The current GPL only licensing on the DTSI makes it very impractical for other
software components licensed under another license.
In order to make it easier for them to reuse our device trees, relicense our
device trees under a GPL/X11 dual-license.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Alexander Bersenev <bay@hackerdom.ru>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Carlo Caione <carlo@caione.org>
Acked-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Hans de Goede <hdegoede@redhat.com>
Acked-by: Olliver Schinagl <oliver@schinagl.nl>
This patch adds the regulator nodes for the axp209 by including
the axp209 dtsi. As the inputs of these regulators are from the
axp209's PS output, which is basically just a mux over the 2
inputs, it is considered to be unregulated. Thus we do not provide
input supply properties for them.
The regulator names and constraints are based on the board
schematics and the SoC datasheet.
DCDC2 is used as the cpu power supply. This patch also references
it from the cpu node.
Also get rid of axp209 properties already set in axp209.dtsi.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
The NMI IRQ controller uses the standard flags definition for the IRQ level and
edges.
Use the common header to use defines instead of opaque numbers.
The pinctrl nodes require some extra opaque arguments for the pull up and drive
strength values.
Introduce a new header file and convert the device trees to replace these
opaque numbers by defines.
Replace the various raw GPIO flags by their definition in the common
dt-bindings header.
Prepare the device trees to use the C preprocessor.
Signed-off-by: Roman Byshko <rbyshko@gmail.com>
Cubietruck uses different pin for the USB OTG VBUS that
is why we override the one defined in sunxi-common-regulators.dtsi
At a node for the axp209, and where necessary the i2c controller to the dts
for various boards. Note the axp209 regulators are omitted as we don't have
any use for them yet, and on some boards were not sure how exactly they are
wired up.
Adding support for just the axp209 without the regulators is still useful, as
it will give us power-button and poweroff support.
Signed-off-by: Carlo Caione <carlo@caione.org>
[hdegoede@redhat.com: Drop the regulator bits for now]
This patch enables two IR devices in dts:
- One IR device physically found on Cubieboard 2
- One IR device physically found on Cubietruck
Signed-off-by: Alexander Bersenev <bay@hackerdom.ru>
Signed-off-by: Alexsey Shestacov <wingrime@linux-sunxi.org>
bus-width defaults to 1, and all 4 lines are hooked up at the cubietruck,
properly set bus-width to 4.
The CubieTruck has an AMPAK AP6210 WiFi+Bluetooth module. The WiFi
part is a BCM43362 IC connected to MMC3 in the A20 SoC via SDIO.
The IC also takes a power enable signal via GPIO.
The WiFi module supports out-of-band interrupt signaling via GPIO,
but this is not supported in this patch.
The cd pin settings have been taken from the original firmware fex files,
and have been confirmed to work on the actual boards.
Enable the PWM for both PWM channels on the cubietruck. They can be found on
connector CN8.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Add nodes for the usb-phy and ehci- and ohci-usb-host controllers.
This patch adds sunxi sata support to A20 boards that have such a connector.
Some boards also feature a regulator via a GPIO and support for this is also
added.
Signed-off-by: Olliver Schinagl <oliver@schinagl.nl>
The CubieTruck uses the GMAC with an RGMII phy.
The Cubietruck makes use of the first three i2c controllers found on the
Allwinner A20; i2c-0 is used internally for the PMIC, i2c-1 is exposed on
the board headers, and i2c-2 is used for DDC on the VGA connector. This
patch enables them in the device tree.
Cubietech introduced a new cubieboard, the CubieTruck. This board added
more output connectors and features 2 GiB of RAM and a Gigabit PHY.
Tested are are uart0 and LEDS which both work as expected.
Signed-off-by: Oliver Schinagl <oliver@schinagl.nl>
