path: root/arch/arm/boot/dts/stih410-clock.dtsi
2016-10-20ARM: dts: stih410-clocks: Add PROC_STFE as a critical clockPeter Griffin
Once the ST frontend demux HW IP has been enabled, the clock can't be disabled otherwise the system will hang and the board will be unserviceable. To allow balanced clock enable/disable calls in the driver we use the critical clock infrastructure to take an extra reference on the clock so the clock will never actually be disabled. Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Acked-by: Patrice Chotard <patrice.chotard@st.com>
2016-09-16ARM: dts: STiH410: Enable synchronous clock mode for video clocksGabriel Fernandez
This patch enables the synchronous clock mode for video clocks on STiH410 board. Signed-off-by: Olivier Bideau <olivier.bideau@st.com> Signed-off-by: Gabriel Fernandez <gabriel.fernandez@st.com> Acked-by: Peter Griffin <peter.griffin@linaro.org>
2016-09-16ARM: dts: STiH410: Enable clock propagation for audio clocksGabriel Fernandez
This patch is used in the clock driver to apply a clock propagation flag on the audio clocks of STiH410 Signed-off-by: Olivier Bideau <olivier.bideau@st.com> Signed-off-by: Gabriel Fernandez <gabriel.fernandez@st.com> Acked-by: Peter Griffin <peter.griffin@linaro.org>
2016-09-16ARM: dts: STiH4xx: Simplify clock binding of STiH4xx platformsGabriel Fernandez
This patch simplifies the clock binding because we had too much detail. Signed-off-by: Gabriel Fernandez <gabriel.fernandez@st.com>
2016-07-12ARM: sti: stih410-clocks: Identify critical clocksLee Jones
Lots of platforms contain clocks which if turned off would prove fatal. The only way to recover is to restart the board(s). This driver takes references to clocks which are required to be always-on. The Common Clk Framework will then take references to them. This way they will not be turned off during the clk_disabled_unused() procedure. In this patch we are identifying clocks, which if gated would render the STiH410 development board unserviceable. Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-07-22ARM: STi: DT: Rename st_pll3200c32_407_c0_x into st_pll3200c32_cx_xGabriel Fernandez
Use a generic name for this kind of PLL Signed-off-by: Gabriel Fernandez <gabriel.fernandez@linaro.org> Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
2014-11-18ARM: STi: DT: STiH410: Add STiH410 SoC and b2120 board support.Peter Griffin
The STiH410 is an advanced multi-HD AVC processor with 3D graphics acceleration and 1.5-GHz ARM Cortex-A9 SMP CPU part of the stih407 family. It has wide connectivity including USB 3.0, PCI-e, SATA and gigabit ethernet. Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
