path: root/arch/arm/boot/dts/tegra124-venice2.dts
2013-12-20ARM: tegra: Enable power key on Venice2Thierry Reding
Contrary to the rest of the keyboard, which is connected to the ChromeOS embedded controller, the power key is hooked up to a GPIO. Add a device tree node to handle it. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-12-20ARM: tegra: Enable Venice2 keyboardThierry Reding
The keyboard on Venice2 is attached to the ChromeOS embedded controller. Add the corresponding device tree nodes and use the MATRIX_KEY define to encode keycodes. Signed-off-by: Rhyland Klein <rklein@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-12-19ARM: tegra: set up /aliases for RTCs on Venice2Stephen Warren
This ensures that the PMIC RTC provides the system time, rather than the on-SoC RTC, which is not battery-backed. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-12-19ARM: tegra: add ams AS3722 device to Venice2 DTLaxman Dewangan
Add ams AS3722 entry for gpio/pincontrol and regulators to venice2 DT. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-12-19ARM: tegra: fix missing pincontrol configuration for Venice2Laxman Dewangan
Compare the initial population of default pinmux configuration of Venice2 with the chrome branch and add/fix the missing configurations. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-12-16ARM: tegra: Fix misconfiguration of pin PH2 on Venice2Thierry Reding
This pin needs to be configured in pull-down, non-tristate mode in order for the backlight to work correctly. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-12-16ARM: tegra: fix pinctrl misconfiguration on Venice2Stephen Warren
Other boards use PULL_NONE for their debug UART pins, and without this change, the board doesn't accept any serial input. Don't set the I2S port pins to tristate mode, or no audio signal will be sent out. Fixes: 605ae5804385 ("ARM: tegra: add default pinctrl nodes for Venice2") Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-12-16ARM: tegra: add default pinctrl nodes for Venice2Laxman Dewangan
Add the default pinmux configuration for the Tegra124 based Venice2 platform. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-12-16ARM: tegra: Enable PWM on Venice2Thierry Reding
Subsequent patches will need to reference a PWM channel for backlight support, so enable the PWM device and assign a label to it. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-12-16ARM: tegra: add sound card to Venice2 DTStephen Warren
Venice2 uses the MAX98090 audio CODEC, and supports built-in speakers, and a combo headphones/microphone jack. Add a top-level sound card node to represent this. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-12-16ARM: tegra: enable I2C controllers on Venice2Stephen Warren
Enable all the I2C controllers that are wired up on Venice2. I don't know the correct I2C bus clock rates, so set them all to a conservative 100KHz for now. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-12-16ARM: tegra: add MMC controllers to Tegra124 DTStephen Warren
Tegra124 has 4 MMC controllers just like previous versions of the SoC. Note that there are some non-backwards-compatible HW differences, and hence a new DT compatible value must be used to describe the HW. Also enable the relevant controllers in the Venice2 board DT. power-gpios property suggested by Thierry Reding. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Tested-by: Thierry Reding <treding@nvidia.com>
2013-12-16ARM: tegra: add clock properties for devices of Tegra124Joseph Lo
This patch adds clock properties for devices in the DT for basic support of Tegra124 SoC. Signed-off-by: Joseph Lo <josephl@nvidia.com> [swarren, added missing unit address to "clock" node] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-10-11ARM: tegra: enable LP1 suspend mode for Venice2Joseph Lo
Enable LP1 suspend mode for Tegra124 Venice2 board. Signed-off-by: Joseph Lo <josephl@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-10-08ARM: tegra: add Venice2 board supportJoseph Lo
Add support for the Tegra124 based Venice2 reference board. Signed-off-by: Joseph Lo <josephl@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
