This converts the Nomadik pin controller and all associated device
trees to use the standard, generic config bindings for pin controllers.
There are no such device trees deployed in the wild so this is
safe to do to set a good example.
Add a VCC and VIO regulator supplies to the the STMPE expander
found on the STUIB UIB variants.
This moves over the configuration of the GPIO keys (used for
proximity sensor and Hall effect sensor) from the static pin
configuration file to the device tree. As part of the exercise,
implement the GPIO keys properly in a per-UIB file as this
setup actually differs with each UIB.
The BU21013 touchscreen GPIOs have been pretty confused, correct
them per board, and move the GPIO assignments up to the top
level DTS file so we can control it from there, and avoid defining
the GPIO assignments for non-ST UIB equipped boards.
Create two different UIB (User Interface Board) include files: one per
UIB simply. The include files now only handle the devices on that
very UIB.
