orion-wdt refuses to start without these properties defined, so lift
definitions out of kirkwood/dove.dtsi
[gregory.clement@free-electrons.com: fix commit title]
Signed-off-by: Jamie Lentin <jm@lentin.co.uk>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
The new bindings split the crypto and sram node in two separate devices.
Modify the existing crypto nodes to match the new representation.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
This commit adds the necessary SoC-level Device Tree definitions to
describe the Device Bus of Orion5x SOCs. The Device Bus is mainly used
to connect NOR flashes to the system.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: https://lkml.kernel.org/r/1398202002-28530-27-git-send-email-thomas.petazzoni@free-electrons.com
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
This commit fixes the Orion5x SoC definition to:
* Not define a clock-frequency, as it should be described on a
per-board basis.
* Declare the appropriate clock reference, so that the driver can do
correct divisors calculations for the I2C bus.
Link: https://lkml.kernel.org/r/1398202002-28530-26-git-send-email-thomas.petazzoni@free-electrons.com
This commit switches the Orion5x platforms described through DT to use
a DT-defined interrupt controller and timer.
This involves:
* Describing in the DT the bridge interrupt controller, which is a
child interrupt controller to the main one, which is used for timer
and watchdog interrupts.
* Describing in the DT the timer.
* Adding in the DT the interrupt specifications for the watchdog.
* Selecting the ORION_IRQCHIP and ORION_TIMER drivers to be compiled.
* Change board-dt.c to no longer have an ->init_time() callback,
since the default callback will work fine: it calls
clocksource_of_init() and of_clk_init(), as needed.
* Implement a multi-IRQ handler for non-DT platforms in
mach-orion5x/irq.c.
Link: https://lkml.kernel.org/r/1398202002-28530-24-git-send-email-thomas.petazzoni@free-electrons.com
Until the previous commit, the Orion5x clocks were not described in
the Device Tree. Now that they are described in the Device Tree, we
can replace the manual 'clock-frequency' property in the UART nodes
by a nicer 'clocks' reference in those UART nodes.
This commit consequently removes the 'clock-frequency' property from
the LaCie edmini_v2 board, which is at this point the only Orion5x
board converted to the Device Tree.
Link: https://lkml.kernel.org/r/1398202002-28530-22-git-send-email-thomas.petazzoni@free-electrons.com
For some reason, the Ethernet interrupt was missing in the Orion5x
Device Tree definition.
Link: https://lkml.kernel.org/r/1398202002-28530-20-git-send-email-thomas.petazzoni@free-electrons.com
This commit renames the XOR engine Device Tree node to
dma-controller@, to conform with the standard node name proposed by
the ePAPR.
Suggested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Link: https://lkml.kernel.org/r/1398202002-28530-19-git-send-email-thomas.petazzoni@free-electrons.com
In order to ease identification of devices, it is useful to have
Device Tree labels on all devices. This commit adds such labels to the
Orion5x SoC Device Tree file.
Link: https://lkml.kernel.org/r/1398202002-28530-15-git-send-email-thomas.petazzoni@free-electrons.com
This commit switches the Orion5x Device Tree files to use the DT
representation and probing for the mvebu-mbus driver. The changes are
mainly:
* Re-organize the DT to follow the same organization as the one used
on Armada 370/XP, which is needed for mvebu-mbus to work: a
top-level soc { ... } node, which corresponds to the MBus bus, and
a sub-node internal-regs { ... } for all peripherals whose register
sit only in the "Internal Register Window". This change re-indents
by one level the definition of all nodes in the Device Tree, which
explains the large change.
* Use custom functions orion5x_dt_init_early() and
orion5x_dt_init_time() instead of orion5x_init_early() and
orion5x_timer_init() as we now want the MBus driver to be probed
from the Device Tree. We still use the old-style timer
initialization, but that will be changed in a followup commit.
Link: https://lkml.kernel.org/r/1398202002-28530-14-git-send-email-thomas.petazzoni@free-electrons.com
This commit switches the Orion5x Device Tree files to use C
preprocessor based includes, as it will allow us to use definitions
from header files in future commits.
Link: https://lkml.kernel.org/r/1398202002-28530-12-git-send-email-thomas.petazzoni@free-electrons.com
The interrupt controller node was located outside of the ocp@f1000000
node, which doesn't make much sense: like any other device, the
interrupt controller has registers located in the "Internal Registers
Window", so it is much more logical to have it under the ocp@f1000000
node.
It is even more important as we are going to move Orion5x to use the
Device Tree binding of the mvebu-mbus driver.
Link: https://lkml.kernel.org/r/1398202002-28530-11-git-send-email-thomas.petazzoni@free-electrons.com
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull devicetree updates from Rob Herring:
- Add new documents with guidelines for DT binding stability and review
process. This is one of the outcomes of Kernel Summit DT discussions
- Remove a bunch of device_type usage which is only for OF and
deprecated with FDT
- Fix a long standing issue with compatible string match ordering
- Various minor binding documentation updates
* tag 'devicetree-for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
dt-bindings: add rockchip vendor prefix
serial: vt8500: Add missing binding document for arch-vt8500 serial driver.
dt/bindings: submitting patches and ABI documents
DT: Add vendor prefix for Emerging Display Technologies
of: add vendor prefixe for EPFL
of: add vendor prefix for Gumstix
of: add vendor prefix for Ka-Ro electronics GmbH
devicetree: macb: Document clock properties
dts: bindings: trivial clock bindings doc fixes
of: Fix __of_device_is_available check
dt/bindings: Remove device_type "serial" from marvell,mv64360-mpsc
dt/bindings: remove device_type "network" references
dt/bindings: remove users of device_type "mdio"
dt/bindings: Remove references to linux,phandle properties
dt/bindings: Remove all references to device_type "ethernet-phy"
of: irq: Ignore disabled intc's when searching map
of: irq: Ignore disabled interrupt controllers
OF: base: match each node compatible against all given matches first
dt-bindings: add GIC-400 binding
device_type is deprecated and the kernel doesn't require it in most
cases. The only exceptions for flat tree users are the "gianfar",
"ucc_geth" and "ibm,emac" bindings, and arguably that requirement could
be relaxed for ucc_geth and ibm,emac (that is a task for separate
patches though).
This patch removes references to device_type="network" from the binding
documentation where possible and removes the properties from ARM and
microblaze dts files. This patch does not modify the powerpc .dts files
since there are a much larger number of them affected and I think the
ucc_geth, ibm,emac and gianfar users should be addressed before clearing
out the references to reduce the chance of breakage.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Acked-by: Michal Simek <monstr@monstr.eu>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Prevent future unnecessary merge conflicts
Future irqchip driver for Orion SoCs has a modified reg layout starting
from CAUSE register. The former DT irq driver stub just used what the
non-DT driver wants. Currently, orion5x is not ready for irqchip driver
because of legacy timer and missing DT clk provider. To ease future
conversion and just because orion-intc binding documentation already
reflects new reg layout, we convert orion5x DT now.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
This patch adds mv643xx_eth and mvmdio device tree nodes for DT enabled
Orion5x boards. Phy nodes are also added with reg property set on a
per-board basis.
Pull ARM SoC device-tree updates from Olof Johansson:
"Part 1 of device-tree updates for 3.10. The bulk of the churn in this
branch is due to i.MX moving from C-defined pin control over to device
tree, which is a one-time conversion that will allow greater
flexibility down the road.
Besides that, there's PCI-e bindings for Marvell mvebu platforms and a
handful of cleanups to tegra due to the new include file functionality
of the device tree compiler"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (113 commits)
arm: mvebu: PCIe Device Tree informations for Armada XP GP
arm: mvebu: PCIe Device Tree informations for Armada 370 DB
arm: mvebu: PCIe Device Tree informations for Armada 370 Mirabox
arm: mvebu: PCIe Device Tree informations for Armada XP DB
arm: mvebu: PCIe Device Tree informations for OpenBlocks AX3-4
arm: mvebu: add PCIe Device Tree informations for Armada XP
arm: mvebu: add PCIe Device Tree informations for Armada 370
ARM: sunxi: unify osc24M_fixed and osc24M
arm: vt8500: Add SDHC support to WM8505 DT
ARM: dts: Add a 64 bits version of the skeleton device tree
ARM: mvebu: Add Device Bus and CFI flash memory support to defconfig
ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board
ARM: mvebu: Add support for NOR flash device on Armada XP-GP board
ARM: mvebu: Add Device Bus support for Armada 370/XP SoC
ARM: dts: imx6dl-wandboard: Add USB Host support
ARM: dts: imx51 cpu node
ARM: dts: Add missing imx27-phytec-phycore dtb target
ARM: dts: Add NFC support for i.MX27 Phytec PCM038 module
ARM: i.MX51: Add PATA support
ARM: dts: Add initial support for Wandboard Dual-Lite
The orion5x SoC includes DMA functionality, so lets enable that
and turn it on by default.
Signed-off-by: Alexander Clouter <alex@digriz.org.uk>
The orion5x SoC also includes a USB EHCI componment so lets add that
to the dtsi (disable by default incase the pins are not broken out).
The crypto functionality in the orion5x dtsi uses the Ethernet IRQ and
so things do not work and there is much grumbling at boot time.
The IRQ for the crypto should be 28, and not 22, and that is what this
patch corrects.
Acked-by: Andrew Lunn <andrew@lunn.ch>
orion5x.dtsi is missing the gpio alias as well as including a typo
('ngpio' instead of 'ngpios') that prevented the orion-gpio driver
from loading. Also missing were the interrupt-controller properties.
This patches resolves those glitches.
This commit adds basic DT support for the Orion5x SoC family. It adds
an orion5x.dtsi description of the Orion5x SoC as well as the needed
DT_MACHINE structure to support boards converted to DT in the future.
So far, the Device Tree contains the interrupt controller, the GPIO
bank, the UART controllers, the SPI controller, the watchdog, the SATA
controller, the I2C controller and the cryptographic engine.
Tested by: Maxime Hadjinlian <mhadjinlian@lacie.com>
