Enable the otg/drc usb controller on the Bananapi.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
sun7i-a20-bananapi.dts doesn't contain regulator nodes for the AXP209 PMU
driver, so add them to allow for voltage-scaling with cpufreq-dt. Also
add board-specific OPP to use slightly higher voltages at lower
frequencies since Kevin Hilman reported that not all BananaPi boards run
stable at the default voltages inherited by sun7i-a20.dtsi.
Signed-off-by: Timo Sigurdsson <public_timo.s@silentcreek.de>
The pinctrl groups for SPI until now were also adding the chip selects in
the SPI pinctrl group.
This was causing a few issues, since a board was forced to use a random
number of chipselects, even though it might use one of these chip selects
for another pin.
The number of chipselects defined was also not the same from one group to
another because of different needs at the time these groups have been
introduced, resulting in no clear view from the board DTS on what exactly
is being muxed, which even might change in the future.
Solve this by creating different pinctrl groups for the chipselects and the
standard SPI pins (CLK, MOSI and MISO) so that we fix both issues.
The FSF address triggers a warning on checkpatch, saying that the FSF
license is already present in the Linux source code, and that it has
already changed in the past.
Remove it from our DT, as suggested.
Currently none of the target boards nor the driver supports
IR TX. However this pin is used in a few instances as a GPIO.
Split the pin ctrl descriptions so that only the IR RX is
configured to be used.
Signed-off-by: Marcus Cooper <codekipper@gmail.com>
Add UART aliases and stdout-path property for all the Allwinner boards so that
we won't have to rely on the bootargs' console= value, while working with
legacy bootloaders.
While we're at it, also remove the mentions of earlyprintk in the bootargs,
that will remove our default bootargs entirely, and allow the kernel to boot on
a system even if DEBUG_LL is configured for another system.
In order to lessen the amount of duplication of the DT tree, ease the
new and follow the trend that prefers to use label based references
when overriding DTSI nodes, convert the board to this syntax
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
Commit f77d55a3b56a ("serial: 8250_dw: get index of serial line from DT
aliases") made the serial driver now use the serial aliases to get the tty
number, pointing out that our aliases have been wrong all along.
Remove them from the DTSI and add custom ones in the relevant boards.
The NMI IRQ controller uses the standard flags definition for the IRQ level and
edges.
Use the common header to use defines instead of opaque numbers.
The pinctrl nodes require some extra opaque arguments for the pull up and drive
strength values.
Introduce a new header file and convert the device trees to replace these
opaque numbers by defines.
Replace the various raw GPIO flags by their definition in the common
dt-bindings header.
Prepare the device trees to use the C preprocessor.
On the LeMaker Banana Pi, probing the external ethernet PHY connected
to the SoC's internal GMAC module sometimes fails. The PHY power
supply is handled via a GPIO-controlled regulator, and the existing
regulator startup-delay of 50000us is too short to make sure that the
PHY is always fully powered up when it is queried by phylib. Tests
have shown that to provide a reliable PHY detection, the startup-delay
has to be increased to at least 60000us. To have a certain safety margin
and to cater for manufacturing variations between different boards,
the delay gets set to 100000us as discussed on the linux-arm-kernel
mailinglist.
Signed-off-by: Karsten Merker <merker@debian.org>
Acked-by: Hans de Goede <hdegoede@redhat.com>
During the GPL to GPL/X11 licensing migration, the GPL notice introduced
mentionned the device trees as a library, which is not really accurate. It
began to spread by copy and paste. Fix all these library mentions to reflect
the file that it's actually just a file.
The Banana Pi is an A20 based development board using Raspberry Pi compatible
IO headers. It comes with 1 GB RAM, 1 Gb ethernet, 2x USB host, sata, hdmi
and stereo audio out + various expenansion headers:
http://www.lemaker.org/
