path: root/arch/arm/boot/dts/tegra20-plutux.dts
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17ARM: tegra: tamonten: add the base board regulatorsAlban Bedel
Currently the Tamonten DTS define a fixed regulator for the 5V supply. However this regulator is in fact on the base board. Fix this by properly defining the regulators found on the base boards. Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-12-16ARM: tegra: add missing unit addresses to DTStephen Warren
DT node names should include a unit address iff the node has a reg property. For Tegra DTs at least, we were previously applying a different rule, namely that node names only needed to include a unit address if it was required to make the node name unique. Consequently, many unit addresses are missing. Add them. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-05-28ARM: tegra20: convert device tree files to use CLK definesHiroshi Doyu
Use the Tegra20 CAR binding header (tegra20-car.h) to replace magic numbers in the device tree. For example, - clocks = <&tegra_car 28>; + clocks = <&tegra_car CLK_HOST1X>; Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com> [swarren, updated since tegra20-car.h moved for consistency] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-05-28ARM: tegra: convert device tree files to use IRQ definesStephen Warren
Use the GIC and standard IRQ binding defines in all IRQ specifiers. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-05-28ARM: tegra: convert device tree files to use GPIO definesStephen Warren
Use TEGRA_GPIO() macro to name all GPIOs referenced by GPIO properties, and some interrupts properties. Use standard GPIO flag defines too. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-05-28ARM: tegra: use #include for all device treesStephen Warren
Replace /include/ (dtc) with #include (C pre-processor) for all Tegra DT files, so that gcc -E handles the entire include tree, and hence any of those files can #include some other file e.g. for constant definitions. This allows future use of #defines and header files in order to define names for various constants, such as the IDs and flags in GPIO specifiers. Use of those features will increase the readability of the device tree files. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-04-04clk: tegra: Fix cdev1 and cdev2 IDsPrashant Gaikwad
Correct IDs for cdev1 and cdev2 are 94 and 93 respectively. Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com> [swarren: split into separate driver and device-tree patches] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-04-04ARM: tegra: add clocks property to sound nodesStephen Warren
Audio-related clocks need to be represented in the device tree. Update bindings to describe which clocks are needed, and DT files to include those clocks. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-16ARM: tegra: plutux: Enable HDMI outputThierry Reding
Enable the HDMI output found on Plutux boards. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-20ARM: tegra: Add Avionic Design Plutux supportThierry Reding
The Plutux is a set-top box device based on the Tamonten SOM and can be connected to a display via HDMI. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Stephen Warren <swarren@nvidia.com>
