path: root/arch/arm/boot/dts/omap4460.dtsi
2014-03-05ARM: dts: OMAP4: Add device nodes for ABBAndrii.Tseglytskyi
Add ABB device nodes for OMAP443x family of devices. abb_iva is populated, but disabled as it is not used on current OMAP443x family, but the node is used on OMAP446x family. Data is based on OMAP443x Technical Reference Manual revision AN (April 2013). ABB device nodes for OMAP4460 device Data is based on OMAP4460 Technical Reference Manual revision Z (April 2013) [nm@ti.com: co-developer] Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Andrii.Tseglytskyi <andrii.tseglytskyi@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-01-28Merge tag 'clk-for-linus-3.14-part2' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull more clock framework changes from Mike Turquette: "The second half of the clock framework pull requeust for 3.14 is dominated by platform support for Qualcomm's MSM SoCs, DT binding updates for TI's OMAP-ish processors and additional support for Samsung chips. Additionally there are other smaller clock driver changes and several last minute fixes. This pull request also includes the HiSilicon support that depends on the already-merged arm-soc pull request" [ Fix up stupid compile error in the source tree with evil merge - Grumpy Linus ] * tag 'clk-for-linus-3.14-part2' of git://git.linaro.org/people/mike.turquette/linux: (49 commits) clk: sort Makefile clk: sunxi: fix overflow when setting up divided factors clk: Export more clk-provider functions dt-bindings: qcom: Fix warning with duplicate dt define clk: si5351: remove variant from platform_data clk: samsung: Remove unneeded semicolon clk: qcom: Fix modular build ARM: OMAP3: use DT clock init if DT data is available ARM: AM33xx: remove old clock data and link in new clock init code ARM: AM43xx: Enable clock init ARM: OMAP: DRA7: Enable clock init ARM: OMAP4: remove old clock data and link in new clock init code ARM: OMAP2+: io: use new clock init API ARM: OMAP2+: PRM: add support for initializing PRCM clock modules from DT ARM: OMAP3: hwmod: initialize clkdm from clkdm_name ARM: OMAP: hwmod: fix an incorrect clk type cast with _get_clkdm ARM: OMAP2+: clock: use driver API instead of direct memory read/write ARM: OMAP2+: clock: add support for indexed memmaps ARM: dts: am43xx clock data ARM: dts: AM35xx: use DT clock data ...
2014-01-17ARM: dts: omap4 clock dataTero Kristo
This patch creates a unique node for each clock in the OMAP4 power, reset and clock manager (PRCM). OMAP443x and OMAP446x have slightly different clock tree which is taken into account in the data. Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-12-04arm: dts: make OMAP4460 bandgap node to belong to OCPEduardo Valentin
Small fix on representation. Bandgap node belongs to OCP. Cc: "Benoît Cousson" <bcousson@baylibre.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-omap@vger.kernel.org Cc: devicetree@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Suggested-by: Nishanth Menon <nm@ti.com> Signed-off-by: Eduardo Valentin <eduardo.valentin@ti.com>
2013-12-04arm: dts: add cooling properties on omap4460 cpu nodeEduardo Valentin
OMAP4460 devices can reach high temperatures and thus needs to have cpufreq-cooling on systems running on it. This patch adds the required cooling device properties so that cpufreq-cpu0 driver loads the cooling device. Cc: "Benoît Cousson" <bcousson@baylibre.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-omap@vger.kernel.org Cc: devicetree@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Eduardo Valentin <eduardo.valentin@ti.com>
2013-12-04arm: dts: add omap4460 thermal dataEduardo Valentin
This patch changes the dtsi entry on omap4460 to contain the thermal data. This data will enable the passive cooling with CPUfreq cooling device at 100C and the system will do a thermal shutdown at 125C. Cc: "Benoît Cousson" <bcousson@baylibre.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-omap@vger.kernel.org Cc: devicetree@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Eduardo Valentin <eduardo.valentin@ti.com>
2013-06-18ARM: dts: OMAP4460: Add bandgap entry for OMAP4460 devicesEduardo Valentin
Add bandgap devices for OMAP4460 devices. Signed-off-by: Eduardo Valentin <eduardo.valentin@ti.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-06-18ARM: dts: OMAP4/5: Use existing constants for IRQsFlorian Vaussard
Use the constants defined in include/dt-bindings/interrupt-controller/ to enhance readability. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-06-18ARM: dts: OMAP2+: Use #include for all device treesFlorian Vaussard
Replace /include/ by #include for OMAP2+ DT, in order to use the C pre-processor, making use of #define features possible. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-05-08ARM: dts: OMAP4460: Fix CPU OPP voltagesNishanth Menon
commit d16fb25 (ARM: dts: OMAP4460: Add CPU OPP table) introduced wrong OPP voltages per OPP by mistake. Sync the OPP tables with existing OMAP4460 OPP data in arch/arm/mach-omap2/opp4xxx_data.c Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-04-09ARM: dts: OMAP4460: Add CPU OPP tableNishanth Menon
Add DT OPP table for OMAP4460 family of devices. This data is decoded by OF with of_init_opp_table() helper function. OPP data here is based on existing opp4xxx_data.c This is in preparation to use generic cpufreq-cpu0 driver for device tree enabled boot. Legacy non device tree enabled boot continues to use omap-cpufreq.c and opp4xxx_data.c. Signed-off-by: Nishanth Menon <nm@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Jon Hunter <jon-hunter@ti.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Keerthy <j-keerthy@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-04-09ARM: dts: omap4-panda: move generic sections to panda-commonNishanth Menon
PandaBoard, PandaBoard-A4 revisions use OMAP4430. PandaBoard-ES version of the board uses OMAP4460. Move the original panda dts file into a common dtsi used by all panda variants. This allows us to introduce SoC variation for PandaBoard ES without impacting other PandaBoard versions that are supported. As part of this change, since OMAP4460 adds on to OMAP4430, add omap4.dtsi to omap4460.dtsi. Signed-off-by: Nishanth Menon <nm@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Jon Hunter <jon-hunter@ti.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Keerthy <j-keerthy@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-04-09ARM: dts: OMAP2+: Add PMU nodesJon Hunter
Add PMU nodes for OMAP2, OMAP3 and OMAP4460 devices. Please note that the node for OMAP4460 has been placed in a separate header file for OMAP4460, because the node is not compatible with OMAP4430. The node for OMAP4430 is not included because PMU is not currently supported on OMAP4430 due to the absence of a cross-trigger interface driver. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
