path: root/arch/arm/boot/dts/tegra114-roth.dts
2014-11-13ARM: tegra: roth: Fix SD card VDD_IO regulatorAlexandre Courbot
vddio_sdmmc3 is a vdd_io, and thus should be under the vqmmc-supply property, not vmmc-supply. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-11-13ARM: tegra: Remove eMMC vmmc property for roth/tn7Alexandre Courbot
This property was wrong and broke eMMC since commit 52221610d ("mmc: sdhci: Improve external VDD regulator support"). Align the eMMC properties to those of other Tegra boards. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-11-13ARM: dts: tegra: move serial aliases to per-boardOlof Johansson
There are general changes pending to make the /aliases/serial* entries number the serial ports on the system. On Tegra, so far the ports have been just numbered dynamically as they are configured so that makes them change. To avoid this, add specific aliases per board to keep the old numbers. This allows us to change the numbering by default on future SoCs while keeping the numbering on existing boards. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17ARM: tegra: roth: add display DT nodeAlexandre Courbot
Tegra DSI support has been fixed to support continuous clock behavior that the panel used on SHIELD requires, so finally add its device tree node since it is functional. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17ARM: tegra: roth: enable input on mmc clock pinsAlexandre Courbot
Input had been disabled by mistake on these pins, leading to issues with SDIO devices like the Wifi module not being probed or random errors occuring on the SD card. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-07-17ARM: tegra: roth: fix unsupported pinmux propertiesAlexandre Courbot
The pinmux subsystem complained that the nvidia,low-power-mode property is not supported by the sdio1, sdio3 and gma drive groups. In addition gma also does not support nvidia,drive-type. Remove these properties so the pinmux configuration can properly be applied. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-05-12ARM: tegra: add device tree for SHIELDAlexandre Courbot
NVIDIA SHIELD is a portable Android console containing a Tegra 4 SoC with 2GB RAM and a 720p panel. The following hardware is enabled by this device tree: UART, eMMC, USB (needs external power), PMIC, backlight, joystick, SD card, GPIO keys. DSI panel, HDMI output, charger, self-powered USB, audio, wifi bluetooth are not supported yet but might be by future patches (likely in that order). Touch panel and sensors will probably never be supported. Initrd addresses are hardcoded to match the static values used by the bootloader, since it won't add them for us. All the same, a kernel command-line is provided to replace the one passed by the bootloader which is filled with garbage. NVIDIA SHIELD is typically booted with an appended DTB to avoid modifications made by the bootloader. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> [swarren, fixed gpio-keys child node sort order, patch description] Signed-off-by: Stephen Warren <swarren@nvidia.com>
