Use stdout-path so that we don't have to put the console on the
kernel command line.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Add the sdcc nodes to support the SD card controller using pl180
mmci driver. We also add a temporary fixed regulator until the
regulator driver is mainlined.
Cc: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Signed-off-by: Kumar Gala <galak@codeaurora.org>
Add the PMIC and the sub-devices that are currently supported in
the kernel to the DT.
* Move SoC peripherals into an SoC container node
* Move serial enabling into board file (qcom-msm8660-surf.dts)
* Cleanup cpu node to match binding spec, enable-method and compatible
should be per cpu, not part of the container
* Add GSBI node and configuration of GSBI controller
Pull the SoC device tree bits into their own files so other boards based
on these SoCs can include them and reduce duplication across a number of
boards.
Add the necessary DT nodes to probe the clock controllers on MSM
devices as well as hook up the uart nodes to the clock
controllers. This should allow us to boot to a serial console on
all DT enabled MSM platforms.
Cc: David Brown <davidb@codeaurora.org>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
The summary interrupt is #16 in the SPI space. Unfortunately,
when this device was translated from board files to DT we forgot
to subtract 16 from the interrupt number to translate it into a
SPI interrupt. Also, the register space is larger than 4k, increase
it appropriately so that the gpio driver doesn't try to access
registers outside of its mapping.
Use a standard 'qcom' prefix to denotate device trees meant for Qualcomm
based processors.
Signed-off-by: David Brown <davidb@codeaurora.org>
