Fixes: c94a4ab7af3f ("ARM: ux500: Disable the MMCI gpio-regulator by default")
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Reviewed-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
The GPIO regulator for the SD-card isn't a ux500 SOC configuration, but
instead it's specific to the board. Move the definition of it, into the
board DTSs.
Add a node in DT for the proper regulator which means we can move away
from the mmci platform data which currently holds the corresponding OCR
mask.
The mmci driver can then calculate the OCR mask based on the voltages
supported by the regulator, instead of relying on the platform data.
The mmci host driver supports the common mmc DT parser, which enables
us to use the use common names instead.
Commit 70b41abc151f9
"ARM: ux500: move MSP pin control to the device tree"
accidentally activated MSP2, giving rise to a boot scroll
scream as the kernel attempts to probe a driver for it and
fails to obtain DMA channel 14.
Fix this up by marking the node disabled again.
Acked-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
Remove duplicated configurations and move specific details into
each corresponding dtsi file for the href versions.
Cc: Lee Jones <lee.jones@linaro.org>
Cc: devicetree@vger.kernel.org
This moves over the configuration of the GPIO keys (used for
proximity sensor and Hall effect sensor) from the static pin
configuration file to the device tree. As part of the exercise,
implement the GPIO keys properly in a per-UIB file as this
setup actually differs with each UIB.
This moves the MCDE pin control table out of the board file
and into the device tree. Some pins and configs have been
marked as used by sub-devices or slaves to the MCDE, such
as I2C device 0-070 which is the HDMI interface circuit
AV8100, but the pins rather belong to the MCDE SOC block
as they come out of the main ASIC. The touch screen GPIO
is not related to MCDE so this gets deleted and need to
be tied to the respective touch screen (I2C) device
once that device is added instead.
This moves the MUSB pin control table out of the board file
and into the device tree. Tie the config to the on-chip MUSB
device rather than the ab8500-usb device which is off-chip.
This moves the static, device-tied pin control configuration
out of the board file board-mop500-pins.c and into the device
tree. Add nodes for MSP0 and MSP2 on the HREF and Snowball
so we can reference the pins properly.
Cc: Patrice Chotard <patrice.chotard@st.com>
tree. Add entries for SDI1 and SDI2 on the Snowball so that the
WLAN pins on SDI1 can be used further on, and the unused pins
on SDI2 can be put to sleep.
tree. Define possible states also for I2C4 even if it's not
used by any board file at this time.
tree.
We create a new .dtsi-file to be shared between all the
MOP500-related boards, that include all HREF variants and
the Snowball board. Assign pin states for HREF and Snowball
boards alike.
The TC35892 was mounted as a GPIO expander on the HREF prior
to v60 and not in later versions, which instead use the Nomadik
GPIO directly, so move it over to the hrefprev60 DTS file.
The ambient light sensor is places at address 0x29 nothing else.
This patch makes the ambient light sensor probe again.
The AB8500 GPIO was only registered for the pre-v60 HREF but should
be made available on all HREF variants, move the DT entry to the
common file.
This adds a heartbeat on the first LED on the ux500 HREF
boards.
The Ux500 boards are layered like this:
ste-snowball.dts includes ste-href.dtsi that includes
ste-dbx500.dtsi.
The dbx500.dtsi defines the PRCMU SoC regulators so the SoC will
probe and you can use ampersand references where need be.
However the HREF common dtsi and these two boards redefine the
same PRCMU SoC regulators with the very same names and properties
for no reason. This is like filling in the same line three
times instead of drawing it once. Just delete the surplus
references and have the PRCMU regulators defines in the SoC
files ste-dbx500.dtsi, this is enough.
The patch set beginning with commit:
"ARM: ux500: Apply a ste-* prefix onto snowball.dts"
thru commit:
"ARM: ux500: Remove u9540.dts as it's been replaced"
altered the names of the ux500 device tree files but forgot
to:
- Rename the ccu8540-pinctrl.dtsi file
- Update #include statements from files using these
files, so the build broke.
- Update the Makefile for the device trees so the build
broke.
Fix it up so we can build them all again.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
