The Versatile boards have the same sysregs as other ARM Ltd boards. Add
the nodes in order to enable support for 24MHz counter as sched_clock.
This is a minimal node definition as the existing sub node definition
used on VExpress has some issues raised by Linus W.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: devicetree@vger.kernel.org
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Pull device tree updates from Grant Likely:
"The branch contains the following device tree changes the v3.17 merge
window:
Group changes to the device tree. In preparation for adding device
tree overlay support, OF_DYNAMIC is reworked so that a set of device
tree changes can be prepared and applied to the tree all at once.
OF_RECONFIG notifiers see the most significant change here so that
users always get a consistent view of the tree. Notifiers generation
is moved from before a change to after it, and notifiers for a group
of changes are emitted after the entire block of changes have been
applied
Automatic console selection from DT. Console drivers can now use
of_console_check() to see if the device node is specified as a console
device. If so then it gets added as a preferred console. UART
devices get this support automatically when uart_add_one_port() is
called.
DT unit tests no longer depend on pre-loaded data in the device tree.
Data is loaded dynamically at the start of unit tests, and then
unloaded again when the tests have completed.
Also contains a few bugfixes for reserved regions and early memory
setup"
* tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux: (21 commits)
of: Fixing OF Selftest build error
drivers: of: add automated assignment of reserved regions to client devices
of: Use proper types for checking memory overflow
of: typo fix in __of_prop_dup()
Adding selftest testdata dynamically into live tree
of: Add todo tasklist for Devicetree
of: Transactional DT support.
of: Reorder device tree changes and notifiers
of: Move dynamic node fixups out of powerpc and into common code
of: Make sure attached nodes don't carry along extra children
of: Make devicetree sysfs update functions consistent.
of: Create unlocked versions of node and property add/remove functions
OF: Utility helper functions for dynamic nodes
of: Move CONFIG_OF_DYNAMIC code into a separate file
of: rename of_aliases_mutex to just of_mutex
of/platform: Fix of_platform_device_destroy iteration of devices
of: Migrate of_find_node_by_name() users to for_each_node_by_name()
tty: Update hypervisor tty drivers to use core stdout parsing code.
arm/versatile: Add the uart as the stdout device.
of: Enable console on serial ports specified by /chosen/stdout-path
Add a stdout-path property to the Versatile devicetree so that automatic
console selection works without needing a console= line on the kernel
command line.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
The versatile dts is missing any clock data. Add the clocks.
It is not clear from the documentation where pclk comes from, so for
now it is a dummy clock which is sufficient for things to work.
While not needed for probing, add the "arm,pl180" compatible string for
completeness.
Add valid-mask and clear-mask properties to the versatile dts so the
platform code doing the same thing can be removed.
Two of the versatile irq definitions are incorrect, mostly because two
devices have connections to more than one interrupt controller. Fix them
by using the new interrupts-extended property to fan out without using
an awful interrupt-map nexus node.
Enable DT based init for the sp804 timers on versatile DT platform.
The MMCI driver will not work without two IRQs since this is not
flagged as a single-irq variant. Looking through the complex IRQ
definition for the MMCI on the versatile (including an #if 1
statement forcing MMCI IRQ0 to the VIC) this appears to the the
correct IRQ number for both models.
Cc: Niklas Hernaeus <niklas.hernaeus@linaro.org>
For testing the dt work, define a dt-enabled versatile platform.
This patch adds a new versatile platform for when using the device
tree. Add platform and amba devices are discovered and registered by
parsing the device tree. Clocks and initial io mappings are still
configured statically.
This patch still depends on some static platform_data for a few devices
which is passed via the auxdata structure to of_platform_populate(),
but it is a viable starting point until the drivers can get all
configuration data out of the device tree.
