module support
ARM: OMAP2+: control: add syscon support for register accesses
ARM: OMAP2+: id: cache omap_type value
ARM: OMAP2+: control: remove API for getting control module base address
ARM: OMAP2+: clock: add low-level support for regmap
ARM: OMAP4+: PRM: get rid of cpu_is_omap44xx calls from interrupt init
ARM: OMAP4+: PRM: setup prm_features from the PRM init time flags
ARM: OMAP2+: CM: move SoC specific init calls within a generic API
ARM: OMAP4+: PRM: determine prm_device_inst based on DT compatibility
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/late
Pull "Clean-up for omap PRCM (Power Reset Clock Management) and interconnects" from Tony Lindgren
Patches originally from Tero Kristo <t-kristo@ti.com>.
This sets gets us into a better position for further clean-up:
- Gets PRCM code closer to being device drivers
- Allows to move the remainig clock code to drivers/clk for v4.2
- Starts enforcing interconnect hierarchy in the SoC specific .dts
files to enforce device drivers are only accesing registers in
the related hardware module
This patchset has seen quite a few revisions but did not come into
mergeable shape until recently. As other patchsets for clock specific
device drivers depend on this, it would be good to get this merged
although it's a bit late for the v4.1 merge window.
Note that as the device entries in the .dts files are moved around,
this is based on earlier non-urgent fixes to avoid a non-trivial
merge conflict.
* tag 'omap-for-v4.1/prcm-dts' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (44 commits)
ARM: OMAP2+: PRM: move SoC specific init calls within a generic API
git://git.infradead.org/users/jcooper/linux into irq/core
irqchip core change for v4.1 (round 3) from Jason Cooper
Purge the gic_arch_extn hacks and abuse by using the new stacked domains
NOTE: Due to the nature of these changes, patches crossing subsystems have
been kept together in their own branches.
- tegra
- Handle the LIC properly
- omap
- Convert crossbar to stacked domains
- kill arm,routable-irqs in GIC binding
- exynos
- Convert PMU wakeup to stacked domains
- shmobile, ux500, zynq (irq_set_wake branch)
- Switch from abusing gic_arch_extn to using gic_set_irqchip_flags
This patch creates the l4_cfg and l4_wkup interconnects for OMAP4, and
moves some of the generic peripherals under it. System control module
support is added to the device tree also, and the existing SCM related
functionality is moved under it.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Reported-by: Tony Lindgren <tony@atomide.com>
OMAP4/5 has been (ab)using the gic_arch_extn to provide
wakeup from suspend, and it makes a lot of sense to convert
this code to use stacked domains instead.
This patch does just this, updating the DT files to actually
reflect what the HW provides.
BIG FAT WARNING: because the DTs were so far lying by not
exposing the WUGEN HW block, kernels with this patch applied
won't have any suspend-resume facility when booted with old DTs,
and old kernels with updated DTs won't even boot.
On a platform with this patch applied, the system looks like
this:
root@bacon-fat:~# cat /proc/interrupts
CPU0 CPU1
16: 0 0 WUGEN 37 gp_timer
19: 233799 155916 GIC 27 arch_timer
23: 0 0 WUGEN 9 l3-dbg-irq
24: 1 0 WUGEN 10 l3-app-irq
27: 282 0 WUGEN 13 omap-dma-engine
44: 0 0 4ae10000.gpio 13 DMA
294: 0 0 WUGEN 20 gpmc
297: 506 0 WUGEN 56 48070000.i2c
298: 0 0 WUGEN 57 48072000.i2c
299: 0 0 WUGEN 61 48060000.i2c
300: 0 0 WUGEN 62 4807a000.i2c
301: 8 0 WUGEN 60 4807c000.i2c
308: 2439 0 WUGEN 74 OMAP UART2
312: 362 0 WUGEN 83 mmc2
313: 502 0 WUGEN 86 mmc0
314: 13 0 WUGEN 94 mmc1
350: 0 0 PRCM pinctrl, pinctrl
406: 35155709 0 GIC 109 ehci_hcd:usb1
407: 0 0 WUGEN 7 palmas
409: 0 0 WUGEN 119 twl6040
410: 0 0 twl6040 5 twl6040_irq_ready
411: 0 0 twl6040 0 twl6040_irq_th
IPI0: 0 1 CPU wakeup interrupts
IPI1: 0 0 Timer broadcast interrupts
IPI2: 95334 902334 Rescheduling interrupts
IPI3: 0 0 Function call interrupts
IPI4: 479 648 Single function call interrupts
IPI5: 0 0 CPU stop interrupts
IPI6: 0 0 IRQ work interrupts
IPI7: 0 0 completion interrupts
Err: 0
Link: https://lkml.kernel.org/r/1426088629-15377-8-git-send-email-marc.zyngier@arm.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
According to the Documentation/devicetree/bindings/dma/dma.txt the
dma-channels and dma-requests property should not have '#'.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Pull ARM SoC DT updates from Arnd Bergmann:
"The DT branch adds a lot of new stuff for additional SoC and board
support. The branch is the largest one and contains 513 out of the
total 972 non-merge arm-soc changesets for 3.19.
Most of the changes are about enabling additional on-chip devices for
existing machines, but there are also an unusual number of new SoC
types being added this time:
- AMLogic Meson8
- ARM Realview in DT mode
- Allwinner A80
- Broadcom BCM47081
- Broadcom Cygnus
- Freescale LS1021A
- Freescale Vybrid 500 series
- Mediatek MT6592, MT8127, MT8135
- STMicroelectronics STiH410
- Samsung Exynos4415
The level of support for the above differs widely, some are just stubs
with nothing more than CPU, memory and a UART, but others are fairly
complete. As usual, these get extended over time.
There are also many new boards getting added, this is the list of
model strings that are showing up in new dts files:
- ARM RealView PB1176
- Altera SOCFPGA Arria 10
- Asus RT-N18U (BCM47081)
- Buffalo WZR-1750DHP (BCM4708)
- Buffalo WZR-600DHP2 (BCM47081)
- Cygnus Enterprise Phone (BCM911360_ENTPHN)
- D-Link DIR-665
- Google Spring
- IGEP COM MODULE Rev. G (TI OMAP AM/DM37x)
- IGEPv2 Rev. F (TI OMAP AM/DM37x)
- LS1021A QDS Board
- LS1021A TWR Board
- LeMaker Banana Pi
- MarsBoard RK3066
- MediaTek MT8127 Moose Board
- MediaTek MT8135 evaluation board
- Mele M3
- Merrii A80 Optimus Board
- Netgear R6300 V2 (BCM4708)
- Nomadik STN8815NHK
- NovaTech OrionLXm
- Olimex A20-OLinuXino-LIME2
- Raspberry Pi Model B+
- STiH410 B2120
- Samsung Monk board
- Samsung Rinato board
- Synology DS213j
- Synology DS414
- TBS2910 Matrix ARM mini PC
- TI AM5728 BeagleBoard-X15
- Toradex Colibri VF50 on Colibri Evaluation Board
- Zynq ZYBO Development Board
Other notable changes include:
- exynos: cleanup of existing dts files
- mvebu: improved pinctrl support for Armada 370/XP
- nomadik: restructuring dts files
- omap: added CAN bus support
- shmobile: added clock support for some SoCs
- shmobile: added sound support for some SoCs
- sirf: reset controller support
- sunxi: continuing the relicensing under dual GPL/MIT
- sunxi: lots of new on-chip device support
- sunxi: working simplefb support (long awaited)
- various: provide stdout-path property for earlycon"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (510 commits)
ARM: dts: rk3288: add arm,cpu-registers-not-fw-configured
Revert "ARM: dts: rockchip: temporarily disable smp on rk3288"
ARM: BCM5301X: Add DT for Buffalo WZR-600DHP2
ARM: BCM5301X: Add DT for Asus RT-N18U
ARM: BCM5301X: Add DT for Buffalo WZR-1750DHP
ARM: BCM5301X: Add DT for Netgear R6300 V2
ARM: BCM5301X: Add buttons for Netgear R6250
ARM: dts: rockchip: Add input voltage supply regulators in pmic for Marsboard
ARM: BCM5301X: Add IRQs to Broadcom's bus-axi in DTS file
arm: dts: zynq: Add Digilent ZYBO board
arm: dts: zynq: Move crystal freq. to board level
doc: dt: vendor-prefixes: Add Digilent Inc
Documentation: devicetree: Fix Xilinx VDMA specification
ARM: dts: rockchip: set FIFO size for SDMMC, SDIO and EMMC on rk3066 and rk3188
ARM: dts: rockchip: add label property for leds on Radxa Rock
ARM: BCM5301X: Add LEDs for Netgear R6250 V1
ARM: BCM5301X: Add Broadcom's bus-axi to the DTS file
ARM: dts: add sysreg phandle to i2c device nodes for exynos
ARM: dts: Remove unused bootargs from exynos3250-rinato
ARM: dts: add board dts file for Exynos3250-based Monk board
RFBI iclk was set to point to hacky "dss_fck", which will be removed.
Instead use "l3_div_ck", which is the proper clock for this. "l3_div_ck"
is the parent of "dss_fck", so the clock rate is the same as previously.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Reviewed-by: Archit Taneja <archit.taneja@gmail.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
The '#mbox-cells' property is added to all the OMAP mailbox
nodes. This property is mandatory with the new mailbox framework.
Cc: "Benoît Cousson" <bcousson@baylibre.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Signed-off-by: Suman Anna <s-anna@ti.com>
"As usual, this is the largest branch, though this time a little under
half of the total changes with 307 individual non-merge changesets.
The largest changes are the addition of new machines, in particular
the Tegra based Chromebook, the Renesas r8a7794 SoC, and DT support
for the old i.MX1 platform.
Other changes include
- at91: various sam9 and sama5 updates
- exynos: much extended Peach Pi/Pit (Chromebook 2) support
- keystone: new peripherals
- meson: added DT for meson6 SoC
- mvebu: new device support for Armada 370/375
- qcom: improved support for IPQ8064 and MSM8x60
- rockchip: much improved support for rk3288
- shmobile: lots of updates all over the place
- sunxi: dts license change
- sunxi: more a23 device support
- vexpress: CLCD DT description"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (308 commits)
ARM: DTS: meson: update DTSI to add watchdog node
ARM: dts: keystone-k2l: fix mdio io start address
ARM: dts: keystone-k2e: fix mdio io start address
ARM: dts: keystone-k2e: update usb1 node for dma properties
ARM: dts: keystone: fix io range for usb_phy0
Revert "Merge tag 'hix5hd2-dt-for-3.18' of git://github.com/hisilicon/linux-hisi into next/dt"
Revert "ARM: dts: hix5hd2: add wdg node"
ARM: dts: add rk3288 i2s controller
ARM: vexpress: Add CLCD Device Tree properties
ARM: bcm2835: add I2S pinctrl to device tree
ARM: meson: documentation: add bindings documentation
ARM: meson: dts: add basic Meson/Meson6/Meson6-atv1200 DTSI/DTS
ARM: dts: mt6589: Change compatible string for GIC
ARM: dts: mediatek: Add compatible property for aquaris5
ARM: dts: mt6589-aquaris5: Add boot argument earlyprintk
ARM: dts: mt6589: Fix typo in GIC unit address
ARM: dts: Build dtb for Mediatek board
ARM: dts: keystone: fix bindings for pcie and usb clock nodes
ARM: dts: keystone: k2l: Fix chip selects for SPI devices
ARM: dts: keystone: add dsp gpio controllers nodes
In order to handle errata I688, a page of sram was reserved by doing a
static iotable map. Now that we use gen_pool to manage sram, we can
completely remove all of these static mappings and use gen_pool_alloc()
to get the one page of sram space needed to implement errata I688.
omap_bus_sync will be NOP until SRAM initialization happens.
Suggested-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
Use drivers/misc/sram.c driver to manage SRAM on all DT only
OMAP platforms (am33xx, am43xx, omap4 and omap5) instead of
the existing private plat-omap/sram.c
Address and size related data is removed from mach-omap2/sram.c
and now passed to drivers/misc/sram.c from DT.
Users can hence use general purpose allocator apis instead of
OMAP private ones to manage and use SRAM.
The sub-mailbox devices are added to the Mailbox DT nodes on
OMAP2420, OMAP2430, OMAP3, AM33xx, AM43xx, OMAP4 and OMAP5
family of SoCs. This data represents the same mailboxes that
used to be represented in hwmod attribute data previously.
The node name is chosen based on the .name field of
omap_mbox_dev_info structure used in the hwmod data.
Provide OMAP3, 4 and OMAP5 with interrupt number for PRM
And for DRA7, provide crossbar number for prm interrupt.
Signed-off-by: Nishanth Menon <nm@ti.com>
The mailbox DT node data has been added for OMAP44xx
devices.
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull OMAP DT fbdev updates from Tomi Valkeinen:
"Here are display related device tree data changes for OMAP. They are
based on an already merged branch to satisfy the dependencies for the
dts file changes.
Add OMAP DT data:
- omap5 display subsystem
- display data for omap5 uEVM board
- am43xx display subsystem
- display data for am43xx ePOS and GP boards (LCD only)
- display data for GTA04 board
- display data for overo board
- display data for duovero-parlor board
- display data for omap3 evm and ldp boards"
* tag 'fbdev-omap-dt-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux:
ARM: omap5.dtsi: Add audio related parameters to hdmi node
ARM: omap4.dtsi: Add audio related parametes to hdmi node
ARM: dts: duovero-parlor: Add HDMI output
ARM: dts: overo: Add support for 3.5'' LCD output
ARM: dts: overo: Add support for 4.3'' LCD output
ARM: dts: overo: Add support for DVI output
ARM: dts: Add LCD panel sharp ls037v7dw01 support for omap3-evm and ldp
ARM: dts: omap3-gta04: Add display support
ARM: dts: omap5-uevm.dts: add display nodes
ARM: dts: omap5-uevm.dts: add tca6424a
ARM: dts: omap5.dtsi: add DSS nodes
ARM: dts: am43x-epos-evm: add LCD data
ARM: dts: am437x-gp-evm: add LCD data
ARM: dts: am4372.dtsi: add DSS information
Adds HDMI audio sDMA properties.
Signed-off-by: Jyri Sarha <jsarha@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next
Pull ARM SoC devicetree updates from Olof Johansson:
"As with previous release, this continues to be among the largest
branches we merge, with lots of new contents.
New things for this release are among other things:
- DTSI contents for the new SoCs supported in 3.16 (see SoC pull request)
- Qualcomm APQ8064 and APQ8084 SoCs and eval boards
- Nvidia Jetson TK1 development board (Tegra T124-based)
Two new SoCs that didn't need enough new platform code to stand out
enough for me to notice when writing the SoC tag, but that adds new DT
contents are:
- TI DRA72
- Marvell Berlin 2Q"
* tag 'dt-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (500 commits)
ARM: dts: add secure firmware support for exynos5420-arndale-octa
ARM: dts: add pmu sysreg node to exynos3250
ARM: dts: correct the usb phy node in exynos5800-peach-pi
ARM: dts: correct the usb phy node in exynos5420-peach-pit
ARM: dts: add dts files for exynos5410 and exynos5410-smdk5410
ARM: dts: add dts files for exynos3250 SoC
ARM: dts: add mfc node for exynos5800
ARM: dts: add Vbus regulator for USB 3.0 on exynos5800-peach-pi
ARM: dts: enable fimd for exynos5800-peach-pi
ARM: dts: enable display controller for exynos5800-peach-pi
ARM: dts: enable hdmi for exynos5800-peach-pi
ARM: dts: add dts file for exynos5800-peach-pi board
ARM: dts: add dts file for exynos5800 SoC
ARM: dts: add dts file for exynos5260-xyref5260 board
ARM: dts: add dts files for exynos5260 SoC
ARM: dts: update watchdog node name in exynos5440
ARM: dts: use key code macros on Origen and Arndale boards
ARM: dts: enable RTC and WDT nodes on Origen boards
ARM: dts: qcom: Add APQ8084-MTP board support
ARM: dts: qcom: Add APQ8084 SoC support
omap-for-v3.16/dt-v2
Booting Linux 3.14 on Pandaboard currently gets the following
message displayed:
smp_twd: clock not found -2
Define "mpu_periphclk" as the twd clock in omap4 dts to avoid this.
Signed-off-by: Gilles Chanteperdrix <gilles.chanteperdrix@xenomai.org>
Acked-by: Tero Kristo <t-kristo@ti.com>
The USB2 PHY driver expects named clocks for wakeup clock
and reference clock. Provide this information for USB2 PHY
nodes in OMAP4 and OMAP5 SoC DTS.
CC: Benoît Cousson <bcousson@baylibre.com>
Reviewed-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
We've had deeper idle states working on omaps for few years now,
but only in the legacy mode. When booted with device tree, the
wake-up events did not have a chance to work until commit
3e6cee1786a1 (pinctrl: single: Add support for wake-up interrupts)
that recently got merged. In addition to that we also needed commit
79d9701559a9 (of/irq: create interrupts-extended property) and
9ec36cafe43b (of/irq: do irq resolution in platform_get_irq) that
are now also merged.
So let's fix the wake-up events for some selected omaps so devices
booted in device tree mode won't just hang if deeper power states
are enabled, and so systems can wake up from suspend to the serial
port event.
Note that there's no longer need to specify the wake-up bit in
the pinctrl settings, the request_irq on the wake-up pin takes
care of that.
Cc: devicetree@vger.kernel.org
Cc: Kevin Hilman <khilman@linaro.org>
Cc: Nishanth Menon <nm@ti.com>
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Tero Kristo <t-kristo@ti.com>
[tony@atomide.com: updated comments, added board LDP]
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: linux-omap@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
Pull MMC updates from Chris Ball:
"MMC highlights for 3.15:
Core:
- CONFIG_MMC_UNSAFE_RESUME=y is now default behavior
- DT bindings for SDHCI UHS, eMMC HS200, high-speed DDR, at 1.8/1.2V
- Add GPIO descriptor based slot-gpio card detect API
Drivers:
- dw_mmc: Refactor SOCFPGA support as a variant inside dw_mmc-pltfm.c
- mmci: Support HW busy detection on ux500
- omap: Support MMC_ERASE
- omap_hsmmc: Support MMC_PM_KEEP_POWER, MMC_PM_WAKE_SDIO_IRQ, (a)cmd23
- rtsx: Support pre-req/post-req async
- sdhci: Add support for Realtek RTS5250 controllers
- sdhci-acpi: Add support for 80860F16, fix 80860F14/SDIO card detect
- sdhci-msm: Add new driver for Qualcomm SDHCI chipset support
- sdhci-pxav3: Add support for Marvell Armada 380 and 385 SoCs"
* tag 'mmc-updates-for-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (102 commits)
mmc: sdhci-acpi: Intel SDIO has broken card detect
mmc: sdhci-pxav3: add support for the Armada 38x SDHCI controller
mmc: sdhci-msm: Add platform_execute_tuning implementation
mmc: sdhci-msm: Initial support for Qualcomm chipsets
mmc: sdhci-msm: Qualcomm SDHCI binding documentation
sdhci: only reprogram retuning timer when flag is set
mmc: rename ARCH_BCM to ARCH_BCM_MOBILE
mmc: sdhci: Allow for irq being shared
mmc: sdhci-acpi: Add device id 80860F16
mmc: sdhci-acpi: Fix broken card detect for ACPI HID 80860F14
mmc: slot-gpio: Add GPIO descriptor based CD GPIO API
mmc: slot-gpio: Split out CD IRQ request into a separate function
mmc: slot-gpio: Record GPIO descriptors instead of GPIO numbers
Revert "dts: socfpga: Add support for SD/MMC on the SOCFPGA platform"
mmc: sdhci-spear: use generic card detection gpio support
mmc: sdhci-spear: remove support for power gpio
mmc: sdhci-spear: simplify resource handling
mmc: sdhci-spear: fix platform_data usage
mmc: sdhci-spear: fix error handling paths for DT
mmc: sdhci-bcm-kona: fix build errors when built-in
Pull OMAP fbdev changes from Tomi Valkeinen:
"This is based on the already pulled fbdev-main changes, and this also
merges .dts branch from Tony Lindgren (which has also been pulled), so
that I was able to add the display related .dts changes.
This contains OMAP related fbdev changes for 3.15. The bulk of the
patches are for adding Device Tree support for OMAP Display Subsystem:
- SoCs: OMAP2/3/4
- Boards: OMAP4 Panda, OMAP4 SDP, OMAP3 Beagle, OMAP3 Beagle-xM,
OMAP3 IGEP0020, OMAP3 N900
- Devices: TFP410 Encoder, tpd12s015 HDMI companion chip, Sony
acx565akm panel, MIPI DSI Command mode panel and HDMI, DVI and
Analog TV connectors"
* tag 'fbdev-omap-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (45 commits)
OMAPDSS: HDMI: fix interlace output
OMAPDSS: add missing __init for dss_init_ports
ARM: OMAP2+: remove pdata quirks for displays
OMAPDSS: remove DT hacks for regulators
Doc/DT: Add DT binding documentation for tpd12s015 encoder
Doc/DT: Add DT binding documentation for TFP410 encoder
Doc/DT: Add DT binding documentation for Sony acx565akm panel
Doc/DT: Add DT binding documentation for MIPI DSI CM Panel
Doc/DT: Add DT binding documentation for HDMI Connector
Doc/DT: Add DT binding documentation for DVI Connector
Doc/DT: Add DT binding documentation for Analog TV Connector
ARM: omap3-n900.dts: add display information
ARM: omap3-igep0020.dts: add display information
ARM: omap3-beagle-xm.dts: add display information
ARM: omap3-beagle.dts: add display information
ARM: omap4-sdp.dts: add display information
Doc/DT: Add DT binding documentation for OMAP DSS
OMAPDSS: acx565akm: Add DT support
OMAPDSS: connector-analog-tv: Add DT support
OMAPDSS: hdmi-connector: Add DT support
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"Changes to existing drivers:
- Use of managed resources - omap, twl4030, ti_am335x_tscadc
- Advanced error handling - omap
- Rework clk management - omap
- Device Tree (re-)work - tc3589x, pm8921, da9055, sec
- IRC management overhaul and !BROKEN - pm8921
- Convert to regmap - ssbi, pm8921
- Use simple power-management ops - ucb1x00
- Include file clean-up - adp5520, cs5535, janz, lpc_ich,
- lpc_sch, max14577, mcp-sa11x0, pcf50633-adc, rc5t583,
rdc321x-southbridge, retu, smsc-ece1099, ti-ssp, ti_am335x_tscadc,
tps65912, vexpress-config, wm8350, ywm8350
- Various bug fixes across the subsystem
- NULL/invalid pointer dereference prevention
- Resource leak mitigation,
- Variable used initialised
- Staticise various containers
- Enforce return value checks
New drivers/supported devices:
- Add support for s2mps14 and s2mpa01 to sec
- Add support for da9063 (v5) to da9063
- Add support for atom-c2000 to gpio-ich
- Add support for come-{mbt10,cbt6,chl6} to kempld
- Add support for da9053 to da9052
- Add support for itco-wdt (v3) and baytrail to lpc_ich
- Add new drivers for tps65218, rtsx_usb, bcm590xx
(Re-)moved drivers:
- twl4030 ==> drivers/iio
- ti-ssp ==> /dev/null"
* tag 'mfd-for-linus-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (103 commits)
mfd: wm5110: Correct default for HEADPHONE_DETECT_1
mfd: arizona: Correct small errors in the DT binding documentation
mfd: arizona: Mark DSP clocking register as volatile
mfd: devicetree: bindings: Add pm8xxx RTC description
mfd: kempld-core: Fix potential hang-up during boot
mfd: sec-core: Fix uninitialized 'regmap_rtc' on S2MPA01
mfd: tps65910: Fix regmap_irq_chip_data leak on mfd_add_devices fail
mfd: tps65910: Fix possible invalid pointer dereference on regmap_add_irq_chip fail
mfd: sec-core: Fix I2C dummy device resource leak on probe failure
mfd: sec-core: Add of_compatible strings for clock MFD cells
mfd: Remove obsolete ti-ssp driver
Documentation: mfd: s2mps11: Describe S5M8767 and S2MPS14 clocks
mfd: bcm590xx: Fix type argument for module device table
mfd: lpc_ich: Add support for Intel Bay Trail SoC
mfd: lpc_ich: Add support for NM10 GPIO
mfd: lpc_ich: Change Avoton to iTCO v3
watchdog: iTCO_wdt: Add support for v3 silicon
mfd: lpc_ich: Add support for iTCO v3
mfd: lpc_ich: Remove lpc_ich_cfg struct use
mfd: lpc_ich: Only configure watchdog or GPIO when present
Pull ARM SoC device tree changes from Arnd Bergmann:
"A large part of the arm-soc patches are nowadays DT changes, adding
support for new SoCs, boards and devices without changing kernel
source. The plan is still to move the devicetree files out of the
kernel tree and reduce the amount of churn going on here, but we keep
finding reasons to delay doing that.
Changes are really all over the place, with little sticking out
particularly. We have contributions from a total of 116 people in
this branch.
Unfortunately, the size of this branch also causes a significant
number of conflicts at the moment, typically when subsystem
maintainers merge patches that change the driver at the same time as
the dts files. In most cases this could be avoided because the dts
changes are supposed to be compatible in both ways, and we are asking
everyone to send ARM dts changes through our tree only"
* tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (541 commits)
dts: stmmac: Document the clocks property in the stmmac base document
dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac.
ARM: STi: stih41x: Add support for the FSM Serial Flash Controller
ARM: STi: stih416: Add support for the FSM Serial Flash Controller
ARM: tegra: fix Dalmore pinctrl configuration
ARM: dts: keystone: use common "ti,keystone" compatible instead of -evm
ARM: dts: k2hk-evm: set ubifs partition size for 512M NAND
ARM: dts: Build all keystone dt blobs
ARM: dts: keystone: Fix control register range for clktsip
ARM: dts: keystone: Fix domain register range for clkfftc1
ARM: dts: bcm28155-ap: leave camldo1 on to fix reboot
ARM: dts: add bcm590xx pmu support and enable for bcm28155-ap
ARM: dts: bcm21664: Add device tree files.
ARM: DT: bcm21664: Device tree bindings
ARM: efm32: properly namespace i2c location property
ARM: efm32: fix unit address part in USART2 device nodes' names
ARM: mvebu: Enable NAND controller in Armada 385-DB
ARM: mvebu: Add support for NAND controller in Armada 38x SoC
ARM: mvebu: Add the Core Divider clock to Armada 38x SoCs
ARM: mvebu: Add a 2 GHz fixed-clock on Armada 38x SoCs
Add DT data for OMAP4 display subsystem, which contains the following
blocks:
dss - the wrapper/glue for the display modules
dispc - display controller
dsi - MIPI DSI encoder (two independent modules)
rfbi - MIPI DBI encoder
venc - analog TV encoder
hdmi - HDMI encoder
Use a meaningful name for the reference clocks so that it indicates the
function.
Update the OMAP4+ USB Host node as well to be in sync with the changes.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
The GPMC clock is derived from l3_ick. The simplest solution is
to reference directly l3_ick to provide the GPMC fck in order to
get correct timings. The real management of the clock is left to
hwmod.
Cc: stable@vger.kernel.org # v3.14+
Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch>
Add the IOMMU nodes for the DSP and IPU subsystems. The MMU
within the IPU sub-system also supports a bus error back
capability, not available on the DSP MMU.
[s-anna@ti.com: IPU bus error back addition]
Add ABB device nodes for OMAP443x family of devices. abb_iva is
populated, but disabled as it is not used on current OMAP443x family,
but the node is used on OMAP446x family. Data is based on OMAP443x
Technical Reference Manual revision AN (April 2013).
ABB device nodes for OMAP4460 device Data is based on OMAP4460
Technical Reference Manual revision Z (April 2013)
[nm@ti.com: co-developer]
Signed-off-by: Andrii.Tseglytskyi <andrii.tseglytskyi@ti.com>
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
The OMAP EHCI and OHCI controllers are not compatible with drivers
other than "ti,ehci-omap" and "ti,ohci-omap3" respectively, so get
rid of the incompatible ids.
CC: Alan Stern <stern@rowland.harvard.edu>
CC: Nishant Menon <nm@ti.com>
CC: Kevin Hilman <khilman@linaro.org>
Add pbias regulator node as a child of system control
module - syscon.
Signed-off-by: Balaji T K <balajitk@ti.com>
Tested-by: Florian Vaussard <florian.vaussard@epfl.ch>
Tested-by: Stefan Roese <sr@denx.de>
Signed-off-by: Chris Ball <chris@printf.net>
git://git.kernel.org/pub/scm/linux/kernel/git/bcousson/linux-omap-dt into omap-for-v3.15/dt
Add craneboard devices
Add more N900 devices
Add am43x-epos-evm and am437x-gp-evm devices
Add OMAP4 DMM devices
arch/arm/boot/dts/am43x-epos-evm.dts
arch/arm/boot/dts/dra7.dtsi
Add Dynamic Memory Manager (DMM) bindings for OMAP4 and OMAP5 and DRA7x devices.
DMM only requires address and irq information.
Add documentation for the DMM bindings.
Originally worked on by Andy Gross <andygro@gmail.com>
Cc: Andy Gross <andygro@gmail.com>
Signed-off-by: Archit Taneja <archit@ti.com>
Signed-off-by: Benoit Cousson <bcousson@baylibre.com>
OMAP34xx, AM3517 and OMAP36xx platforms use dpll1 clock.
OMAP443x, OMAP446x, OMAP447x, OMAP5, DRA7, AM43xx platforms use
dpll_mpu clock.
Latency used is the generic latency defined in omap-cpufreq
driver.
Acked-by: Acked-by: Tero Kristo <t-kristo@ti.com>
Board dts files will need to enable the IP nodes which they are using and
does not have to care about the not used ones (to disable them).
Add a new generic property "#hwlock-cells" to the hwspinlock
DT nodes on OMAP4, OMAP5 and AM33xx. This common property allows
different platform implementations to define the args specifier
length. OMAP implementations will always use a value of 1.
This patch creates a unique node for each clock in the OMAP4 power,
reset and clock manager (PRCM). OMAP443x and OMAP446x have slightly
different clock tree which is taken into account in the data.
Signed-off-by: Mike Turquette <mturquette@linaro.org>
Pull ARM SoC DT updates from Olof Johansson:
"Most of this branch consists of updates, additions and general churn
of the device tree source files in the kernel (arch/arm/boot/dts).
Besides that, there are a few things to point out:
- Lots of platform conversion on OMAP2+, with removal of old board
files for various platforms.
- Final conversion of a bunch of ux500 (ST-Ericsson) platforms as
well
- Some updates to pinctrl and other subsystems. Most of these are
for DT-enablement of the various platforms and acks have been
collected"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (385 commits)
ARM: dts: bcm11351: Use GIC/IRQ defines for sdio interrupts
ARM: dts: bcm: Add missing UARTs for bcm11351 (bcm281xx)
ARM: dts: bcm281xx: Add card detect GPIO
ARM: dts: rename ARCH_BCM to ARCH_BCM_MOBILE (dt)
ARM: bcm281xx: Add device node for the GPIO controller
ARM: mvebu: Add Netgear ReadyNAS 104 board
ARM: tegra: fix Tegra114 IOMMU register address
ARM: kirkwood: add support for OpenBlocks A7 platform
ARM: dts: omap4-panda: add DPI pinmuxing
ARM: dts: AM33xx: Add RNG node
ARM: dts: AM33XX: Add hwspinlock node
ARM: dts: OMAP5: Add hwspinlock node
ARM: dts: OMAP4: Add hwspinlock node
ARM: dts: use 'status' property for PCIe nodes
ARM: dts: sirf: add missed address-cells and size-cells for prima2 I2C
ARM: dts: sirf: add missed cell, cs and dma channel for SPI nodes
ARM: dts: sirf: add missed graphics2d iobg in atlas6 dts
ARM: dts: sirf: add missed chhifbg node in prima2 and atlas6 dts
ARM: dts: sirf: add missed memcontrol-monitor node in prima2 and atlas6 dts
ARM: mvebu: Add the core-divider clock to Armada 370/XP
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt
From Tony Lindgren:
Few device tree changes that fix boot time warnings and
make panda display work with recent u-boot.
* tag 'omap-for-v3.13/dt-fixes-for-merge-window' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
Add the hwspinlock device tree node for OMAP4 family
of SoCs.
Some more dts changes from Benoit Cousson <bcousson@baylibre.com> via
Tony Lindgren:
- Add a lot of N900 nodes
- Add OPP table to OMAP5/DRA7
- Add support for Newflow NanoBone board
- Add i2c aliases
- Add McASP and audio support
- Add reset/idle on init bindings for OMAP
- Add more nodes for AM4272
* tag 'omap-for-v3.13/dt-late' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (42 commits)
ARM: dts: omap5-uevm: Remove pinmux for dmic pins
ARM: dts: omap5-uevm: Correct twl6040 reset GPIO pinmux
ARM: dts: TWL4030: Add power button support
ARM: dts: omap3-n900: Add LP5523 support
ARM: dts: omap3-n900: Add TLV320AIC3X support
ARM: dts: omap3-n900:: Mux RX51_LCD_RESET_GPIO in DTS
ARM: dts: omap3-n900: Add NAND support
ARM: dts: omap3-n900: Specify regulator info
ARM: dts: TWL4030: Add missing regulators
ARM: dts: omap3-n900: Add vibrator device
ARM: dts: omap3-n900: GPIO key definitions
ARM: dts: omap3-n900: Add support for SD cards
ARM: dts: omap3-n900: Add UART support
ARM: dts: omap3-n900: Fix i2c bus speed
ARM: dts: omap3-n900: Add pinctrl for i2c devices
ARM: dts: DRA7: Add CPU OPP table
ARM: dts: OMAP5: Add CPU OPP table
ARM: dts: dra7-evm: add smps123 supply for CPU
ARM: dts: omap5-uevm: add smps123 supply for CPU
Currently, on OMAP5, i2c1 and i2c5 defer probe due to pinctrl
dependencies. This changes the i2c ID each bus is registered with in
i2c-dev interface. As a result of this, many userspace tools break and
there is no consistent manner to fix the same if the i2c dev interface
have no consistent numbering.
Since this could happen for other OMAP derivatives, provide i2c alias
for all OMAP3+ SoCs to allow ordering the i2c devices correctly.
On OMAP we have co-processor IPs, memory controllers,
GPIOs which control regulators and power switches to
PMIC, and SoC internal Bus IPs, some or most of which
should either not be reset or idled or both at init.
(In some cases there are erratas which prevent an IP
from being reset)
Have a way to pass this information from DT.
Update the am33xx/omap4 and omap5 dtsi files with the
new bindings for modules which either should not be
idled. reset or both. A later patch would cleanup the
same information that exists today as part of the hwmod
data files.
From Tony Lindgren:
omap device tree related changes via Benoit Cousson <bcousson@baylibre.com>:
Add the minimal DTS support for DRA7xx based SoC core.
Add the initial support for N900 and gta04 phones.
Enable USB3 on OMAP5 evm board.
Add support for cryto accelerators
Add new IGEP AQUILA board
Add AM33XX EDMA support
Update HSUSB node to use the reset-gpios fmwk
* tag 'omap-for-v3.13/dt-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (58 commits)
ARM: dts: dra7-evm: Add mmc2 node for eMMC support
ARM: dts: dra7-evm: Add mmc1 node for micro-sd support
ARM: dts: omap5-uevm: mark TWL6037 as system-power-controller
ARM: dts: omap3-igep0020: use standard constant for IRQ flags
ARM: dts: omap3-igep0020: Add HS USB Host support
ARM: dts: omap3-igep: Add USB OTG support
ARM: dts: AM33XX beagle black: add pinmux and hdmi node to enable display
ARM: dts: AM33XX: Add LCDC info into am335x-evm
ARM: dts: AM437X: Add DES node
ARM: dts: AM437X: Add AES node
ARM: dts: AM33XX: Fix AES interrupt number
ARM: dts: AM33XX: Add AES data and documentation
ARM: dts: AM33XX: Add SHAM data and documentation
ARM: dts: OMAP4: Add DES3DES node
ARM: dts: OMAP4: Add AES node
ARM: dts: am335x-evm[sdk]: switch mmc1 to 4-bit mode
ARM: dts: am335x-bone-common: correct mux mode for cmd line
ARM: dts: AM33XX: Add support for IGEP AQUILA EXPANSION board.
ARM: dts: AM33XX: Add support for IGEP COM AQUILA
ARM: dts: am335x-boneblack: move fixed regulator to board level
Signed-off-by: Kevin Hilman <khilman@linaro.org>
OMAP4 has an DES3DES module that uses the omap-des crypto driver.
Add DT entries for the same.
Signed-off-by: Joel Fernandes <joelf@ti.com>
