While the DT parsing code recognizes "ok" as a valid value for the
"status" property, ePAPR v1.1 doesn't mention it in the list of valid
values.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Add a stdout-path property so that automatic console selection works
in the absence of a "console=" parameter on the kernel command line.
Remove the now-superfluous "console=" parameter from chosen/bootargs.
No more device needs to be added from platform code when booting the
reference platform, move MTU2 registration from setup-r7s72100.c to
board-genmai.c and remove the now empty r7s72100_add_dt_devices()
function.
As the genmai_add_standard_devices() function is now identical to the
default init_machine implementation, remove it as well.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Acked-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Add SPI device for RSPI on Genmai.
On this board, only rspi4 is in use. Its bus contains a single device
(a wm8978 audio codec), for which no bindings are defined yet.
Copy the device nodes from Genmai reference into the Genmai device tree
file. This will allow us to use a single DTS file regardless of kernel
configuration. In case of legacy C board code the device nodes may or
may not be used, but in the multiplatform case all the DT device nodes
will be used.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
In order to allow usage of the preprocessor in the SoC device tree
sources, switch from /include/ to #include.
Genmai base board support making use of 128 MiB of memory,
the r7s7211 SoC with the SCIF2 serial port and CA9 core.
Signed-off-by: Magnus Damm <damm@opensource.se>
