Assign Ethernet clock parents explicitly. The VF610 Tower Board
uses the external Ethernet clock input which is connected to
a 50MHz clock.
The Vybrid SoC has two ethernet interfaces (fec0 and fec1) which
use the same clock source (VF610_CLK_ENET). Therefore this parent
configuration affects multiple consumer devices and need to be
specified in the clock provider node.
This adds the NAND flash controller (NFC) peripherial. The driver
supports the SLC NAND chips found on Freescale's Vybrid Tower System
Module. The Micron NAND chip on the module needs 4-bit ECC per 512
byte page. Use 24-bit ECC per 2k page, which is supported by the
driver.
Signed-off-by: Bill Pringlemeir <bpringlemeir@nbsps.com>
Reviewed-by: Brian Norris <computersforpeace@gmail.com>
Signed-off-by: Stefan Agner <stefan@agner.ch>
This commit includes a minor nomenclature fixup for boards based on the
Freescale VF610 SoC and which make use of the alternate "RMII1_RXD1"
functionality for pin PTC12. This brings the macro name in-line with
both the datasheet and other similar macros.
Signed-off-by: Cory Tusar <cory.tusar@pid1solutions.com>
Acked-by: Stefan Agner <stefan@agner.ch>
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
On Vybrid, all peripherals are numbered starting with zero,
including the GPIO and PORT module. However, the labels of the
corresponding device tree nodes start with one, which is confusing.
Fix that by renaming the labels of the gpio nodes in the device
tree.
On i.MX28, the MDIO bus is shared between the two FEC instances.
The driver makes sure that the second FEC uses the MDIO bus of the
first FEC. This is done conditionally if FEC_QUIRK_ENET_MAC is set.
However, in newer designs, such as Vybrid or i.MX6SX, each FEC MAC
has its own MDIO bus. Simply removing the quirk FEC_QUIRK_ENET_MAC
is not an option since other logic, triggered by this quirk, is
still needed.
Furthermore, there are board designs which use the same MDIO bus
for both PHY's even though the second bus would be available on the
SoC side. Such layout are popular since it saves pins on SoC side.
Due to the above quirk, those boards currently do work fine. The
boards in the mainline tree with such a layout are:
- Freescale Vybrid Tower with TWR-SER2 (vf610-twr.dts)
- Freescale i.MX6 SoloX SDB Board (imx6sx-sdb.dts)
This patch adds a new quirk FEC_QUIRK_SINGLE_MDIO for i.MX28, which
makes sure that the MDIO bus of the first FEC is used in any case.
However, the boards above do have a SoC with a MDIO bus for each FEC
instance. But the PHY's are not connected in a 1:1 configuration. A
proper device tree description is needed to allow the driver to
figure out where to find its PHY. This patch fixes that shortcoming
by adding a MDIO bus child node to the first FEC instance, along
with the two PHY's on that bus, and making use of the phy-handle
property to add a reference to the PHY's.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Since restructuring of the device tree files, the USB misc/phy
nodes are disabled by default. Hence we need to enable those
explicitly when USB is used.
Use GPIO support by adding SD card detection configuration and
GPIO pinmux for Colibri's standard GPIO pins. Attach the GPIO
pins to the iomuxc node to get the GPIO pin settings applied.
This adds more generic base device trees for Vybrid SoCs. There
are three series of Vybrid SoC commonly available:
- VF3xx series: single core, Cortex-A5 without external memory
- VF5xx series: single core, Cortex-A5
- VF6xx series: dual core, Cortex-A5/Cortex-M4
The second digit represents the presents of a L2 cache (VFx1x).
The VF3xx series are not suitable for Linux especially since the
internal memory is quite small (1.5MiB).
The VF500 is essentially the base SoC, with only one core and
without L1 cache. The VF610 is a superset of the VF500, hence
vf500.dtsi is then included and enhanced by vf610.dtsi. There is
no board using VF510 or VF600 currently, but, if needed, they can
be added easily.
The Linux kernel can also run on the Cortex-M4 CPU of Vybrid
using !MMU support. This patchset creates a device tree structure
which allows to share peripherals nodes for a VF6xx Cortex-M4
device tree too. The two CPU types have different views of the
system: Foremost they are using different interrupt controllers,
but also the memory map is slightly different. The base device
tree vfxxx.dtsi allows to create SoC and board level device trees
supporting the Cortex-M4 while reusing the shared peripherals
nodes.
The clock controller module (CCM) has several clock inputs, which
are connected to external crystal oscillators. To reflect this,
assign these fixed clocks to the CCM node directly.
This especially resolves initialization order dependencies we had
with the earlier initialization code: When resolving of the fixed
clocks failed in clk-vf610, the code created fixed clocks with a
rate of 0.
Add USB support for Freescale Vybrid tower. The USB hosts over-current
protection signal is not connected to the PHY's over- current
protection, hence we need to disable it.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
The ttyLP1 is already the default console/serial port. The
tower board will route ttyLP2 to the same connectors depending
on the JP23/24 settings.
See:
http://lists.infradead.org/pipermail/linux-arm-kernel/2014-July/276457.html
http://lists.infradead.org/pipermail/linux-arm-kernel/2014-July/275576.html
This was added by:
Commit 8128c4f36 ("ARM: dts: vf610-twr: Add simple-card support.")
This useless property may cause some confusions for users.
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
Previous version had an extra 'fsl' which made the pins not match
any entry. The console message,
vf610-pinctrl 40048000.iomuxc: no fsl,pins property in node \
/soc/aips-bus@40000000/iomuxc@40048000/vf610-twr/esdhc1grp
is displayed without the fix. The prior version would generally
work as u-boot sets the pins properly for sdhc. This change allows
Linux sdhc use even if u-boot is built without sdhc support.
Fixes: 0517fe6aa880 ("ARM: dts: vf610-twr: Add support for sdhc1")
Cc: <stable@vger.kernel.org>
Reviewed-by: Sascha Hauer <s.hauer@pengutronix.de>
Reviewed-by: Yuan Yao <yao.yuan@freescale.com>
The kernel was not able to boot from SD card because sdhc support
was not present into the dts.
A new entry for sdhc1 was added for vf610-twr board based on the
compatible entry present on imx53.
After applying these changes, the kernel is able to boot successfully
from SD card.
Signed-off-by: Cosmin Stoica <cosminstefan.stoica@freescale.com>
Signed-off-by: Chircu Bogdan <Bogdan.Chircu@freescale.com>
Signed-off-by: Eddy Petrisor <eddy.petrisor@freescale.com>
Per bindings of fixed-clock, #clock-cells is a required property. Let's
add it for those fixed rate clocks.
vf610 has two ADC controllers, and vf610-twr board ADC0_SE5 pin connect
to sliding rheostat for ADC test, other ADC pins connect to connectors for
future use.
Add support for ADC0_SE5.
CC: Jonathan Cameron <jic23@kernel.org>
CC: Mark Rutland <mark.rutland@arm.com>
CC: Otavio Salvador <otavio@ossystems.com.br>
CC: Peter Meerwald <pmeerw@pmeerw.net>
CC: Lars-Peter Clausen <lars@metafoo.de>
Signed-off-by: Fugang Duan <B38611@freescale.com>
This patch adds and enables simple-card support in DT node.
This patch adds and enables SGTL5000 codec support.
This patch adds and enables the SAI device.
Currently, all pinctrl setting nodes are defined in <soc>.dtsi, so that
boards that share the same pinctrl setting do not have to define it time
and time again in <board>.dts. However, along with the devices and use
cases being added continuously, the pinctrl setting nodes under iomuxc
becomes more than expected. This bloats device tree blob for particular
board unnecessarily since only a small subset of those pinctrl setting
nodes will be used by the board. It impacts not only the DTB file size
but also the run-time device tree lookup efficiency.
The patch moves all the pinctrl data into individual boards as needed.
With the changes, the pinctrl setting nodes becomes local to particular
board, and it makes no sense to continue numbering the setting for
given peripheral. Thus, all the pinctrl phandler name gets updated to
have only peripheral name in there.
Acked-by: Fugang Duan <B38611@freescale.com>
This patch enables DSPI0 and at26df081a flash device for Vybrid VF610
TOWER board.
Signed-off-by: Chao Fu <b44548@freescale.com>
enable i2c0 device on Vybrid VF610 Tower Board
Signed-off-by: Jingchang Lu <b35083@freescale.com>
Add initial Freescale Vybrid VF610 Tower board support
with uart and fec enabled.
