Add pin configuration for LED0 which is connected to a GPIO.
Signed-off-by: Chris Brandt <chris.brandt@renesas.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Add pin configuration for SDHI ch1.
Add pin configuration for Ethernet.
Add pin configuration for SCIF2 serial console interface.
Enable the realtime clock.
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
Enable the 32.768 kHz RTC_X1 clock by setting the frequency value to
non-zero.
Add the initial device tree for the RZ/A1 based development board (RSK).
