path: root/arch/arm/boot/dts/qcom-apq8064.dtsi
2015-04-03ARM: dts: qcom: Add idle state device nodes for 8064Lina Iyer
Add ARM common idle state device bindings for cpuidle support for APQ 8064. Support Standalone power collapse (SPC) idle state (power down that does not affect any SoC idle states) for each cpu. Signed-off-by: Lina Iyer <lina.iyer@linaro.org> Signed-off-by: Kumar Gala <galak@codeaurora.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-04-03ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUsLina Iyer
Update the SAW2 DT bindings to add qcom,apq8064-saw2-v1.1-cpu compatible binding string to configure SPM registers and allow the SPM to put the core in deeper idle states when the core is idle. Signed-off-by: Lina Iyer <lina.iyer@linaro.org> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Kumar Gala <galak@codeaurora.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-04-03arm: dts: qcom: Add LCC nodesKumar Gala
Add the node for the LPASS clock controller found on a few qcom SoCs so that the clock driver can probe. Signed-off-by: Rajendra Nayak <rnayak@codeaurora.org> Signed-off-by: Kumar Gala <galak@codeaurora.org> [sboyd@codeaurora.org: Added apq8064 and msm8960 nodes] Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Kumar Gala <galak@codeaurora.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-04-03arm: dts: qcom: Add TCSR support for APQ8064Andy Gross
This patch adds TCSR support for use by the GSBI to automatically configure ADM CRCI values based on the GSBI port configuration. Signed-off-by: Andy Gross <agross@codeaurora.org> Signed-off-by: Kumar Gala <galak@codeaurora.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-09-17ARM: DT: apq8064: Add i2c device nodeskiran.padwal@smartplayin.com
This patch adds i2c pinctrl DT node for IFC6410 board. It also adds necessary DT support for i2c eeprom which is present on IFC6410. Signed-off-by: Kiran Padwal <kiran.padwal@smartplayin.com> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-09-17ARM: DT: apq8064: add support to sdcc4 for wlan.Srinivas Kandagatla
This patch adds sdcc4 node to enable wlan support on IFC6410 Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-09-11ARM: DT: QCOM: apq8064: Add dma support for sdcc nodeSrinivas Kandagatla
This patch adds dma support in both sdcc1 and sdcc3 device node. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-09-11ARM: DT: apq8064: Add sdcc support via mcci driver.Srinivas Kandagatla
This patch adds support to SD card controller using generic pl180 mmci driver. This patch also adds temporary fixed regulator to get it going till the actual regulator is mainlined. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-09-11ARM: dts: qcom: Add 8064 multimedia clock controller nodeStephen Boyd
Add the mmcc node so that we can probe and use the multimedia clocks on apq8064. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-09-11ARM: DT: APQ8064: Add node for ps_hold function in pinctrlPramod Gurav
This patch adds DT support to configure GPIO_78 as function ps_hold on apq8064. CC: Rob Herring <robh+dt@kernel.org> CC: Pawel Moll <pawel.moll@arm.com> CC: Mark Rutland <mark.rutland@arm.com> CC: Ian Campbell <ijc+devicetree@hellion.org.uk> CC: Kumar Gala <galak@codeaurora.org> CC: devicetree@vger.kernel.org CC: linux-arm-kernel@lists.infradead.org Signed-off-by: Pramod Gurav <pramod.gurav@smartplayin.com> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-09-11ARM: DT: APQ8064: Add pinctrl supportPramod Gurav
This patch adds device tree nodes to support pinctrl for apq8064 SOC CC: Rob Herring <robh+dt@kernel.org> CC: Pawel Moll <pawel.moll@arm.com> CC: Mark Rutland <mark.rutland@arm.com> CC: Ian Campbell <ijc+devicetree@hellion.org.uk> CC: Kumar Gala <galak@codeaurora.org> CC: devicetree@vger.kernel.org CC: linux-arm-kernel@lists.infradead.org Signed-off-by: Pramod Gurav <pramod.gurav@smartplayin.com> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-05-29ARM: dts: qcom: Add initial APQ8064 SoC and IFC6410 board device treesKumar Gala
Add basic APQ8064 SoC include device tree and support for basic booting on the IFC6410 board. Also, keep dtb build list and qcom_dt_match in sorted order. Signed-off-by: Kumar Gala <galak@codeaurora.org>
