When the gpio interrupt bindings where changed to add a bank to the
specifier list, the r_pio nodes of A23/A31/A33 where not updated to
match and neither was the pio node of the A80, this fixes this.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The NMI interrupt controller is in charge of the NMI pin exposed by
the SoC to the PMIC. The PMIC signals interrupts through this.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
This patch adds a device node for the Reduced Serial Bus (RSB)
controller and the defacto pinmux setting to the A23/A33 dtsi.
Since there is only one possible pinmux setting for RSB, just
set it in the dtsi.
The AHB1 gates were assumed to be identical between the A23 and the A33,
which turned out to be wrong. Move the A23 gates definition to the A23
DTSI.
Reported-by: Chen-Yu Tsai <wens@csie.org>
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
The PWM controller has 2 outputs, with one usable pin for each.
Add a pinmux setting for the first channel. This is often used
for backlight dimming on tablets.
A23/A33 have a PWM controller that is compatible to the one on the A20.
Add a device node for it.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Pull ARM DT updates from Olof Johansson:
"Ladies and gentlemen, we proudly announce to you the latest branch of
ARM device tree contents for the mainline kernel. Come and see, come
and see!
No less than twentythree thousand lines of additions! Just imagine the
joy you will have of using your mainline kernel on newly supported
hardware such as Rockchip Chromebooks, Freescale i.MX6UL boards or
UniPhier hardware!
For those of you feeling less adventurous, added hardware support on
platforms such as TI DM814x and Gumstix Overo platforms might be more
of your liking.
We've got something for everyone here!
Ahem. Cough. So, anyway...
This is the usual large batch of DT updates. Lots and lots of smaller
changes, some of the larger ones to point out are:
- Rockchip veyron (Chromebook) support, as well as several other new boards
- DRM support on Atmel AT91SAM9N12EK
- USB additions on some Allwinner platforms
- Mediatek MT6580 support
- Freescale i.MX6UL support
- cleanups for Renesas shmobile platforms
- lots of added devices on LPC18xx
- lots of added devices and boards on UniPhier
There's also some dependent code added here, in particular some
branches that are primarily merged through the clock tree"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (389 commits)
ARM: tegra: Add gpio-ranges property
ARM: tegra: Fix AHB base address on Tegra20, Tegra30 and Tegra114
ARM: tegra: Add Tegra124 PMU support
ARM: tegra: jetson-tk1: Add GK20A GPU DT node
ARM: tegra: venice2: Add GK20A GPU DT node
ARM: tegra: Add IOMMU node to GK20A
ARM: tegra: Add CPU regulator to the Jetson TK1 device tree
ARM: tegra: Add entries for cpufreq on Tegra124
ARM: tegra: Enable the DFLL on the Jetson TK1
ARM: tegra: Add the DFLL to Tegra124 device tree
ARM: dts: zynq: Add devicetree entry for Xilinx Zynq reset controller.
ARM: dts: UniPhier: fix PPI interrupt CPU mask of timer nodes
ARM: dts: rockchip: correct regulator power states for suspend
ARM: dts: rockchip: correct regulator PM properties
ARM: dts: vexpress: Use assigned-clock-parents for sp810
pinctrl: tegra: Only set the gpio range if needed
arm: boot: dts: am4372: add ARM timers and SCU nodes
ARM: dts: AM4372: Add the am4372-rtc compatible string
ARM: shmobile: r8a7794 dtsi: Add CPG/MSTP Clock Domain
ARM: shmobile: r8a7793 dtsi: Add CPG/MSTP Clock Domain
The A23 and A33 gates have a non continuous set of clock IDs that are
valid. Add the clock-indices property to the DT to express this.
Signed-off-by: Michael Turquette <mturquette@baylibre.com>
The current DTs were setting the cell size to 2, but used the default xlate
function that was assuming an interrupt cell size of 1, leading to the
second part of the cell (the flags) being ignored, while we were having an
inconsistent binding between the interrupts and gpio (that could also be
used as interrupts).
That "binding" doesn't work either with newer SoCs that have multiple irq
banks.
Now that we fixed the pinctrl driver to handle this like it should always
have been handled, convert the DT users, and while we're at it, remove the
size-cells property of PIO that is completely useless.
A23/A33 has one pair of EHCI/OHCI USB controllers. There are 2 USB PHYs,
one for the USB OTG controller, one for the EHCI/OHCI pair. The latter
may also support HSIC, though none of the available boards utilize this,
so this is not supported yet.
mmc2 is mostly used with eMMC flash chips, as an alternative to
raw NAND flash chips. 8 bit mmc is commonly used.
Add an usb_clk node for a23/a33.
Rename sun8i-a23.dtsi to sun8i-a23-a33.dtsi as the base dtsi for the A33
is 99% the same and add a new sun8i-a23.dtsi including sun8i-a23-a33.dtsi
and setting the few things not shared with the A33 (mbus-clk, pio
compatible and interrupts).
Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com>
Tested-by: Chen-Yu Tsai <wens@csie.org>
