path: root/arch/arm/boot/dts/qcom-apq8064-ifc6410.dts
2015-10-13ARM: dts: apq8064-ifc6410: add notify led support.Srinivas Kandagatla
This patch adds notify led support on IFC6410, whose trigger can be configured from userspace. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Andy Gross <agross@codeaurora.org>
2015-10-13ARM: dts: ifc6410: Add pwrseq support for WLANSrinivas Kandagatla
This patch adds pwrseq for WLAN which resets the WLAN just before the SDIO bus is up. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Andy Gross <agross@codeaurora.org>
2015-10-13ARM: dts: ifc6410: Add missing pinctrl to gsbi7 uartSrinivas Kandagatla
This patch adds missing 2pin uart pinctrl property to gsbi7 uart on IFC6410. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Andy Gross <agross@codeaurora.org>
2015-10-13ARM: dts: apq8064: Prefix the gsbi6 uart pins correctlySrinivas Kandagatla
Usage of generic names like "uart_pins" is confusing to the reader, given the fact that there could be more than one uart on APQ8064. This patch adds gsbi prefix to uart pinctrl nodes so as to avoid such confusion. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Andy Gross <agross@codeaurora.org>
2015-10-13ARM: dts: ifc6410: remove unnecessary eeprom labelSrinivas Kandagatla
This patch removes unnecessary eeprom label, which is not used anywhere in the board file. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Andy Gross <agross@codeaurora.org>
2015-10-13ARM: dts: apq8064: remove redundant i2c pinctrl propertiesSrinivas Kandagatla
This patch removes i2c pinctrl properties from board which which are now mentioned in the SOC specific file. This will avoid redundant properties across multiple board fiiles. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Andy Gross <agross@codeaurora.org>
2015-09-09ARM: dts: qcom: apq8064-ifc6410: Use stdout-pathStephen Boyd
Use stdout-path so that we don't have to put the console on the kernel command line. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-07-28ARM: dts: ifc6410: add real regulators for sdcc nodes.Srinivas Kandagatla
This patch adds real regulators for all the three sdcc nodes. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Andy Gross <agross@codeaurora.org>
2015-07-27ARM: dts: apq8064: Add DT support for GSBI6 and for UART pin muxPramod Gurav
This change adds DT support for GSBI6 and muxes the gpio pins as UART lines. Also defines a alias for serial port on these lines. Signed-off-by: Pramod Gurav <pramod.gurav@smartplayin.com> [Srinivas Kandagatla]: fix pinctrl location and rename alias correctly Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Andy Gross <agross@codeaurora.org>
2015-04-27ARM: dts: qcom: apq8064 - add i2c3 node for panel.Srinivas Kandagatla
This patch adds i2c3 node which is used for panel control on IFC6410. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2015-04-27ARM: dts: qcom: apq8064 - Move i2c1 pinctrl to apq8064.dtsiSrinivas Kandagatla
I2C1 pinctrl is not really specific to a board, moving to SOC dtsi would avoid redefining this in every board. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2015-04-27ARM: dts: qcom: apq8064-ifc6410 - Add DT alias for serial portPramod Gurav
Define an alias for serial port present on ifc6410 which is used as console. Signed-off-by: Pramod Gurav <pramod.gurav@smartplayin.com> Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> [Srinivas Kandagatla: renamed the serial0 label appropriately] Reviewed-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2015-04-27ARM: dts: qcom: apq8064 - Add SATA controller supportSrinivas Kandagatla
This patch adds AHCI based SATA controller support to APQ8064. Tested on IFC6410 board. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2015-04-27ARM: dts: qcom: apq8064 - Add USB OTG supportSrinivas Kandagatla
This patch adds USB OTG support on USB1 of APQ8064 SOC. Tested on IFC6410 with ethernet gadget. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2015-04-27ARM: dts: qcom: apq8064 - Add usb host support.Srinivas Kandagatla
This patch adds device tree nodes to support two usb hosts on APQ8064 SOC. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2015-04-27ARM: dts: qcom: apq8064-ifc6410 - Add basic regulatorsSrinivas Kandagatla
This patch adds support to basic regulators wiredup on IFC6410 board. All these regulators are tested as part of USB, SATA and HDMI. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2015-01-19ARM: dts: qcom: Add Support for SD Card Detect for ifc6410 boardPramod Gurav
This changes muxes in gpio26 pin to function as gpio and adds support for sd card detect for apq8064 based IFC6410 board. Cc: Rob Herring <robh+dt@kernel.org> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Kumar Gala <galak@codeaurora.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Pramod Gurav <pramod.gurav@smartplayin.com> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-09-17ARM: DT: apq8064: Add i2c device nodeskiran.padwal@smartplayin.com
This patch adds i2c pinctrl DT node for IFC6410 board. It also adds necessary DT support for i2c eeprom which is present on IFC6410. Signed-off-by: Kiran Padwal <kiran.padwal@smartplayin.com> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-09-17ARM: DT: apq8064: add support to sdcc4 for wlan.Srinivas Kandagatla
This patch adds sdcc4 node to enable wlan support on IFC6410 Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-09-11ARM: DT: apq8064: Add sdcc support via mcci driver.Srinivas Kandagatla
This patch adds support to SD card controller using generic pl180 mmci driver. This patch also adds temporary fixed regulator to get it going till the actual regulator is mainlined. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-05-29ARM: dts: qcom: Add initial APQ8064 SoC and IFC6410 board device treesKumar Gala
Add basic APQ8064 SoC include device tree and support for basic booting on the IFC6410 board. Also, keep dtb build list and qcom_dt_match in sorted order. Signed-off-by: Kumar Gala <galak@codeaurora.org>
