commit 1dfc65cef481ac6af64380f26186d5cc585b46eb upstream.
The R-Car M2N hardware manual states that Tc = –40°C to +105°C. The
thermal sensor has an accuracy of ±5°C and there can be a temperature
difference of 1 or 2 degrees between Tjmax and the thermal sensor due
to the location of the latter.
This means that 95°C is a safer value to use.
Fixes: 57f9156bc620ac56 ("ARM: dts: r8a7793: enable to use thermal-zone")
Signed-off-by: Chris Paterson <chris.paterson2@renesas.com>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Reserve SRAM for the jump stub for CPU core bringup.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
R-Car M2-N has 2 regions of Inter Connect RAM (72 + 4 KiB).
Define the upper limit otherwise the driver cannot utilize max speeds.
Acked-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
The device trees for Renesas SoCs use either pfc or pin-controller as the
node name for the PFC device. This patch is intended to take a step towards
unifying the node name used as pin-controller which appears to be the more
generic of the two and thus more in keeping with the DT specs.
My analysis is that this is a user-visible change to the extent that kernel
logs, and sysfs entries change from e6060000.pfc and pfc@e6060000 to
e6060000.pin-controller and pin-controller@e6060000.
The SSI-ALL gate clock is located in between the P clock and the
individual SSI[0-9] clocks, hence the former should be listed as their
parent.
Fixes: 072d326542e49187 ("ARM: dts: r8a7793: add MSTP10 clocks to device tree")
Link the ARM GIC to the INTC-SYS module clock, and add it to the "always
on" PM Domain, so it can be power managed using that clock.
Note that currently the GIC-400 driver doesn't support module clocks nor
Runtime PM, so this must be handled as a critical clock.
Current Audio-DMAC is assigned "rx" as Audio-DMAC0, "tx" as Audio-DMAC1.
Thus, DVC "tx" should be assigned as Audio-DMAC1, instead of Audio-DMAC0.
Because of this, current platform board (using SRC/DVC/SSI)
Playback/Capture both will use same Audio-DMAC0
(but it depends on audio data path).
First note is that this "rx" and "tx" are from each IP point,
it doesn't mean Playback/Capture.
Second note is that Audio DMAC assigned on DT is only for
Audio-DMAC, Audio-DMAC-peri-peri has no entry.
=> Audio-DMAC
-> Audio-DMAC-peri-peri
-- HW connection
Playback case
[Mem] => [SRC]--[DVC] -> [SSI]--[Codec]
rx ~~~~~~~~~~~~
Capture
[Mem] <= [DVC]--[SRC] <- [SSI]--[Codec]
tx ~~~~~~~~~~~~
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
The Cortex-A15 cache controller is an integrated controller, and thus
the device node representing it should not have a unit-addresses or reg
property.
Fixes: ad53f5f00b095a0d ("ARM: dts: r8a7793: Fix W=1 dtc warnings")
Since everybody copied my own mistake from the DT binding example,
let's address all the offenders in one swift go.
Most of them got the CPU interface size wrong (4kB, while it should
be 8kB), except for both keystone platforms which got the control
interface wrong (4kB instead of 8kB).
In a few cases where I knew for sure what implementation was used,
I've added the "arm,gic-400" compatible string. I'm 99% sure that
this is what everyone is using, but short of having the TRM for
all the other SoCs, I've left them alone.
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Use recently added R-Car Gen 2 fallback binding for iic nodes in
DT for r8a7793 SoC.
This has no run-time effect for the current driver as the initialisation
sequence is the same for the SoC-specific binding for r8a7793 and the
fallback binding for R-Car Gen 2.
Use recently added R-Car Gen 2 fallback binding for i2c nodes in
DT for r8a7793 SoC.
Pull ARM DT updates from Arnd Bergmann:
"Lots of changes as usual, so I'm trying to be brief here. Most of the
new hardware support has the respective driver changes merged through
other trees or has had it available for a while, so this is where
things come together.
We get a DT descriptions for a couple of new SoCs, all of them
variants of other chips we already support, and usually coming with a
new evaluation board:
- Oxford semiconductor (now Broadcom) OX820 SoC for NAS devices
- Qualcomm MDM9615 LTE baseband
- NXP imx6ull, the latest and smallest i.MX6 application processor variant
- Renesas RZ/G (r8a7743 and r8a7745) application processors
- Rockchip PX3, a variant of the rk3188 chip used in Android tablets
- Rockchip rk1108 single-core application processor
- ST stm32f746 Cortex-M7 based microcontroller
- TI DRA71x automotive processors
These are commercially available consumer platforms we now support:
- Motorola Droid 4 (xt894) mobile phone
- Rikomagic MK808 Android TV stick based on Rockchips rx3066
- Cloud Engines PogoPlug v3 based on OX820
- Various Broadcom based wireless devices:
- Netgear R8500 router
- Tenda AC9 router
- TP-LINK Archer C9 V1
- Luxul XAP-1510 Access point
- Turris Omnia open hardware router based on Armada 385
And a couple of new boards targeted at developers, makers or
industrial integration:
- Macnica Sodia development platform for Altera socfpga (Cyclone V)
- MicroZed board based on Xilinx Zynq FPGA platforms
- TOPEET itop/elite based on exynos4412
- WP8548 MangOH Open Hardware platform for IOT, based on Qualcomm MDM9615
- NextThing CHIP Pro gadget
- NanoPi M1 development board
- AM571x-IDK industrial board based on TI AM5718
- i.MX6SX UDOO Neo
- Boundary Devices Nitrogen6_SOM2 (i.MX6)
- Engicam i.CoreM6
- Grinn i.MX6UL liteSOM/liteBoard
- Toradex Colibri iMX6 module
Other changes:
- added peripherals on renesas, davinci, stm32f429, uniphier, sti,
mediatek, integrator, at91, imx, vybrid, ls1021a, omap, qualcomm,
mvebu, allwinner, broadcom, exynos, zynq
- Continued fixes for W=1 dtc warnings
- The old STiH415/416 SoC support gets removed, these never made it
into products and have served their purpose in the kernel as a
template for teh newer chips from ST
- The exynos4415 dtsi file is removed as nothing uses it.
- Intel PXA25x can now be booted using devicetree"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (422 commits)
arm: dts: zynq: Add MicroZed board support
ARM: dts: da850: enable high speed for mmc
ARM: dts: da850: Add node for pullup/pulldown pinconf
ARM: dts: da850: enable memctrl and mstpri nodes per board
ARM: dts: da850-lcdk: Add ethernet0 alias to DT
ARM: dts: artpec: add pcie support
ARM: dts: add support for Turris Omnia
devicetree: Add vendor prefix for CZ.NIC
ARM: dts: berlin2q-marvell-dmp: fix typo in chosen node
ARM: dts: berlin2q-marvell-dmp: fix regulators' name
ARM: dts: Add xo to sdhc clock node on qcom platforms
ARM: dts: r8a7794: Add device node for PRR
ARM: dts: r8a7793: Add device node for PRR
ARM: dts: r8a7792: Add device node for PRR
ARM: dts: r8a7791: Add device node for PRR
ARM: dts: r8a7790: Add device node for PRR
ARM: dts: r8a7779: Add device node for PRR
ARM: dts: r8a73a4: Add device node for PRR
ARM: dts: sk-rzg1e: add Ether support
ARM: dts: sk-rzg1e: initial device tree
Add a device node for the Product Register, which provides SoC product
and revision information.
Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Several SCIFB registers reside outside the reported register ranges.
Fortunately this works (on Linux), due to the PAGE_SIZE granularity of
ioremap().
Extend the sizes from 64 to 0x100 bytes to fix this, like is done on
SH/R-Mobile SoCs.
Add a device node for the RST module, which provides a.o. reset control
and mode pin monitoring.
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
Add DT nodes for the Advanced Power Management Unit (APMU) and the
second CPU core. Use the enable-method to point out that the APMU
should be used for SMP support.
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
Warning (unit_address_vs_reg): Node /cache-controller@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,dvc/dvc@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,dvc/dvc@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@2 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@3 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@4 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@5 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@6 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@7 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@8 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@9 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@2 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@3 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@4 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@5 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@6 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@7 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@8 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@9 has a unit name, but no reg property
Move the cache-controller node under the cpus node, and make its unit
name and reg property match the MPIDR values.
R-Car Gen2 have two DMA controllers, which are equivalent. Add
references to both dmac0 and dmac1 so the driver can choose which one to
use.
Signed-off-by: Niklas Söderlund <niklas.soderlund+renesas@ragnatech.se>
Same as on r8a7791.
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Pull ARM SoC late DT updates from Arnd Bergmann:
"This is a collection of a few late fixes and other misc stuff that had
dependencies on things being merged from other trees.
The Renesas R-Car power domain handling, and the Nvidia Tegra USB
support both hand notable changes that required changing the DT
binding in a way that only provides compatibility with old DT blobs on
new kernels but not vice versa. As a consequence, the DT changes are
based on top of the driver changes and are now in this branch.
For NXP i.MX and Samsung Exynos, the changes in here depend on other
changes that got merged through the clk maintainer tree"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (35 commits)
ARM: dts: exynos: Add support of Bus frequency using VDD_INT for exynos5422-odroidxu3
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos542x SoC
ARM: dts: exynos: Add NoC Probe dt node for Exynos542x SoC
ARM: dts: exynos: Add support of bus frequency for exynos4412-trats/odroidu3
ARM: dts: exynos: Expand the voltage range of buck1/3 regulator for exynos4412-odroidu3
ARM: dts: exynos: Add support of bus frequency using VDD_INT for exynos3250-rinato
ARM: dts: exynos: Add exynos4412-ppmu-common dtsi to delete duplicate PPMU nodes
ARM: dts: exynos: Add bus nodes using VDD_MIF for Exynos4210
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos4x12
ARM: dts: exynos: Add bus nodes using VDD_MIF for Exynos4x12
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos3250
ARM: dts: exynos: Add DMC bus frequency for exynos3250-rinato/monk
ARM: dts: exynos: Add DMC bus node for Exynos3250
ARM: tegra: Enable XUSB on Nyan
ARM: tegra: Enable XUSB on Jetson TK1
ARM: tegra: Enable XUSB on Venice2
ARM: tegra: Add Tegra124 XUSB controller
ARM: tegra: Move Tegra124 to the new XUSB pad controller binding
ARM: dts: r8a7794: Use SYSC "always-on" PM Domain
ARM: dts: r8a7793: Use SYSC "always-on" PM Domain
Hook up all devices that are part of the CPG/MSTP Clock Domain to the
SYSC "always-on" PM Domain, for a more consistent device-power-area
description in DT.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Add a device node for the System Controller.
Hook up the first Cortex-A15 CPU core and the Cortex-A15 L2 cache/SCU to
their respective PM Domains.
clk_get() on a disabled clock node will return -EPROBE_DEFER, which can
cause drivers to be deferred forever if such clocks are referenced in
their devices' clocks properties.
Update the various disabled external clock nodes to default to a
frequency of 0, but don't disable them, to prevent this.
Same as on r8a7791.
Add CAN nodes to r8a7793 device tree.
Based on work by Sergei Shtylyov for the r8a7791 SoC.
The R-Car CAN controllers can derive the CAN bus clock not only from their
peripheral clock input (clkp1) but also from the other internal clock
(clkp2) and external clock fed on CAN_CLK pin. Describe those clocks in
the device tree along with the USB_EXTAL clock from which clkp2 is
derived.
* Fixed rate and fixed factor clocks do not require an
clock-output-names property.
* Since 07705583e920fef6 ("clk: shmobile: div6: Make clock-output-names
optional") Renesas div6 clocks do not require a clock-output-names
property.
In the above cases there is only one clock output and its name is taken
from that of the clock node. Accordingly, remove the unnecessary
clock-output-names properties and as necessary update the node names.
Add a device node for the L2 cache, and link the CPU node to it.
The L2 cache for the Cortex-A15 CPU cores is 1 MiB large (organized as
64 KiB x 16 ways).
This patch enables to use thermal-zone on r8a7793.
This thermal sensor can measure temperature from -40000 to 125000,
but over 117000 can be critical on this chip.
Thus, default critical temperature is now set as 115000 (this driver
is using 5000 steps) (Current critical temperature is using it as
90000, but there is no big reason about it)
And it doesn't check thermal zone periodically (same as current
behavior). You can exchange it by modifying polling-delay[-passive]
property.
You can set trip temp if your kernel has CONFIG_THERMAL_WRITABLE_TRIPS,
but you need to take care to use it, since it will call
orderly_poweroff() it it reaches to the value.
echo $temp > /sys/class/thermal/thermal_zone0/trip_point_0_temp
Add the device node for the external SCIF_CLK.
The presence of the SCIF_CLK crystal and its clock frequency depends on
the actual board.
Add the two optional clock sources (ZS_CLK and SCIF_CLK for the internal
resp. external clock) for the Baud Rate Generator for External Clock
(BRG) to all SCIF and HSCIF device nodes.
This increases the range and accuracy of supported baud rates on
(H)SCIF.
The clock is really the device functional clock, not the interface
clock. Rename it.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Enable audio DMAC (= rcar-dmac) in r8a7793 device tree.
Based on similar work for the r8a7791 by Kuninori Morimoto.
Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
v4
* Use GIC_SPI in interrupts properties
Audio DMAC peri peri is no longer DMAEngine. it is supported by
sound driver. this patch enable it.
Base on work for the r8a7791 by Kuninori Morimoto.
Instantiate the two Audio DMA controllers in the r8a7791 device tree.
Instantiate Audio DMA clocks in the r8a7791 device tree.
Add DVC support to sound node in r8a7793 device tree.
Instantiate R-Car sound node in r8a7793 device tree.
This only supports PIO transfers.
Declare m2 clock in r8a7793 device tree.
Based on similar work for the r8a7791 by Laurent Pinchart.
Instantiate audio clock in r8a7793 device tree.
audio_clk_a/b/c are required for R-Car sound.
Instantiate MSTP10 clocks in r8a7793 device tree.
Use GIC_* defines for GIC interrupt cells in r8a7793 device tree.
Move dmac nodes in the r8a7793 device tree to match their location
in the r8a7791 device tree to aid comparison between the device
trees of these similar SoCs.
Instantiate all the 9 I2C controllers in the disabled state.
Update IPMMU compat strings to include SoC part number.
By specifying SoC part number in DT it becomes possible
to implement SoC specific features in the IPMMU driver.
Add DMA properties to all SCIF, SCIFA, SCIFB, and HSCIF device nodes.
Based on similar work for the r8a7791 by Geert Uytterhoeven.
Instantiate all serial devices in r8a7793 device tree
and set them as disabled by default.
Cc: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Commit a1bc260bb5f5d9 ("gpio: clean up gpio-ranges documentation")
declares the above property deprecated. That was more than 2 years ago.
Remove it, so it doesn't get copied around needlessly.
Based on similar work for the r8a7791 and r8a7794 by Wolfram Sang.
Cc: Wolfram Sang <wsa+renesas@sang-engineering.com>
Reported-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
