path: root/arch/arm/boot/dts/rk3288-veyron-pinky.dts
2015-08-21ARM: dts: rockchip: correct regulator power states for suspendBrian Norris
When getting translated from a downstream device tree that used slightly different DT bindings, these regulators got labeled with the "on-in-suspend" state, when they were actually supposed to be turned off for S3 suspend. This was harmless, but not intentional, AFAICT. Let's turn them off to get the optimal power state. Signed-off-by: Brian Norris <briannorris@chromium.org> Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Heiko Stuebner <heiko@sntech.de>
2015-07-16ARM: dts: rockchip: add veyron-pinky boardHeiko Stuebner
While pinky was one of the earlier development models, is on the list of endangered species today and nearly extinct, I want to keep mine around for the foreseeable future after spending all the time making a nice hole into the base below the dut-connector. Signed-off-by: Heiko Stuebner <heiko@sntech.de>
