The Olimex A20 OLinuXino Lime features an eeprom that is always on the
board. This patch adds it to the dts.
Signed-off-by: Olliver Schinagl <oliver@schinagl.nl>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Enable the otg/drc usb controller on the A20-OLinuxIno-Lime.
The FSF address triggers a warning on checkpatch, saying that the FSF
license is already present in the Linux source code, and that it has
already changed in the past.
Remove it from our DT, as suggested.
Add UART aliases and stdout-path property for all the Allwinner boards so that
we won't have to rely on the bootargs' console= value, while working with
legacy bootloaders.
While we're at it, also remove the mentions of earlyprintk in the bootargs,
that will remove our default bootargs entirely, and allow the kernel to boot on
a system even if DEBUG_LL is configured for another system.
In order to lessen the amount of duplication of the DT tree, ease the
new and follow the trend that prefers to use label based references
when overriding DTSI nodes, convert the board to this syntax
The NMI IRQ controller uses the standard flags definition for the IRQ level and
edges.
Use the common header to use defines instead of opaque numbers.
The pinctrl nodes require some extra opaque arguments for the pull up and drive
strength values.
Introduce a new header file and convert the device trees to replace these
opaque numbers by defines.
Replace the various raw GPIO flags by their definition in the common
dt-bindings header.
Prepare the device trees to use the C preprocessor.
The current GPL only licensing on the DTSI makes it very impractical for other
software components licensed under another license.
In order to make it easier for them to reuse our device trees, relicense our
device trees under a GPL/X11 dual-license.
Acked-by: FUKAUMI Naoki <naobsd@gmail.com>
This patch adds support for Olimex A20-OLinuXino-LIME board.
Signed-off-by: FUKAUMI Naoki <naobsd@gmail.com>
