The Tegra20 CAR (Clock And Reset) Controller controls most aspects of
most clocks within Tegra20. The device tree binding models this as a
single monolithic clock provider, which exports many clocks. This reduces
the number of nodes needed in device tree to represent these clocks.
This binding is only useful for Tegra20; the set of clocks that exists on
Tegra30 is sufficiently different to merit its own binding.
[pgaikwad: Added mux clk ids and sorted CAR node]
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Add CPU node for Tegra20.
Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com>
Reviewed-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
This will allow timer.c to use twd_local_timer_of_register(), and
hence not need to hard-code the TWD address or IRQ.
The Tegra RTC maintains seconds and milliseconds counters, and five alarm
registers. The alarms and other interrupts may wake the system from
low-power state.
Define a DT binding for this HW module, and add the module into the Tegra
device tree files.
The Tegra timer provides a number of 29-bit timer channels, a single
32-bit free running counter, and in the Tegra30 variant, 5 watchdog modules.
The first two channels may also trigger a legacy watchdog reset.
device tree files.
Add the host1x node along with its children to the Tegra20 DTSI. Board-
specific DTS files are expected to enable the available outputs and
complement the device tree with data specific to the hardware.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Nvidia's Tegra20 have the SPI (SFLASH) controller to
interface with spi flash device which is used for system
boot. Add DT entry for this controller.
[swarren: move sflash node to keep file sorted]
Add slink controller details in the dts file of
Tegra20 and Tegra30.
Add L2 cache controller binding into DT for Tegra.
Signed-off-by: Joseph Lo <josephl@nvidia.com>
Unit addresses, whilst written in hex, don't contain a 0x prefix.
Reviewed-by: Thierry Reding <thierry.reding@avionic-design.de>
PWM devices can be referenced in the DT by phandle and per-chip index.
In order for this to work properly, the PWM controller needs to have a
label attached to it.
Pull PWM subsystem from Thierry Reding:
"The new PWM subsystem aims at collecting all implementations of the
legacy PWM API and to eventually replace it completely.
The subsystem has been in development for over half a year now and
many drivers have already been converted. It has been in linux-next
for a couple of weeks and there have been no major issues so I think
it is ready for inclusion in your tree."
Arnd Bergmann <arnd@arndb.de>:
"Very much Ack on the new subsystem. It uses the interface
declarations as the previously separate pwm drivers, so nothing
changes for now in the drivers using it, although it enables us to
change those more easily in the future if we want to.
This work is also one of the missing pieces that are required to
eventually build ARM kernels for multiple platforms, which is
currently prohibited (amongs other things) by the fact that you cannot
have more than one driver exporting the pwm functions."
Tested-and-acked-by: Alexandre Courbot <acourbot@nvidia.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Philip, Avinash <avinashphilip@ti.com> # TI's AM33xx platforms
Acked-By: Alexandre Pereira da Silva <aletes.xgr@gmail.com> # LPC32XX
Acked-by: Sachin Kamat <sachin.kamat@linaro.org>
Fix up trivial conflicts with other cleanups and DT updates.
* 'for-3.6' of git://gitorious.org/linux-pwm/linux-pwm: (36 commits)
pwm: pwm-tiehrpwm: PWM driver support for EHRPWM
pwm: pwm-tiecap: PWM driver support for ECAP APWM
pwm: fix used-uninitialized warning in pwm_get()
pwm: add lpc32xx PWM support
pwm_backlight: pass correct brightness to callback
pwm: Use pr_* functions in pwm-samsung.c file
pwm: Convert pwm-samsung to use devm_* APIs
pwm: Convert pwm-tegra to use devm_clk_get()
pwm: pwm-mxs: Return proper error if pwmchip_remove() fails
pwm: pwm-bfin: Return proper error if pwmchip_remove() fails
pwm: pxa: Propagate pwmchip_remove() error
pwm: Convert pwm-pxa to use devm_* APIs
pwm: Convert pwm-vt8500 to use devm_* APIs
pwm: Convert pwm-imx to use devm_* APIs
pwm: Conflict with legacy PWM API
pwm: pwm-mxs: add pinctrl support
pwm: pwm-mxs: use devm_* managed functions
pwm: pwm-mxs: use global reset function stmp_reset_block
pwm: pwm-mxs: encode soc name in compatible string
pwm: Take over maintainership of the PWM subsystem
Add auxdata to instantiate the PWFM controller from a device tree,
include the corresponding nodes in the dtsi files for Tegra 20 and
Tegra 30 and add binding documentation.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
This patches fixes some status = "disable" strings to "disabled", the correct
way of disabling nodes in the devicetree.
Just the tegra part here. Everything else goes via other patches and trees.
Signed-off-by: Roland Stigge <stigge@antcom.de>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Use a more plain english name.
Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com>
[swarren: also rename the node in tegra-seaboard.dts]
[swarren: remove redundant unit address from tegra30.dtsi change]
In tegra*.dtsi, set status="disable" for all HW modules that the board
design may choose not to use. Update all boards to specifically enable
any of those modules that are useful by setting status="okay".
This makes board files say which features they do use, rather than which
they don't, which feels more logical. It also makes the .dts files
slightly smaller, at least for existing content.
Acked-by: Olof Johansson <olof@lixom.net>
Put properties in order compatible, reg, interrupts, then anything else
the node has.
Sort the nodes according to the following rules:
* First, any overrides for properties or nodes created by included files,
in the order they appeared in the include file.
* Second, any nodes with a reg property, in numerical order.
* Third, any nodes without a reg property, in alphabetical order of node
name.
The second sorting rule at least will probably help if/when we need to
explicitly insert nodes for the various busses in Tegra; that will just
be an indentation change rather than also a node re-ordering.
Place each reg "entry" on its own line, and wrap the whole list in
<> rather than each individual entry.
The convention chosen here is slightly arbitrary, but is not consistent
throughout all Tegra files.
DT node names only need to include the unit address if it's required to
make the node name unique. Remove the unnecessary unit addresses.
Consistently don't place a space after < or before >.
Add a node for the Tegra20 GART
Add Tegra MC(Memory Controller) nodes for tegra20.dtsi.
Add AHB entry for tegra20/30.
Pull "ARM: More device tree support updates" from Olof Johansson:
"This branch contains a number of updates for device tree support on
several ARM platforms, in particular:
* AT91 continues the device tree conversion adding support for a
number of on-chip drivers and other functionality
* ux500 adds probing of some of the core SoC blocks through device
tree
* Initial device tree support for ST SPEAr600 platforms
* kirkwood continues the conversion to device-tree probing"
Manually merge arch/arm/mach-ux500/Kconfig due to MACH_U8500 rename, and
drivers/usb/gadget/at91_udc.c due to header file include cleanups.
Also do an "evil merge" for the MACH_U8500 config option rename that the
affected RMI4 touchscreen driver in staging. It's called MACH_MOP500
now, and it was missed during previous merges.
* tag 'dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits)
ARM: SPEAr600: Add device-tree support to SPEAr600 boards
ARM: ux500: Provide local timer support for Device Tree
ARM: ux500: Enable PL022 SSP Controller in Device Tree
ARM: ux500: Enable PL310 Level 2 Cache Controller in Device Tree
ARM: ux500: Enable PL011 AMBA UART Controller for Device Tree
ARM: ux500: Enable Cortex-A9 GIC (Generic Interrupt Controller) in Device Tree
ARM: ux500: db8500: list most devices in the snowball device tree
ARM: ux500: split dts file for snowball into generic part
ARM: ux500: combine the board init functions for DT boot
ARM: ux500: Initial Device Tree support for Snowball
ARM: ux500: CONFIG: Enable Device Tree support for future endeavours
ARM: kirkwood: use devicetree for rtc-mv
ARM: kirkwood: rtc-mv devicetree bindings
ARM: kirkwood: fdt: define uart[01] as disabled, enable uart0
ARM: kirkwood: fdt: facilitate new boards during fdt migration
ARM: kirkwood: fdt: absorb kirkwood_init()
ARM: kirkwood: fdt: use mrvl ticker symbol
ARM: orion: wdt: use resource vice direct access
ARM: Kirkwood: Remove tclk from kirkwood_asoc_platform_data.
ARM: orion: spi: remove enable_clock_fix which is not used
Pull "ARM: device tree work" from Arnd Bergmann:
"Most of these patches convert code from using static platform data to
describing the hardware in the device tree. This is only the first
half of the changes for v3.4 because a lot of patches for this topic
came in the last week before the merge window.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>"
Fix up trivial conflicts in arch/arm/mach-vexpress/{Kconfig,core.h}
* tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (86 commits)
Document: devicetree: add OF documents for arch-mmp
ARM: dts: append DTS file of pxa168
ARM: mmp: append OF support on pxa168
ARM: mmp: enable rtc clk in pxa168
i2c: pxa: add OF support
serial: pxa: add OF support
arm/dts: mt_ventoux: very basic support for TeeJet Mt.Ventoux board
ARM: OMAP2+: Remove extra ifdefs for board-generic
ARM: OMAP2+: Fix build error when only ARCH_OMAP2/3 or 4 is selected
ASoC: DT: Add digital microphone binding to PAZ00 board.
ARM: dt: Add ARM PMU to tegra*.dtsi
ARM: at91: at91sam9x5cm/dt: add leds support
ARM: at91: usb_a9g20/dt: add gpio-keys support
ARM: at91: at91sam9m10g45ek/dt: add gpio-keys support
ARM: at91: at91sam9m10g45ek/dt: add leds support
ARM: at91: usb_a9g20/dt: add leds support
ARM: at91/pio: add new PIO3 features
ARM: at91: add sam9_smc.o to at91sam9x5 build
ARM: at91/tc/clocksource: Add 32 bit variant to Timer Counter
ARM: at91/tc: add device tree support to atmel_tclib
Tegra's USB1 port supports legacy mode, so mark it as such. Even if we
don't use it, we must turn it off in the driver.
This enables HW performance measurements, and usage of the "perf" tool.
Enhance the driver to dynamically allocate the base IRQ number, and
create an IRQ domain for itself. The use of an IRQ domain ensures that
any device tree node interrupts properties are correctly parsed.
Describe interrupt-related properties in the device tree binding docs,
and the contents of "child" node interrupts property.
Update tegra*.dtsi to specify the required interrupt-related properties.
Finally, remove the definition of TEGRA_GPIO_TO_IRQ; this macro no longer
gives correct results since the IRQ numbers for GPIOs are dynamically
allocated.
The Tegra PMC (Power Management Controller) interfaces with an external
PMU (Power Management Unit), and controls wake-up from sleep modes.
This initial binding is the bare minimum required to control the PMC's
inversion of the PMU's interrupt signal.
This will allow the sound node to refer to the I2S controllers by name
when creating phandles.
Adjust the dma-channel property name to match the binding implemented by
the driver. The binding was implemented and documented in a
separate change to the ASoC tree.
Document binding, and add the node to tegra*.dtsi.
The driver isn't actually instantiated from this node yet, but the I2S
binding will rely on being able to refer to the APB DMA node using a
phandle.
Device tree bindings for the EMC tables on tegra.
Update the device tree to indicate which I2C controller is the DVC
controller. AUXDATA needs to be updated too, since the compatible
value changed.
Convert tegra20 IRQ intialization to the GIC devicetree binding. Modify the
interrupt definitions in the dts files according to
Documentation/devicetree/bindings/arm/gic.txt
v3 (swarren):
* Moved of_irq_init() call into board-dt.c to avoid ifdef'ing it.
- Even with a dummy replacement if !CONFIG_OF, the reference from
tegra_dt_irq_match[] to gic_of_init() would still have to be ifdef'd
- It's plausible that tegra_dt_irq_match[] may need to contain more
entries in the future, and defining what they are seems more suitable
for board-dt.c than irq.c
v2 (swarren):
* Removed some stale GIC init code from board-dt.c
* Undid some accidental 0x -> 0x0 search/replace.
Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com>
[olof: added include of <asm/hardware/gic.h> for compile to pass]
The I2S and DAS nodes don't have children, and hence don't need to set
address/size cells.
For now they are a minimal binding. It needs to be amended with
vendor-specific settings for phy setup and link tuning, etc.
v2: Added bindings specification and phy_type properties
Add a pinmux node to tegra20.dtsi in order to instantiate the future
pinmux device.
v2: Specify reg property precisely; don't just point at the whole APB_MISC
register range.
Everything required to populate NVIDIA Tegra devices from the device
tree. This patch adds a new DT_MACHINE_DESC() which matches against
a tegra20 device tree. So far it only registers the on-chip devices,
but it will be refined in follow on patches to configure clocks and
pin IO from the device tree also.
