path: root/arch/arm/boot/dts/spear1340-evb.dts
2015-07-17Update Viresh Kumar's email addressViresh Kumar
Switch to my kernel.org alias instead of a badly named gmail address, which I rarely use. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-14ARM: SPEAr13xx: Add pcie and miphy DT nodesPratyush Anand
This patch adds necessary DT nodes for pcie controllers and miphys for SPEAr13xx SoCs. SPEAr1310 has 3 PCIe ports and SPEAr1340 has 1, which are multiplexed with ahci/sata pins. By default evaluation board of both controller works in ahci mode. Because of this, these nodes are marked "disabled" by default. In order to use pcie controller on evaluation boards do necessary modifications on board and enable (By replacing "disabled" with "okay") pcie and miphy from respective 'evb' dtsi file. Phy specific initialization was previously done from spear1340.c, which isn't required anymore as we have separate drivers for it. Remove it. Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Pratyush Anand <pratyush.anand@st.com> Signed-off-by: Mohit Kumar <mohit.kumar@st.com> [viresh: fixed logs/cclist/checkpatch warnings, clubbed multiple patches into one] Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2012-11-26ARM: SPEAr: DT: Update device nodesShiraz Hashim
This patch adds multiple device nodes for SPEAr machines and boards. Signed-off-by: Bhavna Yadav <bhavna.yadav@st.com> Signed-off-by: Deepak Sikri <deepak.sikri@st.com> Signed-off-by: Rajeev Kumar <rajeev-dlh.kumar@st.com> Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Vijay Kumar Mishra <vijay.kumar@st.com> Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Vipul Kumar Samar <vipulkumar.samar@st.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2012-11-26ARM: SPEAr: DT: add uart state to fix warningVipul Kumar Samar
amba-pl011 driver supports two pin state "default" and "sleep" and it expect from dt to provide this pinctrl states and phandler otherwise it gives a warning message. To remove this warning message pass default state with null phandler to uart pins in device node (In our case all the pins are configured in default states so we pass null phandler to pins). Signed-off-by: Vipul Kumar Samar <vipulkumar.samar@st.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2012-11-26ARM: SPEAr: DT: Modify DT bindings for STMMACDeepak Sikri
This patch modifies the DT bindings for the GMAC IP existings for the SPEAr family. The DT bindings now additionally pass the phy mode as a configuration parameter for the ethernet device. Signed-off-by: Deepak Sikri <deepak.sikri@st.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2012-11-26ARM: SPEAr: DT: Fix existing DT supportVipul Kumar Samar
This patch fixes existing DT support for all SPEAr SoC's. This includes: - Removing few nodes from board files - Updating DT data of few nodes - Updating ranges of few busses - Moving devices to correct parent bus Signed-off-by: Bhavna Yadav <bhavna.yadav@st.com> Signed-off-by: Deepak Sikri <deepak.sikri@st.com> Signed-off-by: Rajeev Kumar <rajeev-dlh.kumar@st.com> Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Vijay Kumar Mishra <vijay.kumar@st.com> Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Vipul Kumar Samar <vipulkumar.samar@st.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2012-11-26ARM: SPEAr: DT: Update partition info for MTD devicesVipin Kumar
This patch enhances partition information of MTD devices like fsmc-nand and spear-smi. Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Vipul Kumar Samar <vipulkumar.samar@st.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2012-11-26ARM: SPEAr: DT: Update pinctrl listVipul Kumar Samar
This patch updates pinctrl configuration for SPEAr SoC's. Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Vipul Kumar Samar <vipulkumar.samar@st.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2012-11-11ARM: SPEAr: Add plgpio node in device tree dtsi filesViresh Kumar
This patch adds plgpio nodes in SPEAr DT files. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-06-20Viresh has movedViresh Kumar
viresh.kumar@st.com email-id doesn't exist anymore as I have left the company. Replace ST's id with viresh.linux@gmail.com. It also updates .mailmap file to fix address for 'git shortlog' Signed-off-by: Viresh Kumar <viresh.linux@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-14SPEAr13xx: Add dts and dtsi filesViresh Kumar
This patch adds machines/boards dts{i} files for SPEAr1310 and SPEAr1340. Both are based on ARM, Cortex A9 processor family. Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
