There are general changes pending to make the /aliases/serial* entries
number the serial ports on the system. On Tegra, so far the ports have
been just numbered dynamically as they are configured so that makes them
change.
To avoid this, add specific aliases per board to keep the old numbers.
This allows us to change the numbering by default on future SoCs while
keeping the numbering on existing boards.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Dalmore can detect write-protect on the SD card. Add the required
DT entries to allow this.
The 1.2V supply for CSI and DSI was previously marked always-on. This is
suboptimal because it prevents the supply from being disabled when there
is no activity in the display or capture paths that it powers.
Hook up the regulator to the DSI output and mark it as not always-on, so
that it will only be enabled when DSI actually needs it.
This supply controls the +5V pin on the HDMI connector, which in turn is
used by attached sinks to return the hotplug detect signal.
Pull ARM SoC device tree changes from Arnd Bergmann:
"A large part of the arm-soc patches are nowadays DT changes, adding
support for new SoCs, boards and devices without changing kernel
source. The plan is still to move the devicetree files out of the
kernel tree and reduce the amount of churn going on here, but we keep
finding reasons to delay doing that.
Changes are really all over the place, with little sticking out
particularly. We have contributions from a total of 116 people in
this branch.
Unfortunately, the size of this branch also causes a significant
number of conflicts at the moment, typically when subsystem
maintainers merge patches that change the driver at the same time as
the dts files. In most cases this could be avoided because the dts
changes are supposed to be compatible in both ways, and we are asking
everyone to send ARM dts changes through our tree only"
* tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (541 commits)
dts: stmmac: Document the clocks property in the stmmac base document
dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac.
ARM: STi: stih41x: Add support for the FSM Serial Flash Controller
ARM: STi: stih416: Add support for the FSM Serial Flash Controller
ARM: tegra: fix Dalmore pinctrl configuration
ARM: dts: keystone: use common "ti,keystone" compatible instead of -evm
ARM: dts: k2hk-evm: set ubifs partition size for 512M NAND
ARM: dts: Build all keystone dt blobs
ARM: dts: keystone: Fix control register range for clktsip
ARM: dts: keystone: Fix domain register range for clkfftc1
ARM: dts: bcm28155-ap: leave camldo1 on to fix reboot
ARM: dts: add bcm590xx pmu support and enable for bcm28155-ap
ARM: dts: bcm21664: Add device tree files.
ARM: DT: bcm21664: Device tree bindings
ARM: efm32: properly namespace i2c location property
ARM: efm32: fix unit address part in USART2 device nodes' names
ARM: mvebu: Enable NAND controller in Armada 385-DB
ARM: mvebu: Add support for NAND controller in Armada 38x SoC
ARM: mvebu: Add the Core Divider clock to Armada 38x SoCs
ARM: mvebu: Add a 2 GHz fixed-clock on Armada 38x SoCs
Neither Tegra114 nor Tegra124 allow "low power mode" to be configured
on SDIO1 or SDIO3 drive groups. Remove the attempt to configure that
option from the Dalmore and Venice2 DTs.
The Venice2 DT contained duplicate configurations for most sdmmc1_*
pins. Remove the duplicate pins from one of the nodes, and fix the
configuration since the remaining clk pin is output-only.
Remove some entries from Dalmore's device tree that attempt to set some
options which aren't supported for the drive_gma pin group.
There are a number of revisions of the Dalmore board, each with a variety
of incompatible SW-visible HW changes. The Dalmore DT file in the kernel
only supports HW revision A04. Document this in the DT file.
Reported-by: Paul Walmsley <pwalmsley@nvidia.com>
Reviewed-by: Thierry Reding <treding@nvidia.com>
Add HDMI node to the Dalmore device tree and hook up the VDD and PLL
regulators as well as the I2C adapter used for DDC and the GPIO used
for hotplug detection.
Signed-off-by: Mikko Perttunen <mperttunen@nvidia.com>
Dalmore has a 10.1" WUXGA panel connected to one of the DSI outputs of
the Tegra114.
This ensures that the PMIC RTC provides the system time, rather than
the on-SoC RTC, which is not battery-backed.
tegra124-venice2.dts isn't touched yet since we haven't added any off-
SoC RTC device to its device tree.
Use Tegra pinconrol dt-binding macro to set the values of different pinmux
properties of Tegra114 platforms.
DT node names should include a unit address iff the node has a reg
property. For Tegra DTs at least, we were previously applying a different
rule, namely that node names only needed to include a unit address if it
was required to make the node name unique. Consequently, many unit
addresses are missing. Add them.
Enable thermal sensor nct1008 for Tegra114 dalmore.
Signed-off-by: Wei Ni <wni@nvidia.com>
In place of hardcoding the key code in DTS file and comment the
key code as side notes, use the key code macro defines in the
dt-bindings/input/input.h directly.
Add Palmas pincontrol to Dalmore device tree and make following
configuration as default:
- Disable DVFS1 and DVFS2.
- Set GPIO6 to gpio mode.
Add DT property to tell the regulator to register pm_power_off to make
"shutdown" work.
Signed-off-by: Bill Huang <bilhuang@nvidia.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
This enables the microphone input jack, and hence allows audio to be
captured as well as played back.
Device tree entries for the three EHCI controllers on Tegra114.
Enables the the third controller (USB host) on Dalmore.
Enabling the LP1 suspend mode for Tegra devices.
Tested-by: Marc Dietrich <marvin24@gmx.de> # paz00 board
Signed-off-by: Joseph Lo <josephl@nvidia.com>
The IRQ trigger type of Palmas MFD device (tps65913) is designed as
low-level sensitive on Dalmore. The wrong configuration would cause an
interrupt storm when booting the system. Fixing it in DT with appropriate
interrupt type.
Cc: Laxman Dewangan <ldewangan@nvidia.com>
Adding the PM configurations for PMC to support platform suspend.
Make the entry of Dalmore Power Management Unit device TPS65913
in dalmore DTS file. The Palma driver support this device.
Enable following submodule of the TPS65913:
- GPIO driver
- RTC driver.
- Power regulator driver.
[swarren, fixed indentation and DT node sort order]
Dalmore have the keys mounted on board which are connected
to different pins of Tegra.
Add the keys entry in DTS file to enable key functionality.
This will enable KEY_POWER, KEY_HOME, KEY_VOLUMEUP and
KEY_VOLUMEDOWN.
Dalmore uses the RT5640 audio CODEC. Instantiate this on the I2C bus.
Enable the relevant Tegra I2C controller. Add the top-level "sound" node
to hook everything together, and provide a "sound card" device.
The power supply core now supports detecting linkages between batteries
and chargers through the use of the power-supplies property. Adding
this to the battery, the core will use the phandle list to find
the associated charger and pair them up. This facilitates notifications
from the charger to the battery when ac power is dissconnected
or connected for instance.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
The charger is now represented by a distinct subnode of the tps65090
device. Add this node and enable low current charging with it.
Use the GIC and standard IRQ binding defines in all IRQ specifiers.
Use TEGRA_GPIO() macro to name all GPIOs referenced by GPIO properties,
and some interrupts properties. Use standard GPIO flag defines too.
Replace /include/ (dtc) with #include (C pre-processor) for all Tegra DT
files, so that gcc -E handles the entire include tree, and hence any of
those files can #include some other file e.g. for constant definitions.
This allows future use of #defines and header files in order to define
names for various constants, such as the IDs and flags in GPIO
specifiers. Use of those features will increase the readability of the
device tree files.
Enable SPI4 and add Winbond SPI flash W25Q32DW device
on CS0 line.
This patch adds "non-removable" property of MMC host where the eMMC device
is for Tegra platform.
And the "keep-power-in-suspend" property was used for the SDIO device that
need this to go into suspend mode (e.g. BRCM43xx series).
Set "regulator-always-on" for the SD slot on Dalmore, so that SD cards
work. This used to work, since this regulator is on by default, but was
broken by commit "ARM: tegra: dalmore: add TPS65090 node", since that
didn't specify always-on for this regulator.
In the long run, the regulators should all be hooked up to the SDHCI
device nodes. However, we haven't done that for any of the Tegra boards
yet, so to be consistent, this patch simply forces the regulator on,
rather than hooking it up and making it work differently to other boards.
Reported-by: Rhyland Klein <rklein@nvidia.com>
Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
NVIDIA's Tegra114 reference platform Dalmore has voltage switch
regulators which are controlled by the Tegra GPIOs.
Add DT node for fixed regulators.
NVIDIA's Tegra114 reference platform, Dalmore, uses the TPS65090 as
secondary PMICs which is mainly act as voltage switch regulator
controlled by i2c communication.
Add DT node for TPS65090.
[swarren: remove unit-address from node name since it's unique already]
Dalmore uses the TPS51632 as CPU regulator. The device is connected
on I2C5.
Add DT node for TPS51632.
This patch adds the node for the bq20z45 I2C gas gauge which is
compatible with the sbs-battery power supply driver.
Dalmore has a built-in eMMC device and a user-accessible SD card slot.
Add device tree nodes to enable these.
Based on changes by: Pritesh Raithatha <praithatha@nvidia.com>
[swarren: added commit description, fixed DT node sort order]
This change adds the default pinctrl nodes for the Dalmore Tegra114
platform.
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
[Rhyland added patch description]
[swarren: fixed DT node sort order]
Add references to tegra_car clocks for the basic device nodes. Also remove
the clock-frequency property of the serial node as the UART driver can now
use the clock framework to obtain the frequency.
Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Acked-by: Mike Turquette <mturquette@linaro.org>
Adding the bindings of the clock source of PMC in DT.
Add a new evaluation board, Dalmore for Tegra 114 family.
Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com>
