Add a device node for the System Controller, with subnodes that
represent the hardware power area hierarchy.
Hook up all devices to their respective PM domains.
Note that unlike on R-Mobile A1 (r8a7740), PM domain D4 can be powered
down without ill effects on s2ram behavior, just like on SH-Mobile AP4
(sh7372). Hence we can postpone adding a (minimal) device node for the
Coresight-ETM hardware block.
The System Controller is also used by the R-Mobile Reset driver, which
can now restart the system.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Add a node for the Private Timer and Watchdog, as found in the Cortex-A9
MPCore.
Without this, there's no clocksource available during early kernel
initialization, before cmt1 is initialized, leading to a lock-up if
CONFIG_CPU_IDLE=y.
Add a node for the Bus State Controller (BSC) on sh73a0, to which
multiple external devices can be connected.
The BSC is driven by the ZB clock, and located in PM domain A4S.
A reference to the latter will be added later.
Specifies clock sources and register bits.
Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
[geert: Drop renesas,src-shift/renesas,src-width, pad to 4 or 8 parents]
This clock drives the irqpin controller modules.
Before, it was assumed enabled by the bootloader or reset state.
By making it available to the driver, we make sure it gets enabled when
needed, and allow it to be managed by system or runtime PM.
The sh73a0 INTC can't mask interrupts properly most likely due to a
hardware bug. Set the control-parent property to delegate masking to the
parent interrupt controller.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Pull ARM SoC driver updates from Olof Johansson:
"These are changes for drivers that are intimately tied to some SoC and
for some reason could not get merged through the respective subsystem
maintainer tree.
This time around, much of this is for at91, with the bulk of it being
syscon and udc drivers.
Also, there's:
- coupled cpuidle support for Samsung Exynos4210
- Renesas 73A0 common-clk work
- of/platform changes to tear down DMA mappings on device destruction
- a few updates to the TI Keystone knav code"
* tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (26 commits)
cpuidle: exynos: add coupled cpuidle support for exynos4210
ARM: EXYNOS: apply S5P_CENTRAL_SEQ_OPTION fix only when necessary
soc: ti: knav_qmss_queue: change knav_range_setup_acc_irq to static
soc: ti: knav_qmss_queue: makefile tweak to build as dynamic module
pcmcia: at91_cf: depend on !ARCH_MULTIPLATFORM
soc: ti: knav_qmss_queue: export API calls for use by user driver
of/platform: teardown DMA mappings on device destruction
usb: gadget: at91_udc: Allocate udc instance
usb: gadget: at91_udc: Update DT binding documentation
usb: gadget: at91_udc: Rework for multi-platform kernel support
usb: gadget: at91_udc: Simplify probe and remove functions
usb: gadget: at91_udc: Remove non-DT handling code
usb: gadget: at91_udc: Document DT clocks and clock-names property
usb: gadget: at91_udc: Drop uclk clock
usb: gadget: at91_udc: Fix clock names
mfd: syscon: Add Atmel SMC binding doc
mfd: syscon: Add atmel-smc registers definition
mfd: syscon: Add Atmel Matrix bus DT binding documentation
mfd: syscon: Add atmel-matrix registers definition
clk: shmobile: fix sparse NULL pointer warning
Add device nodes for the two SDRAM Bus State Controllers.
The SBSCs are located in the A4BC0 resp. A4BC1 PM domains, which must
not be powered down, else the system will crash.
References to the A4BC0 and A4BC1 PM domains will be added later.
The FSI2 sound node used the generic compatible property only.
Add the SoC-specific one, to make it future proof.
Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Assigns clocks to cmt1, i2c*, mmcif, sdhi*, and scif*.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Tested-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Declares all sh73a0 clocks supported by the legacy clock framework.
The IIC nodes used the generic compatible properties only.
This causes the driver to fail when using Standard Speed, as the
operational clock is driven by the 104 MHz HP clock:
i2c-sh_mobile e6820000.i2c: timing values out of range: L/H=0x208/0x1bf
i2c-sh_mobile: probe of e6820000.i2c failed with error -22
Add the SoC-specific compatible property to fix this.
Reviewed-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Pull ARM SoC DT updates from Arnd Bergmann:
"As usual, this is the largest branch, though this time a little under
half of the total changes with 307 individual non-merge changesets.
The largest changes are the addition of new machines, in particular
the Tegra based Chromebook, the Renesas r8a7794 SoC, and DT support
for the old i.MX1 platform.
Other changes include
- at91: various sam9 and sama5 updates
- exynos: much extended Peach Pi/Pit (Chromebook 2) support
- keystone: new peripherals
- meson: added DT for meson6 SoC
- mvebu: new device support for Armada 370/375
- qcom: improved support for IPQ8064 and MSM8x60
- rockchip: much improved support for rk3288
- shmobile: lots of updates all over the place
- sunxi: dts license change
- sunxi: more a23 device support
- vexpress: CLCD DT description"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (308 commits)
ARM: DTS: meson: update DTSI to add watchdog node
ARM: dts: keystone-k2l: fix mdio io start address
ARM: dts: keystone-k2e: fix mdio io start address
ARM: dts: keystone-k2e: update usb1 node for dma properties
ARM: dts: keystone: fix io range for usb_phy0
Revert "Merge tag 'hix5hd2-dt-for-3.18' of git://github.com/hisilicon/linux-hisi into next/dt"
Revert "ARM: dts: hix5hd2: add wdg node"
ARM: dts: add rk3288 i2s controller
ARM: vexpress: Add CLCD Device Tree properties
ARM: bcm2835: add I2S pinctrl to device tree
ARM: meson: documentation: add bindings documentation
ARM: meson: dts: add basic Meson/Meson6/Meson6-atv1200 DTSI/DTS
ARM: dts: mt6589: Change compatible string for GIC
ARM: dts: mediatek: Add compatible property for aquaris5
ARM: dts: mt6589-aquaris5: Add boot argument earlyprintk
ARM: dts: mt6589: Fix typo in GIC unit address
ARM: dts: Build dtb for Mediatek board
ARM: dts: keystone: fix bindings for pcie and usb clock nodes
ARM: dts: keystone: k2l: Fix chip selects for SPI devices
ARM: dts: keystone: add dsp gpio controllers nodes
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/soc
Pull "Second Round of Renesas ARM Based SoC DT Timers Updates for v3.18" from Simon Horman:
* kzm9g-reference: Enable CMT1 in device tree
* Use SoC-specific timer compat strings
* tag 'renesas-dt-timers2-for-v3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
ARM: shmobile: kzm9g-reference: Enable CMT1 in device tree
ARM: shmobile: sh73a0: Add CMT1 device to DT
ARM: shmobile: r8a7740: Use SoC-specific 48-bit CMT compat string
ARM: shmobile: r8a7779: Use SoC-specific TMU compat string
ARM: shmobile: r8a7791: Use SoC-specific 48-bit CMT compat string
ARM: shmobile: r7s72100: Use SoC-specific MTU2 compat string
ARM: shmobile: r8a7790: Use SoC-specific 48-bit CMT compat string
Acked-by: Magnus Damm <damm+renesas@opensource.se>
Add an "interrupt-parent = <&gic>;" at the top, which is inherited by
all child nodes, so the "interrupt-parent" properties can be removed
from the individual child nodes.
Add CPU Frequency information to the sh73a0 DTS file. This
will allow us to use the shared C code on sh73a0 and KZM9G
which reads out the clock frequency from DT and calculates the
delay settings from there.
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
This describes all of the SCIF hardware of the sh73a0.
Each node is disabled and may be enabled as necessary
by board DTS files.
This is likely a copy-and-paste error from the
ARM GIC documentation, that has already been fixed.
address-cells should have been set to 0, as with the size
cells. As having those properties set to 0 is the
same thing as not specifying them, drop them completely.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Add "renesas,intc-irqpin-sh73a0" to the compatible string for the
IRQ pins in case of sh73a0 INTC. This makes the INTC irqpin follow
the same style as the other devices and also makes it more future proof.
Signed-off-by: Magnus Damm <damm@opensource.se>
sh73a0 != r8a7740
According to ePAPR spec,
this patch tidies up DT node name and related clock.
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt
From Tony Lindgren:
Changes needed to prepare for making omap3 device tree only:
- Always build in board-generic, and add pdata quirks and auxdata
support for it so we have all the pdata related quirks
in the same place.
- Merge of the drivers/pinctrl changes that are needed for PM
to continue working on omap3 and also needed for other omaps
eventually. The three pinctrl related patches have been acked
by Linus Walleij and are pulled into both the pinctrl tree
and this branch.
- Few defconfig related changes for drivers needed.
* tag 'omap-for-v3.13/quirk-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (523 commits)
ARM: configs: omap2plus_defconfig: enable dwc3 and dependencies
ARM: OMAP2+: Add WLAN modules and of_serial to omap2plus_defconfig
ARM: OMAP2+: Run make savedefconfig on omap2plus_defconfig to shrink it
ARM: OMAP2+: Add minimal 8250 support for GPMC
ARM: OMAP2+: Use pdata quirks for wl12xx for omap3 evm and zoom3
ARM: OMAP: Move DT wake-up event handling over to use pinctrl-single-omap
ARM: OMAP2+: Add support for auxdata
pinctrl: single: Add support for auxdata
pinctrl: single: Add support for wake-up interrupts
pinctrl: single: Prepare for supporting SoC specific features
ARM: OMAP2+: igep0020: use display init from dss-common
ARM: OMAP2+: pdata-quirks: add legacy display init for IGEPv2 board
+Linux 3.12-rc4
Signed-off-by: Kevin Hilman <khilman@linaro.org>
Currently all I2C interfaces in all *.dtsi files for various Renesas SoCs
are enabled by default. Switch them all off and only enable populated I2C
interfaces in board-specific *.dts files.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski+renesas@gmail.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Currently DT compatibility strings of both types can be found in the kernel
sources: <unit>-<soc> and <soc>-<unit>, whereas a unique format should be
followed and the former one is preferred. This patch converts the SDHI
MMC driver and its users to the common standard. This is safe for now, since
ATM no real products are using this driver with DT.
Acked-by: Chris Ball <cjb@laptop.org>
[Removed r8a7740.dtsi portion as it is not applicable]
Pull ARM Renesas SoC cleanup, refactoring and more SMP support from Kevin Hilman:
"Lots of cleanup and refactoring and some SMP additions for Renesas
platforms. Due to some inter-dependencies with other arm-soc
branches, this Renesas stuff was separated out for sending after the
other branches were merged.
Highlights:
- remove unused board support and cleanup of unused headers
- refactoring of init and device registration
- simplify IRQ initialization"
* tag 'renesas-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (68 commits)
ARM: shmobile: Per-CPU SMP boot / sleep code for SCU SoCs
ARM: shmobile: Introduce per-CPU SMP boot / sleep code
ARM: shmobile: Use shared SCU CPU Hotplug code on r8a7779
ARM: shmobile: Use shared SCU CPU Hotplug code on sh73a0
ARM: shmobile: Add shared SCU CPU Hotplug code
ARM: shmobile: Use shared SCU SMP boot code on emev2
ARM: shmobile: Use shared SCU SMP boot code on r8a7779
ARM: shmobile: Use shared SCU SMP boot code on sh73a0
ARM: shmobile: Introduce shared SCU SMP boot code
ARM: shmobile: sh73a0: Remove global GPIO_NR definition
ARM: shmobile: kzm9d: remove nfsroot settings from bootargs
ARM: shmobile: armadillo800eva: remove nfsroot settings from bootargs
ARM: shmobile: r8a7779: move r8a7779_init_irq_xxx() to setup
ARM: shmobile: r8a7740: move r8a7740_init_irq_of() to setup
ARM: shmobile: bockw: add missing __initdata
ARM: shmobile: r8a7790: add missing __initdata
ARM: shmobile: r8a7779: add missing __initdata
ARM: shmobile: Remove unused shmobile_init_time()
ARM: shmobile: Use clocksource_of_init() on r8a7790
ARM: shmobile: Use default ->init_time() on KZM9G DT ref
Add PMU information to sh73a0.dtsi. With this
included KZM9G DT reference may use the PMU.
Add a pfc node to the sh73a0 device tree and remove manual pinmux
initialization from the corresponding board files.
The convention for Device Tree node names is <device>@<hex-address>, where
the part after '@' shouldn't contain the "0x" prefix. Fix the sh73a0.dtsi
DT names.
Second round of Renesas ARM and SH based SoC pinmux updates for v3.10
Highlights:
* Compilation fixes for sh7269 and for when CONFIG_BUG is not set
* sh-pfc Support for r8a73a4 SoC
* Move GPIOs handling from the PFC device to separate GPIO devices on the r8a7779 SoC
This pull request is based on a merge of:
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas renesas-pinmux-for-v3.10
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas renesas-soc2-for-v3.10
This merge is made to supply run-time dependencies for the following
patches that will bea added on top:
ARM: shmobile: APE6EVM LAN9220 support
ARM: shmobile: APE6EVM PFC support
Add DT nodes for the 4 irqpin interrupt controllers on sh73a0. We add them
to sh73a0.dtsi, which is also used by configurations, doing all their
device instantiation from board the .c code. We rely on the fact, that
such configurations don't instantiate devices from the device-tree.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Fix several device-tree bindings, that haven't been updated for newest
versions of respective drivers, and device names and pin numbers, left over
from non-DT and old pinctrl versions.
To avoid having to repeat common DT node properties in all .dts files
move them to SoC's .dtsi file, setting their status to "disabled."
Individual boards will pick up devices, that they want to use and
change their DT node status to enabled.
Cc: Mark Rutland <mark.rutland@arm.com>
Allow a minimal setup of the sh73a0 SoC using a flattened device tree.
In particular, Configure the i2c controllers using a flattened device tree.
SCI serial controller and CMT clock source, whose drivers do not yet
support configuration using a flattened device tree, are still configured
using C code in order to allow booting of a board with this SoC.
*** Please note that the clock initialisation scheme used in
this patch does not currently work with SMP as there
is a yet to be resolved lock-up in workqueue initialisation.
CONFIG_SMP must be disabled when using this code. ***
Includes update from Thierry Reding to no longer use gic_handle_irq()
Cc: Thierry Reding <thierry.reding@avionic-design.de>
fix
This allows the GIC interrupt controller of the sh73a0 SoC to be
initialised using a flattened device tree blob.
It does not allow the INTC interrupt controller which is also present on
the sh73a0 SoC to be enabled via device tree. Nor does it handle sharing
of interrupts between the GIC and INTC interrupt controllers.
This limits the usefulness of this code to applications which only wish to
access devices which use interrupts that can be handled by the GIC
interrupt controller. Other applications should, for now, continue using
non-device tree initialisation of the sh72a0 interrupt controllers.
Includes update to use irqchip_init() by Thierry Reding
