The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com>
Acked-by: Michael Trimarchi <michael@amarulasolutions.com>
Acked-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Remove skeleton.dtsi from the common ARM Cortex-M dtsi. This will allow
us to remove skeleton.dtsi on a per platform basis and get rid of the
unit address warning on the memory nodes without getting duplicate memory
nodes.
See 3ebee5a2e141 ("arm64: dts: kill skeleton.dtsi") for additional
reasons not to use the skeleton.dtsi.
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
Acked-by: Rob Herring <robh@kernel.org>
Acked-by: Vladimir Murzin <vladimir.murzin@arm.com>
Acked-by: Alexandre TORGUE <alexandre.torgue@st.com>
This adds an initial device tree to run Linux on the Cortex-M4 on
the Vybrid based Colibri VF61 module.
Signed-off-by: Stefan Agner <stefan@agner.ch>
