path: root/arch/arm/boot/dts/orion5x-lacie-ethernet-disk-mini-v2.dts
2014-04-26ARM: orion5x: keep TODO list in edmini_v2 DTThomas Petazzoni
In preparation to the complete removal of non-DT support for edmini_v2, this commit copies the TODO list of things to support from the old-style board file into the Device Tree of edmini_v2. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: https://lkml.kernel.org/r/1398202002-28530-33-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-26ARM: orion5x: use DT to describe NOR on edmini_v2Thomas Petazzoni
This commit converts the already partially DT-converted edmini_v2 platform to use the Device Tree for NOR flash, using the Device Bus. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: https://lkml.kernel.org/r/1398202002-28530-32-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-26ARM: orion5x: use DT to describe EHCI on edmini_v2Thomas Petazzoni
This commit converts the already partially DT-converted edmini_v2 platform to use the Device Tree for USB. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: https://lkml.kernel.org/r/1398202002-28530-31-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-26ARM: orion5x: use DT to describe I2C devices on edmini_v2Thomas Petazzoni
This commit converts the already partially DT-converted edmini_v2 platform to use the Device Tree for I2C bus and devices. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: https://lkml.kernel.org/r/1398202002-28530-30-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-26ARM: orion5x: convert edmini_v2 to DT pinctrlThomas Petazzoni
This commit converts the already partially DT-converted edmini_v2 platform to use the Device Tree for pinctrl. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: https://lkml.kernel.org/r/1398202002-28530-29-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-26ARM: orion5x: convert to use 'clocks' property for UART controllersThomas Petazzoni
Until the previous commit, the Orion5x clocks were not described in the Device Tree. Now that they are described in the Device Tree, we can replace the manual 'clock-frequency' property in the UART nodes by a nicer 'clocks' reference in those UART nodes. This commit consequently removes the 'clock-frequency' property from the LaCie edmini_v2 board, which is at this point the only Orion5x board converted to the Device Tree. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: https://lkml.kernel.org/r/1398202002-28530-22-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-26ARM: orion5x: use node labels for UART and SATA on edmini_v2Thomas Petazzoni
This commit converts the existing devices described in the edmini_v2 Device Tree to use node labels: the UART and SATA device. Also, it reorders the eth and mdio node label references to be sorted alphabetically. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: https://lkml.kernel.org/r/1398202002-28530-18-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-26ARM: orion5x: add linux,stdout-path to edmini_v2Thomas Petazzoni
This commit adds the new linux,stdout-path to the edmini_v2 platform, pointing to the serial device use for the console. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: https://lkml.kernel.org/r/1398202002-28530-17-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-26ARM: orion5x: use gpio-keys and gpio-leds instead of gpio_keys/gpio_leds in ↵Thomas Petazzoni
edmini_v2 As noted by Sebastian Hesselbarth, the Device Tree nodes for GPIO keys and LEDs should be named gpio-keys and gpio-leds. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: https://lkml.kernel.org/r/1398202002-28530-16-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-26ARM: orion5x: convert DT to use the mvebu-mbus driverThomas Petazzoni
This commit switches the Orion5x Device Tree files to use the DT representation and probing for the mvebu-mbus driver. The changes are mainly: * Re-organize the DT to follow the same organization as the one used on Armada 370/XP, which is needed for mvebu-mbus to work: a top-level soc { ... } node, which corresponds to the MBus bus, and a sub-node internal-regs { ... } for all peripherals whose register sit only in the "Internal Register Window". This change re-indents by one level the definition of all nodes in the Device Tree, which explains the large change. * Use custom functions orion5x_dt_init_early() and orion5x_dt_init_time() instead of orion5x_init_early() and orion5x_timer_init() as we now want the MBus driver to be probed from the Device Tree. We still use the old-style timer initialization, but that will be changed in a followup commit. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: https://lkml.kernel.org/r/1398202002-28530-14-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-26ARM: orion5x: use existing dt-bindings include for Device Tree filesThomas Petazzoni
The orion5x-lacie-ethernet-disk-mini-v2.dts can benefit from using gpio.h and input.h dt-bindings headers to replace hardcoded values by more meaningful macros. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Link: https://lkml.kernel.org/r/1398202002-28530-13-git-send-email-thomas.petazzoni@free-electrons.com Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-26ARM: orion5x: switch to preprocessor includes in DTThomas Petazzoni
This commit switches the Orion5x Device Tree files to use C preprocessor based includes, as it will allow us to use definitions from header files in future commits. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Link: https://lkml.kernel.org/r/1398202002-28530-12-git-send-email-thomas.petazzoni@free-electrons.com Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-01-16dt/bindings: Remove all references to device_type "ethernet-phy"Grant Likely
The device_type property is deprecated for the flattened device tree and the value "ethernet-phy" has never been defined as having a useful meaning. Neither the kernel nor u-boot depend on it. It should never have appeared in PHY bindings. This patch removes all references to "ethernet-phy" as a device_type value from the documentation and the .dts files. This patch was generated mechanically with the following command and then verified by looking at the diff. sed -i '/"ethernet-phy"/d' `git grep -l '"ethernet-phy"'` Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Kumar Gala <galak@codeaurora.org> Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-07-25ARM: orion5x: add gigabit ethernet and mvmdio device tree nodesSebastian Hesselbarth
This patch adds mv643xx_eth and mvmdio device tree nodes for DT enabled Orion5x boards. Phy nodes are also added with reg property set on a per-board basis. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-03-08arm: mach-orion5x: fix typo in compatible string of a .dts fileThomas Petazzoni
The orion5x-lacie-ethernet-disk-mini-v2.dts file was using "marvell-orion5x-88f5182" as a compatible string, while it should have been "marvell,orion5x-88f5182". Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-21arm: orion5x: convert 'LaCie Ethernet Disk mini v2' to Device TreeThomas Petazzoni
This commit converts the 'LaCie Ethernet Disk mini v2' board to the Device Tree. All devices that have existing Device Tree bindings are converted over to the Device Tree, the other devices remain instantiated in the old way, until the respective drivers get the needed Device Tree bindings. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested by: Maxime Hadjinlian <mhadjinlian@lacie.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
