path: root/arch/arm/boot/dts/stih41x.dtsi
2013-08-04ARM: STi: Fix cpu nodes with correct device_type.Srinivas Kandagatla
This patch fixes cpu nodes with device_type = "cpu". This change was not necessary before 3.10-rc7. Without this patch STi SOCs does not boot as SMP. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-25ARM: sti: Add STiH415 SOC supportSrinivas Kandagatla
The STiH415 is the next generation of HD, AVC set-top box processors for satellite, cable, terrestrial and IP-STB markets. It is an ARM Cortex-A9 1.0 GHz, dual-core CPU. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> CC: Stephen Gallimore <stephen.gallimore@st.com> CC: Stuart Menefy <stuart.menefy@st.com> CC: Arnd Bergmann <arnd@arndb.de> CC: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Signed-off-by: Olof Johansson <olof@lixom.net>
