Use stdout-path dts property for kernel console.
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Without the 3.3V regulator node, the SDMMC driver will give these warnings:
dw_mmc ff704000.dwmmc0: No vmmc regulator found
dw_mmc ff704000.dwmmc0: No vqmmc regulator found
This patch adds the regulator node, and points the SD/MMC to the regulator.
Reviewed-by: Doug Anderson <dianders@chromium.org>
v3: Rename nodes to have schematic-name_regulator and remove "boot-on" and
"always-on"
v2: Move the regulator nodes to their respective board dts file and
correctly rename them to match the schematic
commit [2755e187 dts: socfpga: Add DTS entry for adding the stmmac glue
layer for stmmac.] added an extra ethernet alias in the ArriaV devkit
board file. This patch removes it.
Update all the SOCFPGA DTS files with USB entries.
Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
The Altera Cyclone5 and Arria5 devkit has an EEPROM and a RTC on the
board. This patch adds support for them.
v2: Remove LCD as the driver has not been upstreamed.
Convert all socfpga DT files to the dtc preprocessor include syntax.
This allows to include header files in the devicetrees like other
SoC-types already do.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
This patch adds the dts bindings documenation for the Altera SOCFPGA glue
layer for the Synopsys STMMAC ethernet driver.
Add support for a new SOCFPGA board that has an Arria V FPGA along with
dual ARM Cortex-A9 cores.
Cc: Pavel Machek <pavel@denx.de>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: devicetree@vger.kernel.org
CC: linux-arm-kernel@lists.infradead.org
